Home » Eclipse Projects » Oomph » Howto prepare preconfigured Eclipse Installer
Howto prepare preconfigured Eclipse Installer [message #1734546] Thu, 09 June 2016 05:52 Go to next message
as an Oomph beginner, I am trying to use the Eclipse installer (eclipse-inst-win64.exe downloaded from https://www.eclipse.org/downloads/download.php?file=/oomph/epp/neon/RC3a/eclipse-inst-win64.exe) in such a way:
I wrote a product setup file for an Eclipse product based on the C++ package plus some utility plugins and some company-internal features.
This product can be installed successfully using eclipse-inst-win64.exe by interactively switching to the advanced mode, adding the setup file und starting the install process.
Is it possible to prepare an easy-to-use preconfigured eclipse-inst-win64.exe so that any user in our department can install the tailored Eclipse just with a double click, but without any further actions?
Thank you in advance
Matthias
Re: Howto prepare preconfigured Eclipse Installer [message #1734578 is a reply to message #1734546] Thu, 09 June 2016 09:44 Go to previous messageGo to next message
Matthias,
That's certainly possible in principle, but the not something we've
implemented in practice. If there were funding for such an effort, it
would be done already...
On 09.06.2016 11:52, Matthias Albert wrote:
> in such a way:
> actions?
> Matthias
Re: Howto prepare preconfigured Eclipse Installer [message #1740065 is a reply to message #1734578] Mon, 08 August 2016 15:53 Go to previous message
Yes it can be done. I did it!
Once you have your product setup file, you need to build another eclipse catalog file that points to your product setup file.
I placed one eclipse-installer onto a shared drive that every has access to in my development department. This eclipse-installer has an .ini file for it. In this file you must place this:
-Doomph.redirection.setups=index:/->file://D:/your/directory/
That is for a static file on a file system, You can also use a URI and host the file.
At that location you must have a file called: org.eclipse.setup
This file needs to have a productCatalog node which points to your custom setup file
<setup:Index
xmi:version="2.0"
xmlns:setup="http://www.eclipse.org/oomph/setup/1.0"
name="index"
label="Index">
<discoverablePackage
href="models/Git.ecore#/"/>
href="models/Launching.ecore#/"/>
href="models/JDT.ecore#/"/>
href="models/Maven.ecore#/"/>
href="models/Mylyn.ecore#/"/>
href="models/PDE.ecore#/"/>
href="models/Predicates.ecore#/"/>
href="models/Projects.ecore#/"/>
href="models/ProjectSet.ecore#/"/>
href="models/Resources.ecore#/"/>
href="models/SetupTarglets.ecore#/"/>
href="models/SetupWorkingSets.ecore#/"/>
href="models/Targlets.ecore#/"/>
href="models/Workbench.ecore#/"/>
href="models/WorkingSets.ecore#/"/>
<productCatalog
href="your.products.setup#/"/>
</setup:Index>
You also need to save all of those models listed too.
Basically to acheive this I used the normal eclipse installer to install a fresh version of eclipse. Then after installed I opened up Navigate->Open Setup->Parent Models->Catalog Index
That will open up the xml file of the default product catalog, the one from eclipse. You just need to remove everything from that other than one product catalog pointed to your own custom setup. It will end up looking like the above.
You can then leave the hosted links to the Models/ nodes, or you can manually download them into your shared drive and host them yourself.
Sorry this is a terrible guide as I don't have time to write an amazing one.
But basically I learned everything I needed to know from this guide: https://wiki.eclipse.org/Eclipse_Oomph_Authoring
[Updated on: Mon, 08 August 2016 15:57] by Moderator
Previous Topic:Reusing variables across setups
Next Topic:using boolean variables in filter
Current Time: Thu Jul 24 23:43:26 EDT 2025
Powered by FUDForum. Page generated in 0.06113 seconds
