Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » export model to xsd with referenced generator model
export model to xsd with referenced generator model [message #1734442] |
Wed, 08 June 2016 07:52  |
I run into a problem when exporting an xsd from a genmodel which
references to another generator model. I want to use the XST XML editor,
which uses the xsd for content assistant and validation, to edit the xml
file which could be read from the generated ecore model.
Problem:
First the referenced schema was exported from an *.genmodel
(schemaA.genmodel). Then the schema referencing to the previously
exported schema was exported but the imported namespace from the
referenced generator model was not correct.
import statement:
<xsd:import namespace="http://xyz.com/schemaA.xsd"
schemaLocation="../../com.xyz.a/model/schemaA.xsd"/>
The schemaLocation contains this ../../ which works perfectly when
starting the RCP from the IDE. But after the RCP export the schemaA.xsd
could not be found.
platform:/plugin/ should be used instead of ../../
Workaround: replacing ../../ "manually" by platform:/plugin/.
Question: Is there a setting to generate the xsd by using
platform:/plugin/ instead of ../../? May be a setting at the *.genmodel?
Martin
Re: export model to xsd with referenced generator model [message #1734577 is a reply to message #1734548] |
Thu, 09 June 2016 09:43   |
Martin,
Comments below.
On 09.06.2016 11:49, Martin Jacob wrote:
> Thanks Ed,
> well, the namespace is correct but the schemaLocation is not.
> Yes, both xsd files are included in the distribution and I also unpack
> the plugin. But still no success using the WST XML editor.
> The only working solution is to use platform:/plugin/ instead of ../../.
I think whether it works or not depends on what URI is used to open the
schema that contains this reference. Or at least it should. If the
schema itself is referenced with platform:/plugin/<plugin-id>/<path>
then the relative path itself should resolve to platform:/plugin/....
The platform:/plugin scheme should not require a version number.
I know all this works for *.ecore and *.genmodel resources, so it should
work in general. That's how relative paths should work in general.
> I believe when using ../../, the correct path could not be resolved,
> e.g. the plugin version.
> So instead of ../../com.xyz.a/model/schemaA.xsd
> ../../com.xyz.a_1.0.0/model/schemaA.xsd might work but I have not tested.
> When starting the product from the IDE it works as it takes the source
> code/xsd directly without a version at the "plugin" folder.
Yes it should just work.
> May be it is an issue in WST XML editor catalogue to be unable to find
> the imported schema?
It would certainly depend on how the schema that contains this relative
reference itself is referenced. platform:/plugin/<plugin-id> should work
and then the relative reference should be resolved to platform:/plugin
as well.
> Shall I create two small sample plugins to reproduce the issue on your
> side?
I implemented the XSD model, so I know how relative reference should
work. I can't comment on why it might not work with WST. That's a Web
Tools issue. You can see in *.ecore and *.genmodel files that these
cross resource references also look like this, and they definitely work.
> Martin
Re: export model to xsd with referenced generator model [message #1734649 is a reply to message #1734577] |
Fri, 10 June 2016 03:48   |
Hi Ed,
As the emf eco system is able to handle the relative path it might be an
issue of the WST XML editor.
So I posted a question in eclipse.webtools forum, but no response for now.
some more comments below
Am 09.06.2016 um 15:43 schrieb Ed Merks:
> Martin,
> Comments below.
>> Thanks Ed,
When I look into the catalogue entry (preferences > XML > XML Catalog)
it says for the referencing schema:
Entry element: URI
C:\Users\jacob\Documents\dev\RCP\plugins\com.xyz.b_1.0.0.201606100929.jar
URI:
jar:file:/C:/Users/jacob/Documents/dev/RCP/plugins/com.xyz.b_1.0.0.201606100929.jar!/model/schemaB.xsd
Key type: Namespace name
Key: http://xyz.com/schemaB.xsd
Is there any thing suspicious?
Yes it does.
