Home » Eclipse Projects » Plugin Development Environment (PDE) » Enabling the Plug-In Spy
Enabling the Plug-In Spy [message #1734633] Fri, 10 June 2016 02:44 Go to next message
I'd like to enable the plug-in spy in my RCP application. To do so, I have included the following plug-ins in its build path:
org.eclipse.core.runtime
org.eclipse.ui
org.eclipse.ui.forms
However, nothing happens when I press ALT+SHIFT+F1 in my application.
Is there any other plug-in I should add, or something else I should do to enable the plug-in spy?
Thanks in advance!
Vlad
Re: Enabling the Plug-In Spy [message #1734809 is a reply to message #1734633] Mon, 13 June 2016 02:42 Go to previous messageGo to next message
I was able to find a workaround for this problem, so I am writing my solution here in case anyone else can use it.
What I ended up doing was defining my own command for opening the Plug-In Spy in my plugin's plugin.xml file:
<command
    description="Spy Command"
    id="org.eclipse.pde.runtime.spy.commands.mySpyCommand"
    name="Spy Command">
</command>
I associated a Handler to this command, pointing to the SpyHandler class provided by PDE:
<handler
    class="org.eclipse.pde.internal.runtime.spy.handlers.SpyHandler"
    commandId="org.eclipse.pde.runtime.spy.commands.mySpyCommand">
</handler>
Finally, I created a binding between my command and the Alt+Shift+F1 key combination:
<key
    contextId="org.eclipse.ui.contexts.dialogAndWindow"
    schemeId="myscheme"
    sequence="M3+M2+F1">
</key>
I still don't know why I was not able to use the Plug-In Spy out of the box, but this workaround did the trick for me.
Vlad
Re: Enabling the Plug-In Spy [message #1734867 is a reply to message #1734633] Mon, 13 June 2016 02:42 Go to previous messageGo to next message
<command
name="Spy Command">
</command>
<handler
</handler>
<key
schemeId="myscheme"
</key>
Vlad
Re: Enabling the Plug-In Spy [message #1735706 is a reply to message #1734633] Wed, 22 June 2016 03:43 Go to previous message
On 10/06/2016 08:44, Vlad Acretoaie wrote:
> org.eclipse.ui
> Thanks in advance!
> Cheers,
> Vlad
you should add also org.eclipse.pde.runtime
see http://blog.vogella.com/2009/06/22/eclipse-plug-in-spy-eclipse-rcp/
Prof. Lorenzo Bettini, Computer Science, DISIA, Univ. Firenze
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Previous Topic:create custom export wizard
Next Topic:Using JavaCompiler within a Plug-in: Package does not exist
Current Time: Wed Jul 23 21:44:25 EDT 2025
Powered by FUDForum. Page generated in 0.52719 seconds
