Home » Language IDEs » C / C++ IDE (CDT) » No Defined Symbols?
No Defined Symbols? [message #173091] Mon, 17 July 2006 16:32 Go to next message
My code uses defines like "_WIN32" and "linux". But CDT doesn't seem
to
have any predefined symbols like VC++, code::blocks, and Dev-Cpp. Why
doesn't CDT automatically detect its environment and define symbols? Does
the user have to define everything?
Nathan
Re: No Defined Symbols? [message #173146 is a reply to message #173091] Tue, 18 July 2006 00:46 Go to previous messageGo to next message
Originally posted by: newsgroups.snipah.com
Nathan,
usually the compiler does predefines these symbols, why should cdt do that?
In case you use cygwin-gcc, try __CYGWIN32__. Because its cygwin and not
windows. Or read the compiler manuals.
ciao
Enrico
Nathan wrote:
> My code uses defines like "_WIN32" and "linux". But CDT doesn't seem to
> Nathan
Re: No Defined Symbols? [message #173168 is a reply to message #173091] Tue, 18 July 2006 01:58 Go to previous messageGo to next message
Nathan,
if you need predefined symbols you can set them in the project properties of
managed make projects. Environment variables will generally passed through
to the compiler although you can modify this thoo in the project properties.
Eclipse does not of itself define any symbols.
HTH
Norbert
Re: No Defined Symbols? [message #173460 is a reply to message #173146] Fri, 21 July 2006 13:21 Go to previous messageGo to next message
__CYGWIN32__ works, your right I should see what defines I can use from
the compiler.
Nathan
Re: No Defined Symbols? [message #174099 is a reply to message #173168] Mon, 31 July 2006 08:01 Go to previous message
Originally posted by: divis1969.mail.ru
Unfortunately, undefined symbols and unconfigured include directories
impacts the indexer and outline view.
This is the major disadvantage of the Eclipse CDT I see right know.
Sometimes, you need just to browse the bunch of code and the indexer is the
all that you need for this purpose. But if you don't have build output, if
this code have a lot of include directories and predefined symbols, you
cannot use CDT effectively.
So, when I create the new standard make project, I would prefer if CDT
indexer assumes each directory where .h files resides as an include
directory and each predefined symbol as already defined.
For example, the code base could have two different definitions of the same
function. Depending on #define statements you could work with one of them.
But I would like to see both of them under outline view.
I don't know, may be all of the above is already scheduled as future
enchancements of CDT?
Dmitry
"Norbert Ploett" <norbert.ploett@siemens.com> wrote in message
news:1153202292.790878@baruth.khe.siemens.de...
> Nathan,
> of managed make projects. Environment variables will generally passed
> through to the compiler although you can modify this thoo in the project
> properties.
> HTH
> Norbert
Previous Topic:make: *** No rule to make target `all'.
Next Topic:GDB on Linux machine and Eclipse on Windows .. how ?
Current Time: Sat Jul 26 21:18:43 EDT 2025
Powered by FUDForum. Page generated in 0.04959 seconds