> as well.
Both schema are inside different plugins. The structure is like this:
RCP
+ plugins
+ com.xyz.a_1.0.0/model/schemaA.xsd
+ com.xyz.b_1.0.0/model/schemaB.xsd
Where schemaB.xsd is referencing schemaA.xsd
>> side?
Yes all works well within the IDE respectively RCP started as run
configuration. But unfortunately not with the exported RCP and the WST
XML editor.
Do you know the xsd model you implemented is also used by the WST XML
editor?
>> Martin
Re: export model to xsd with referenced generator model [message #1734659 is a reply to message #1734649] |
Fri, 10 June 2016 04:26   |
Martin,
I wonder which URIs you used the register the schemas... I'm not
familiar with the details of the catalog, but I imagine it's a logical
namespace URI to physical location mapping. A correct/proper
interpretation of a relative path in schema import/includes should
resolve the relative URI of the location against the absolute URI of the
containing schema, and that should produce another absolute path (just
as it does for an href="..." in an HMTL document).
On 10.06.2016 09:48, Martin Jacob wrote:
> Hi Ed,
> an issue of the WST XML editor.
> now.
>> Martin,
>> Comments below.
>>> Thanks Ed,
> Entry element: URI
> Location: model\schemaB.xsd in jar file
> URI:
>>> tested.
> Yes it does.
>> as well.
> RCP
> + plugins
>>> side?
> XML editor.
> editor?
>>> Martin
Re: export model to xsd with referenced generator model [message #1734681 is a reply to message #1734659] |
Fri, 10 June 2016 05:30   |
Ed,
oh yes, the URI looks strange. I used the extension point definition of
the catalogue is:
<extension point="org.eclipse.wst.xml.core.catalogContributions">
<catalogContribution id="opn">
<uri name="http://xyz.com/schemaB.xsd" uri="model/schemaB.xsd"></uri>
</catalogContribution>
</extension>
Which is then displayed/translated at the catalogue preferences as
described.
Entry element: URI
URI:
Am 10.06.2016 um 10:26 schrieb Ed Merks:
> Martin,
>> Hi Ed,
>> now.
>>> Martin,
>>> Comments below.
>>>> Thanks Ed,
>> Entry element: URI
>> URI:
>>>> tested.
>> Yes it does.
>>> as well.
>> RCP
>> + plugins
>>>> side?
>> XML editor.
>> editor?
>>>> Martin
Re: export model to xsd with referenced generator model [message #1734723 is a reply to message #1734681] |
Fri, 10 June 2016 12:24   |
Martin,
Yes, that won't work. It needs to be a logical namespace, not a
physical file location. There's no mechanism that would allow a
relative reference to "traverse" to another jar. The "platform:" scheme
is built-in to Eclipse, i.e., it can even be accessed as a java.net.URL
because there is a registered URLHandler. You should perhaps try
registering with platform:/plugin/com.xyz.b/model/schemaB.xsd and hope
that this works.
On 10.06.2016 11:30, Martin Jacob wrote:
> Ed,
> of the catalogue is:
> </extension>
> described.
> Entry element: URI
> URI:
>> Martin,
>>> Hi Ed,
>>> now.
>>>> Martin,
>>>> Comments below.
>>>>> Thanks Ed,
>>>>> unpack
>>>> the
>>> Entry element: URI
>>> URI:
>>>> should
>>>>> tested.
>>>>> source
>>> Yes it does.
>>>>> find
>>>> relative
>>>> work
>>>> as well.
>>> RCP
>>> + plugins
>>>>> your
>>>>> side?
>>>> work.
>>> XML editor.
>>> editor?
