Home » Eclipse Projects » WindowBuilder » Version for Mars 4.5.2(Installpage doesn't work)
Version for Mars 4.5.2 [message #1734356] Tue, 07 June 2016 08:07 Go to next message
Dear all,
http://www.eclipse.org/windowbuilder/download.php
Klicking on 4.5 Mars link, it appears just a white page. wherelse with the other versions everything is fine.
http://download.eclipse.org/windowbuilder/WB/release/R201506241200-1/4.5/
I've also tried to download, but also this doesn't function.
So what can I do, if I'm using the version 4.5.2 Java EE IDE of Eclipse?
Does the version Luna (4.4) of the window builder work as well?
Thanks and regards
Uwe
Re: Version for Mars 4.5.2 [message #1734401 is a reply to message #1734356] Tue, 07 June 2016 21:38 Go to previous messageGo to next message
That is an update site URL, not a download site URL.
Re: Version for Mars 4.5.2 [message #1734403 is a reply to message #1734401] Tue, 07 June 2016 23:23 Go to previous messageGo to next message
sorry, but I don't understand. The ohter versions don't have this problem.
Re: Version for Mars 4.5.2 [message #1734417 is a reply to message #1734403] Wed, 08 June 2016 03:55 Go to previous messageGo to next message
Hi Uwe,
I can't tell why this particular link shows a blank page while others not.
In any case these links are not made for being viewed into the browser, but to be copied and used into the IDE, via Help, Install New Software and pasted in "Work with" field.
HTH
Vincenzo
Re: Version for Mars 4.5.2 [message #1734439 is a reply to message #1734417] Wed, 08 June 2016 07:41 Go to previous message
There isn't a "problem" with the 4.5 link. The 4.5 link shows a blank page because the index.html file at that location is essentially empty. At some point, someone added content to the other index.html files. Those pages don't actually need to have any content as they are update site URLs meant to be used within the IDE and are not actual download pages with download links (as implied by the fact that they are in the column labeled "Update Site"). Actual downloadable update sites are available in the "Zipped Update Site" column.
Previous Topic:WindowBuilder Design view rendering issues
Next Topic:Custom property editor SWT
Current Time: Sun Aug 31 15:53:36 EDT 2025
Powered by FUDForum. Page generated in 0.03453 seconds
