| Home » Archived » Eclipse Communications Framework (ECF) » ECF r-osgi : NPEs in proxies during startup
 Goto Forum:|
| ECF r-osgi : NPEs in proxies during startup [message #1732833] | Fri, 20 May 2016 10:54  |  |
| Eclipse User  |  |  |  |  | When using the r_osgi provider (3.5.300.v20160405-1820), we always get NPEs from inside the generated proxies when starting the consumer application.
 And then some time later the proxy gets in order.
 Does this ring a bell for someone?
 thanks!
 erwin & yannick
 Some detailed info :
 We have a service that implements 2 interfaces : an IRestService and an IDataSourceService. In the DS config we try to only export the IDataSourceService interface :
<scr:component xmlns:scr="http://www.osgi.org/xmlns/scr/v1.1.0" immediate="true" name="DataSourceService">
   <implementation class="com.isencia.passerelle.edm.datasource.service.impl.DataSourceService"/>
   <service>
      <provide interface="com.isencia.sherpa.rs.IRestService"/>
      <provide interface="com.isencia.passerelle.edm.datasource.service.IDataSourceService"/>
   </service>
   <property name="service.exported.interfaces" type="String" value="com.isencia.passerelle.edm.datasource.service.IDataSourceService"/>
   <property name="service.exported.configs" type="String" value="ecf.r_osgi.peer"/>
</scr:component>
 This seems to be picked up correctly for the r_osgi bundle :
osgi>services (objectClass="com.isencia.passerelle.edm.datasource.service.IDataSourceService")
{com.isencia.sherpa.rs.IRestService, com.isencia.passerelle.edm.datasource.service.IDataSourceService}={component.name=DataSourceService, component.id=58, service.exported.configs=ecf.r_osgi.peer, service.exported.interfaces=com.isencia.passerelle.edm.datasource.service.IDataSourceService, service.id=126}
  "Registered by bundle:" com.isencia.passerelle.edm.datasource.service.impl_3.0.5.qualifier [189]
  "Bundles using service"
    com.isencia.sherpa.rs_6.12.4.qualifier [71]
    org.eclipse.ecf.osgi.services.remoteserviceadmin_4.4.0.v20160405-1820 [123]
    org.eclipse.ecf.provider.r_osgi_3.5.300.v20160405-1820 [74]
{com.isencia.passerelle.edm.datasource.service.IDataSourceService}={component.name=DataSourceService, ecf.rsvc.id=155, ecf.rsvc.ranking=0, service.remote.registration=true, ecf.rsvc.cid=r-osgi://Yannick-PC:9278, ecf.robjectClass=[com.isencia.passerelle.edm.datasource.service.IDataSourceService], component.id=58, service.id=155}
    ch.ethz.iks.r_osgi.remote_1.0.5.RC1_v20160405-1820 [182]
 But during the startup we get NPEs in generated proxies for both interfaces :
 !SESSION 2016-05-12 10:24:53.779 -----------------------------------------------
 eclipse.buildId=unknown
 java.version=1.7.0_79
 BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_GB
 Framework arguments:  -product com.isencia.passerelle.edm.datasource.consumer.product
 Command-line arguments:  -product com.isencia.passerelle.edm.datasource.consumer.product -data C:\Users\visyan\workspace-passerelle-edm/../runtime-datasourceservice.consumer.ecf.local.product -dev file:C:/Users/visyan/workspace-passerelle-edm/.metadata/.plugins/org.eclipse.pde.core/datasourceservice.consumer.ecf.local.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog -console
 !ENTRY R-OSGi Proxy Bundle generated for Endpoint r-osgi://169.254.254.194:9278#218 4 0 2016-05-12 10:24:54.437
 !MESSAGE FrameworkEvent ERROR
 !STACK 0
 org.osgi.framework.BundleException: Exception in proxy.bgjocfeocfeobje_jchicbi.com.isencia.sherpa.rs.IRestServiceImpl.start() of bundle R-OSGi Proxy Bundle generated for Endpoint r-osgi://169.254.254.194:9278#218.
 at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
 at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
 at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
 at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
 at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176)
 at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
 at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
 at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
 at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
 at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
 at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
 at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
 at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
 Caused by: java.lang.NullPointerException: A null service reference is not allowed.
 at org.eclipse.osgi.framework.internal.core.BundleContextImpl.getService(BundleContextImpl.java:586)
 at proxy.bgjocfeocfeobje_jchicbi.com.isencia.sherpa.rs.IRestServiceImpl.start(Unknown Source)
 at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
 at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
 ... 12 more
 Root exception:
 !ENTRY R-OSGi Proxy Bundle generated for Endpoint r-osgi://YANNICK-PC:9278#218 4 0 2016-05-12 10:24:54.440
 !STACK 0
 org.osgi.framework.BundleException: Exception in proxy.YANNICK_PC_jchicbi.com.isencia.passerelle.edm.datasource.service.IDataSourceServiceImpl.start() of bundle R-OSGi Proxy Bundle generated for Endpoint r-osgi://YANNICK-PC:9278#218.
