Home » Modeling » EMF » [CDO] integrating uml profile in servers
[CDO] integrating uml profile in servers [message #1734024] Fri, 03 June 2016 03:10 Go to next message
Hi CDO community,
I am working with the CDO integration with papyrus. I am using a PostgreSQL server for the data base. I am using profiles. Profiles are declared on the CDO Client (through extension points). I am wondering if I could declare it on CDO Server and how?
Xavier
Re: [CDO] integrating uml profile in servers [message #1734041 is a reply to message #1734024] Fri, 03 June 2016 06:07 Go to previous messageGo to next message
Am 03.06.2016 um 09:10 schrieb Xavier Zeitoun:
> Hi CDO community,
> CDO Server and how?
Unfortunately I'm totally unexperienced with UML profiles. Maybe Thorsten (cc'ed) can share his experience with the
SysML profile...
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] integrating uml profile in servers [message #1734060 is a reply to message #1734041] Fri, 03 June 2016 08:09 Go to previous messageGo to next message
If it's a statically-generated profile, then it is deployed and
"registered" just as any Ecore package would be. The only difference
is the additional org.eclipse.uml2.uml.generated_package extension.
If it's a dynamic profile, then things get more dicey and I would have
to defer to Thorsten's experience. But I would recommend generating
the profile if it is under your control.
HTH,
Christian
>> Hi CDO community,
> Thorsten (cc'ed) can share his experience with the SysML profile...
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: [CDO] integrating uml profile in servers [message #1734075 is a reply to message #1734060] Fri, 03 June 2016 10:36 Go to previous message
I can only repeat Christians answer. We are only using static profiles and that works like a charm.
Thorsten
Previous Topic:Eclipse custom import wizard plugin
Next Topic:How to write xtext terminal rule for multi line string?
Current Time: Mon Jul 28 17:08:01 EDT 2025
Powered by FUDForum. Page generated in 0.03916 seconds
