Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Use STRING datatype with IEC61131 F_SEL block
Use STRING datatype with IEC61131 F_SEL block [message #1733888] Wed, 01 June 2016 16:36 Go to next message
I'd like to switch between two string constants, depending on a BOOL value. That's why the F_SEL block was my first guess. Both inputs are of datatype ANY so i thought i can connect a STRING there. When I try to enter the string constants directly in the F_SEL properties, the IDE tells me, that this is not allowed. Also connecting other FB with STRING outputs to the F_SEL does not work.
Is there any easy way to achieve this, without having to create my own F_SEL_STRING block and compile it into FORTE?
Herwig
Re: Use STRING datatype with IEC61131 F_SEL block [message #1733893 is a reply to message #1733888] Wed, 01 June 2016 17:36 Go to previous messageGo to next message
HI,
could you be more specific on the error message. You should be able to put string constants on F_SEL. However as it is an ANY input you have to add the type information to your constants following the IEC 61131-3 literal conventions. For strings this means that you have to add STRING# upfront (e.g, STRING#MYSTRingconstant).
Also connecting strings should work. Could you say more on what is not working there?
Alois
Re: Use STRING datatype with IEC61131 F_SEL block [message #1733912 is a reply to message #1733893] Thu, 02 June 2016 03:55 Go to previous messageGo to next message
Hi Alois,
thanks for your feedback. I did not use the STRING#, so this explains why i was not able to set the string constant in the F_SEL directly. I will try this on the weekend. When trying to connect the output of a CONCAT block with the F_SEL input I see a small prohibition sign and the wire is not connected and disappears when i release the mouse button.
greetings
Herwig
Re: Use STRING datatype with IEC61131 F_SEL block [message #1733936 is a reply to message #1733912] Thu, 02 June 2016 06:39 Go to previous messageGo to next message
Hi Herwig,
thanks for the clarification. The problem with the CONCAT block is that it has as in and outputs ANY_STRINGS which have to be typed as well. Unfortunately we are currently not very good in propagating the type through a network. So for now you would need to insert a STRING2STRING FB between CONCAT and F_SEL. I know this is ugly and I really want to have this gone.
The CONCAT function is maybe better used in algorithms there I think it will also be more efficient as the compiler can optimize away some overhead.
Alois
Re: Use STRING datatype with IEC61131 F_SEL block [message #1734136 is a reply to message #1733936] Sat, 04 June 2016 14:23 Go to previous messageGo to next message
Hi Alois,
the string constant STRING#MyString works now.
I cannot find a STRING2STRING block in the library, at least it is not part of the IEC61131-3 conversion blocks. I can find a STRING_TO_WSTRING converter
kind regards
Herwig
Re: Use STRING datatype with IEC61131 F_SEL block [message #1734185 is a reply to message #1734136] Sun, 05 June 2016 17:32 Go to previous messageGo to next message
STRING2STRING is in the conversion library (Edit: which is outside of the IEC 61131-3 lib).
Alois
[Updated on: Sun, 05 June 2016 17:32] by Moderator
Re: Use STRING datatype with IEC61131 F_SEL block [message #1734284 is a reply to message #1734185] Mon, 06 June 2016 14:18 Go to previous message
Thanks, Alois
it's working now, I overlooked the "convert" folder in the type library Embarrassed and only searched within the IEC61131-3 converters.
The STRING2STRING after the F_SEL did the trick.
greetings
Herwig
Previous Topic:SubApp Error
Next Topic:BeagleBoard-X15
Current Time: Thu Jul 24 00:40:07 EDT 2025
Powered by FUDForum. Page generated in 0.04200 seconds
