Home » Modeling » EMF » XMI idref reading error
XMI idref reading error [message #1734082] Fri, 03 June 2016 11:19 Go to next message
As I was upgrading my Ecore libraries, I got the following error when reading a file:
org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.eclipse.emf.ecore.xml.type.impl.AnyTypeImpl@5607ce2 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@3c2bbbf0 (name: Element) (instanceClassName: null) (abstract: false, interface: false)) (mixed: null, anyAttribute: [XMI_20131001:idref=SysML.package_packagedElement_Activities.stereotype_packagedElement_Continuous])' is not legal.
The relevant XMI content is the following:
<packagedElement xmi:id="SysML.package_packagedElement_Activities.stereotype_packagedElement_Continuous" xmi:uuid="org.omg.sysml.SysML.package_packagedElement_Activities.stereotype_packagedElement_Continuous" xmi:type="uml:Stereotype">
  <name>Continuous</name>
  <ownedComment xmi:id="SysML.package_packagedElement_Activities.stereotype_packagedElement_Continuous._ownedComment.0" xmi:uuid="org.omg.sysml.SysML.package_packagedElement_Activities.stereotype_packagedElement_Continuous._ownedComment.0" xmi:type="uml:Comment">
    <body>
    </body>
    <annotatedElement xmi:idref="SysML.package_packagedElement_Activities.stereotype_packagedElement_Continuous"/>
  </ownedComment>
I'm guessing I get this error because the type of the annotatedElement is UML Element, which is abstract, so a proxy can't be created. Now, I don't know why a proxy would be created since the actual element should have been created already.
My code was working with EMF (ecore+ecore.xmi) 2.11.0, meaning that element with idrefs didn't require a xmi:type to be read. The code doesn't work anymore in 2.11.1, so I'm suspecting http://git.eclipse.org/c/emf/org.eclipse.emf.git/commit/?h=R2_11_maintenance&id=da4f80486a37c34d9eae223dd38fa9ee873ca36d to have introduced the problem, but I don't know EMF well enough to say.
Is there a workaround that does not involve adding an xmi:type to all idrefs?
Thanks!
Re: XMI idref reading error [message #1734090 is a reply to message #1734082] Fri, 03 June 2016 12:53 Go to previous messageGo to next message
I'm not sure what models are involved, but better to ask on a forum
related to that specific technology. I.e., SysML or UML2 or whatever
this is supposed to represent.
On 03.06.2016 17:19, Raphael B wrote:
> Hello,
> reading a file:
> null, anyAttribute:
> is not legal.
> <packagedElement
> <ownedComment
> <body>
> </body>
> <annotatedElement
> </ownedComment>
> idrefs?
> Thanks!
Re: XMI idref reading error [message #1734093 is a reply to message #1734090] Fri, 03 June 2016 13:05 Go to previous messageGo to next message
Alright, I'll post on the UML2 forum then.
I thought the EMF forum would be a better place, since my issue is with upgrading ecore and ecore.xmi
Re: XMI idref reading error [message #1734116 is a reply to message #1734090] Sat, 04 June 2016 02:11 Go to previous messageGo to next message
This does appear to be an EMF problem, albeit a crazy one.
The problem does not appear to be new. I see it with EMF 2.11.0.
The user's snippet enables the source to be identified as
http://www.omg.org/spec/SysML/20150709/SysML.xmi.
The XMI is incredibly bloated and close to criminal. ID and UUID, with
element style IDREFs to maximize the character count for simple
attributes. It is doubtful that the UUIDs will be stable.
Using the debugger suggests that the problem is actually caused when
XMIHandler.createObject(EObject peekObject, EStructuralFeature feature)
passes the first four if's and goes to super.createObject. It would
appear that the case of an xmi:idref, !isContainment(), isMany(),
isResolveProxies() and an abstract feature type has not been encountered
before. The abstract feature causes a failure when an
org.eclipse.emf.ecore.xml.type.impl.AnyTypeImpl is added to the list.
Ed Willink
>> Hello,
>> reading a file:
>> is not legal.
>> <packagedElement
>> <ownedComment
>> <body>
>> </body>
>> <annotatedElement
>> </ownedComment>
>> idrefs?
>> Thanks!
Re: XMI idref reading error [message #1748541 is a reply to message #1734116] Thu, 24 November 2016 03:32 Go to previous messageGo to next message
I have the same problem. For instance, XMI exported by Enterprise Architect contains such constructs.
Is there any follow-up information about this problem? I didn't find a related bug ticket yet; should I create one?
Andreas
[Updated on: Thu, 24 November 2016 03:51] by Moderator
Re: XMI idref reading error [message #1748547 is a reply to message #1748541] Thu, 24 November 2016 04:55 Go to previous messageGo to next message
You'll find many messages regarding Enterprise Architect and RSA. They generally turn out to be incompatibilities in the use of obsolete UML versions. Eclipse UML2 supports UML 2.5 with some migration support for earlier versions but see https://wiki.eclipse.org/MDT/UML2/UML2_5.0_Migration_Guide and its predecessors if you are using non-trivial constructs.
Ed Willink
Re: XMI idref reading error [message #1748566 is a reply to message #1748541] Thu, 24 November 2016 09:00 Go to previous messageGo to next message
Andreas,
Have you tried reading your file with EMF 2.11.0?
I ended "fixing" my issue by not upgrading EMF.
Raphael
Re: XMI idref reading error [message #1748581 is a reply to message #1748547] Thu, 24 November 2016 12:25 Go to previous messageGo to next message
Hi Ed,
Thanks for the useful hint.
I was particularly wondering about the question posted above, i.e. XMI constructs such as
<ownedComment xmi:type="uml:Comment" xmi:id="xyz1" body="My comment">
    <annotatedElement xmi:idref="xyz2"/>
</ownedComment>
result in a org.eclipse.emf.ecore.xmi.IllegalValueException (as reported in the initial post of this thread). However, the XMI seems to be legal in terms of the XMI specification.
From the discussion above I understood that XMIHandler has not encountered yet the case of an xmi:idref, !isContainment(), isMany(), isResolveProxies() and an abstract feature type. So I was wondering if this should be filed as a bug.
Andreas
Re: XMI idref reading error [message #1748583 is a reply to message #1748566] Thu, 24 November 2016 12:40 Go to previous messageGo to next message
Raphael B wrote on Thu, 24 November 2016 14:00
Andreas,
Raphael
Hi Raphael,
Thanks for letting me know.
I think I'm constrained concerning the EMF version. At the moment I use a previous transformation step to remove those constructs as a temporary solution.
Andreas
Re: XMI idref reading error [message #1748584 is a reply to message #1748583] Thu, 24 November 2016 13:05 Go to previous messageGo to next message
If you can provide a simple repro, the bug can then be addressed.
Ed Willink
Re: XMI idref reading error [message #1748773 is a reply to message #1748584] Mon, 28 November 2016 09:18 Go to previous message
I've filed a bug including a minimal example
https://bugs.eclipse.org/bugs/show_bug.cgi?id=508297
Andreas
Previous Topic:The changeRecorder consolidateChanges does not seem to handle opposite features
Next Topic:Transforming a model instance to .e4xmi and .fxml
Current Time: Sat Jul 26 00:23:48 EDT 2025
Powered by FUDForum. Page generated in 0.28496 seconds
