Home » Modeling » Papyrus » No palette when editing model
No palette when editing model [message #1734301] Mon, 06 June 2016 20:55 Go to next message
I am new to Papyrus. I running Mars.2 and I added all the Papyrus components from Install new Software.
I followed a tutorial on Getting Started with Papyrus Modeling. I created the model and when I opened it, there is supposed to be a palette on the right side of the window. I have no palette.
Can anyone point me in the right direction to fix this problem?
Thanks, in advance.
Re: No palette when editing model [message #1734411 is a reply to message #1734301] Wed, 08 June 2016 02:59 Go to previous messageGo to next message
I think by default you won't see the palette as you don't have an open diagram. If you look at the "Model Explorer" (Window -> Show View -> Model Explorer if not visible), you should see the top level element of your model (which looks like a package). Right-Click on this to create a new diagram and an editor should open with a palette customised for the type of diagram you have created.
Dan
Re: No palette when editing model [message #1734448 is a reply to message #1734411] Wed, 08 June 2016 08:18 Go to previous message
You should also make sure you have the Papyrus perspective open.
Previous Topic:adding new compartment for opaque action in Activity Diagra
Next Topic:Problem Recreation of activity diagram from activity
Current Time: Thu Sep 25 20:26:12 EDT 2025
Powered by FUDForum. Page generated in 0.07295 seconds