>>>>> Martin
Re: export model to xsd with referenced generator model [message #1735061 is a reply to message #1734723] |
Wed, 15 June 2016 02:50   |
Ed,
I modified the extension point at
/extension/catalogContribution/uri/@uri, see below, but still no success.
uri="platform:/plugin/com.xyz.b/model/schemaB.xsd"</uri>
</extension>
As mentioned earlier it works if I use
platform:/plugin/com.xyz.b/model/schemaB.xsd at the schemaLocation
attribute of the import. For me it seams the schemaLocation is used to
find schemaB.xsd instead of the catalogue entry which should match the
namespace URI with the file.
Do you think this is more an issue of the Editor or others?
Unfortunately I go no feedback from
news://news.eclipse.org:119/njbf5u$i8a$1@xxxxxxxxe.org.
Martin
Am 10.06.2016 um 18:24 schrieb Ed Merks:
> Martin,
> that this works.
>> Ed,
>> </extension>
>> described.
>> Entry element: URI
>> URI:
>>> Martin,
>>>> Hi Ed,
>>>> now.
>>>>> Martin,
>>>>> Comments below.
>>>>>> Thanks Ed,
>>>>>> unpack
>>>>> the
>>>> Entry element: URI
>>>> URI:
>>>>> should
>>>>>> tested.
>>>>>> source
>>>> Yes it does.
>>>>>> find
>>>>> relative
>>>>> work
>>>>> as well.
>>>> RCP
>>>> + plugins
>>>>>> your
>>>>>> side?
>>>>> work.
>>>> XML editor.
>>>> editor?
>>>>>> Martin
Re: export model to xsd with referenced generator model [message #1735092 is a reply to message #1735061] |
Wed, 15 June 2016 09:41   |
Martin,
Comments below.
On 15.06.2016 08:50, Martin Jacob wrote:
> Ed,
> </extension>
How is the schema containing the import itself registered?
> For me it seams the schemaLocation is used to find schemaB.xsd instead
> of the catalogue entry which should match the namespace URI with the
> file.
Technically the schemaLocation on an import or include is just a "hint"
for where to find the schema. A schema processor can use or ignore that
hint.
What are the two schema namespaces involved and how (with which URI) are
each of them registered in the catalog?
Yes, not all forums are as responsive.
> Martin
>> Martin,
>> that this works.
>>> Ed,
>>> </extension>
>>> described.
>>> Entry element: URI
>>> URI:
>>>> Martin,
>>>> of the
>>>>> Hi Ed,
>>>>> now.
>>>>>> Martin,
>>>>>> Comments below.
>>>>>>> Thanks Ed,
>>>>>>> unpack
>>>>>> the
>>>>> Catalog)
>>>>> Entry element: URI
>>>>> URI:
>>>>>> should
>>>>>>> resolved,
>>>>>>> tested.
>>>>>>> source
>>>>> Yes it does.
>>>>>>> find
>>>>>> relative
>>>>>> work
>>>>>> platform:/plugin
>>>>>> as well.
>>>>> RCP
>>>>> + plugins
>>>>>>> your
>>>>>>> side?
>>>>>> a Web
>>>>>> work.
>>>>> WST
>>>>> XML editor.
>>>>> editor?
>>>>>>> Martin
Re: export model to xsd with referenced generator model [message #1735127 is a reply to message #1735092] |
Wed, 15 June 2016 13:16   |
Ed,
thanks Ed. The schema containing the import (schemaA.xsd) is registered
same as the referenced (schemaB.xsd). But schemaA.xsd is on another
plugin then schemaB.xsd.
<uri name="http://xyz.com/schemaA.xsd" uri="model/schemaA.xsd"</uri>
</extension>
schemaA.xsd has no (empty) namespace and schemaB.xsd has a namespace ("b").
Do you know the meaning of extension/catalogContribution/@id ?
It seams the schemaLocation only is evaluated by the schema processor
but not the catalogues entry. Does the schema processor look into the
catalogue?
Martin
Am 15.06.2016 um 15:41 schrieb Ed Merks:
> Martin,
> Comments below.
>> Ed,
>> </extension>
>> file.
> hint.