 at proxy.YANNICK_PC_jchicbi.com.isencia.passerelle.edm.datasource.service.IDataSourceServiceImpl.start(Unknown Source)
 ... 12 more
 Root exception:
 WARNING: Port 9278 already in use. This instance of R-OSGi is running on port 9279
 !ENTRY org.eclipse.equinox.ds 4 0 2016-05-12 10:24:55.186
 !MESSAGE Could not bind a reference of component com.isencia.passerelle.edm.datasource.consumer. The reference is: Reference[name = IDataSourceService, interface = com.isencia.passerelle.edm.datasource.service.IDataSourceService, policy = dynamic, cardinality = 0..n, target = null, bind = bindDataSourceService, unbind = null]
 !ENTRY org.eclipse.equinox.ds 4 0 2016-05-12 10:24:55.188
 And then, after a minute or two, our consumer can start using the proxy after all to start pushing data (which is the thing our service allows) :
osgi> 2016-05-12 10:26:41 INFO  DataSourceServiceComponent:27 - Got proxy IDataSourceService=proxy.Yannick_PC_jchibff.com.isencia.passerelle.edm.datasource.service.IDataSourceServiceImpl@5abcfadd
2016-05-12 10:26:41 INFO  DataSourceServiceComponent:29 - Starting remote call via proxy...
2016-05-12 10:26:41 INFO  DataSourceServiceComponent:44 - Published value1: 72
| Re: ECF r-osgi : NPEs in proxies during startup [message #1732840 is a reply to message #1732833] | Fri, 20 May 2016 11:57   |  |
| Eclipse User  |  |  |  |  | Hi Erwin and Yannick,
 erwin de ley wrote on Fri, 20 May 2016 10:54
 It might.   The r-OSGi provider needs to clean up (remove) the bundles that it creates to hold the proxy impl, and it only gets to do that if the client is shutdown normally (i.e. doesn't crash and doesn't get terminated via Eclipse debugger).   I/we have seen cases like this when the previous client session is terminated abnormally, meaning that the previous rosgi proxy bundles are still present, but are irrelevant and nonstartable (NPE on next launch).   This doesn't generally prevent the discovery and use of the new proxy (which I think is happening for you after a while).
 If you shutdown the consumer normally (i.e. 'shutdown' at osgi console) then these NPEs shouldn't occur.   And it has been harmless (except for the ominous log entries) in other cases.
 If a normal shutdown does *not* fix this issue, please open a bug and I'll look into it immediately.
 If discovery is taking minutes...what discovery provider are you using?   If desired, chances are this time delay could be reduced.
 Thanks.  Scott
 [Updated on: Fri, 20 May 2016 05:23] by Moderator |  |  |  |  |  |  |
| Re: ECF r-osgi : NPEs in proxies during startup [message #1733461 is a reply to message #1733303] | Fri, 27 May 2016 13:08   |  |
| Eclipse User  |  |  |  |  | Yannick De Visscher wrote on Wed, 25 May 2016 23:02 Hi Scott,
 Even on the first startup and also after a clean osgi exit, the NPEs are thrown.
 We are using org.eclipse.ecf.provider.r_osgi (3.5.300.v20160405-1820).
 This is my launcher config
 <code deleted>
 Where can I open a bug?
 Hi Yannick.   Best to open a bug here:   https://bugs.eclipse.org/bugs/enter_bug.cgi?product=ECF
 Probably best to select ecf.providers as the component, and put '[r-OSGi] <subject>' in the subject line...for example:  [r-OSGi] non-fatal NPE in proxy creation
 Just so I'm clear on what's happening:  The desired proxy is eventually created, injected, and used successfully, right?   It just takes longer than you would expect, and is preceeded by the NPEs in log?
 If you don't mind it would be diagnostic if you could try to reproduce under two other conditions:
 1) Export via another provider...e.g. ecf.generic.server and see if a similar things happens.  I'm expecting not, but it would be helpful to eliminate this possibility
 2) Try exporting with only one interface (the one you consume)
 If you like I can help with this if you are willing to give me temporary access to your code.   My direct email is slewis at composent.com
 Scott
| Re: ECF r-osgi : NPEs in proxies during startup [message #1734402 is a reply to message #1734228] | Tue, 07 June 2016 22:26  |  |
| Eclipse User  |  |  |  |  | Yannick De Visscher wrote on Mon, 06 June 2016 08:39 Hi Scott,
 Sorry for the delay.
 Bug posted at: https://bugs.eclipse.org/bugs/show_bug.cgi?id=495535
 The desired proxy is indeed created, injected and used. It takes about 20 seconds before the proxy is available, that's not such a big deal for us.
 We were already exporting only one interface (IDataSourceService), the other one isn't even in the classpath of the consumer application.
 This is indeed very strange.
 I've tried using the generic server, but I can't seem to get it to work with this one...
 It should be a matter of changing the service.exported.configs service property to
 service.exported.configs="ecf.generic.server"
 If there is something else going on please do let me know as I've not seen these problems before.
 Access to the code won't be possible because it's part of quite a big project.
 If I have the time I might try to reproduce this issue with some ecf example classes.
 Ok...that would be great, as I currently cannot reproduce, and it's going to be next to impossible to fix without being able to first reproduce.
 What might work is if you can reproduce with using two interface classes (e.g. IRestService IDataSourceService) with some similar-but-not-same method signatures...with only trivial implementations.
 One other thing to check that I just thought of.   What are you doing WRT discovery?  (e.g. a discovery protocol like jmsdns/zeroconf, jslp, one of the other discovery providers, or edef-etc.   Sorry if I already asked this...you should probably answer on the bug you created (thanks for doing that by the way)
 Current Time: Fri Oct 31 18:36:24 EDT 2025
 Powered by FUDForum . Page generated in 0.12326 seconds |
