| [Acceleo] Custom Acceleo metamodel [message #1734268] |
Mon, 06 June 2016 12:12  |
Hello, I'm new in Acceleo.
I try to make generator from my custom metamodel. I created it by Obeo Designer - it is ecore metamodel.
So I create new Acceleo Project, choose my metamodel URI (http://org/model/ros) from "Runtime version" and try to run it.
But project can't run and i get exception:
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://org/model/ros' not found. (file:/C:/Users/Jakub%20Kitaj/Downloads/ObeoDesigner-Community-8.1-win32.win32.x86/ObeoDesigner-Community/workspace/TestAcceleo/model/example.ros, 2, 120)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(XMLHandler.java:2625)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefix(XMLHandler.java:2458)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType(XMLHandler.java:1335)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XMLHandler.java:1504)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1026)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:78)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1008)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:719)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:190)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$ContentDriver.scanRootElementHook(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 6 more
I think i should set my custom metamodel but how can I do this?
| Re: [Acceleo] Custom Acceleo metamodel [message #1734648 is a reply to message #1734645] |
Fri, 10 June 2016 03:42   |
The generated "registerPackages" method is:
public void registerPackages(ResourceSet resourceSet) {
super.registerPackages(resourceSet);
* If you want to change the content of this method, do NOT forget to change the "@generated"
* tag in the Javadoc of this method to "@generated NOT". Without this new tag, any compilation
* of the Acceleo module with the main template that has caused the creation of this class will
* revert your modifications.
* If you need additional package registrations, you can register them here. The following line
* (in comment) is an example of the package registration for UML.
* You can use the method "isInWorkspace(Class c)" to check if the package that you are about to
* register is in the workspace.
* To register a package properly, please follow the following conventions:
* If the package is located in another plug-in, already installed in Eclipse. The following content should
* have been generated at the beginning of this method. Do not register the package using this mechanism if
* the metamodel is located in the workspace.
* if (!isInWorkspace(UMLPackage.class)) {
* // The normal package registration if your metamodel is in a plugin.
* resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
* If the package is located in another project in your workspace, the plugin containing the package has not
* been register by EMF and Acceleo should register it automatically. If you want to use the generator in
* stand alone, the regular registration (seen a couple lines before) is needed.
* To learn more about Package Registration, have a look at the Acceleo documentation (Help -> Help Contents).
I think, I should write something like:
but from can I get package class for my metamodel (like UMLPackage above) ?
Can you show your "registerPackages" method?
[Updated on: Fri, 10 June 2016 03:48] by Moderator
| Re: [Acceleo] Custom Acceleo metamodel [message #1736163 is a reply to message #1736094] |
Mon, 27 June 2016 04:21  |
Hi Jakub,
Please look at Viktoria's example, as well as those that are pre-generated for you in the java class beside your main template : what you need to "put" in the package registry is the instance of your metamodel's package.
You should have an ecore model you've created with the URI "http://org/model/ros" , and you have generated the code corresponding to that model. In that code, you have a class named "RosPackage" (or "XyzPackage", xyz being the name of your model's EPackage). what you need to pu in the "registerPackages" method is :
resourceSet.getPackageRegistry().put("http://org/model/ros", RosPackage.eINSTANCE);
You will need to have a dependency between the project that contains your acceleo templates and the project that contains your generated model code for this to work.
Laurent Goubet
Obeo
FUDForum. Page generated in 0.04776 seconds