>> Martin
>>> Martin,
>>> that this works.
>>>> Ed,
>>>> </extension>
>>>> described.
>>>> Entry element: URI
>>>> URI:
>>>>> Martin,
>>>>> of the
>>>>>> Hi Ed,
>>>>>> now.
>>>>>>> Martin,
>>>>>>> Comments below.
>>>>>>>> Thanks Ed,
>>>>>>>> unpack
>>>>>>> the
>>>>>> Catalog)
>>>>>> Entry element: URI
>>>>>> URI:
>>>>>>> should
>>>>>>>> resolved,
>>>>>>>> tested.
>>>>>>>> source
>>>>>> Yes it does.
>>>>>>>> find
>>>>>>> relative
>>>>>>> work
>>>>>>> platform:/plugin
>>>>>>> as well.
>>>>>> RCP
>>>>>> + plugins
>>>>>>>> your
>>>>>>>> side?
>>>>>>> a Web
>>>>>>> work.
>>>>>> WST
>>>>>> XML editor.
>>>>>> editor?
>>>>>>>> Martin
Re: export model to xsd with referenced generator model [message #1735138 is a reply to message #1735127] |
Wed, 15 June 2016 14:11   |
Martin,
Comments below.
On 15.06.2016 19:16, Martin Jacob wrote:
> Ed,
> registered same as the referenced (schemaB.xsd). But schemaA.xsd is on
> another plugin then schemaB.xsd.
> </extension>
Yes, that's what I guessed. But it's this schema that has this poor
physical URI that can't possibility resolve the relative schemLocation
URI within that file. But you've not tried platform:/plugin for this
registration yet?
> ("b").
Now does this no namespace relate to name="http://xyz.com/schemaA.xsd"?
It's it supported to the the namespace of the schema?
No, I know nothing about the catalog?
> catalogue?
That all depends on Web Tools extensions, and I'm not familiar with
those. But I'm concerned you've been focused on the registration for B
and it's the schema A that contains the schemaLocation that's failing to
resolve, so it's the URI used to load A that will determine how that
relative schemaLocation resolves. So your focus should be on A's
registration.
> Martin
>> Martin,
>> Comments below.
>>> Ed,
>>> success.
>>> </extension>
>>> file.
>> hint.
>>> Martin
>>>> Martin,
>>>> scheme
>>>> java.net.URL
>>>> that this works.
>>>>> Ed,
>>>>> </extension>
>>>>> described.
>>>>> Entry element: URI
>>>>> URI:
>>>>>> Martin,
>>>>>> logical
>>>>>> of the
>>>>>> (just
>>>>>>> Hi Ed,
>>>>>>> might be
>>>>>>> response for
>>>>>>> now.
>>>>>>>> Martin,
>>>>>>>> Comments below.
>>>>>>>>> Thanks Ed,
>>>>>>>>> unpack
>>>>>>>> open
>>>>>>>> the
>>>>>>>> If the
>>>>>>> Catalog)
>>>>>>> Entry element: URI
>>>>>>> URI:
>>>>>>>> should
>>>>>>>> general.
>>>>>>>>> resolved,
>>>>>>>>> tested.
>>>>>>>>> source
>>>>>>> Yes it does.
>>>>>>>>> find
>>>>>>>> relative
>>>>>>>> should
>>>>>>>> work
>>>>>>>> platform:/plugin
>>>>>>>> as well.
>>>>>>> this:
>>>>>>> RCP
>>>>>>> + plugins
>>>>>>>>> your
>>>>>>>>> side?
>>>>>>>> should
>>>>>>>> a Web
>>>>>>>> these
>>>>>>>> work.
>>>>>>> WST
>>>>>>> XML editor.
>>>>>>> WST XML
>>>>>>> editor?
>>>>>>>>> Martin
Current Time: Mon Jul 21 00:06:48 EDT 2025
Powered by FUDForum. Page generated in 0.10960 seconds
