Home » Archived » BIRT » Change report title property value at runtime
Change report title property value at runtime [message #933588] Fri, 05 October 2012 02:29 Go to next message
Hi all,
How do I dynamically change the Title propery of my report at runtime?
I use reportContext.getReportRunnable().getProperty("title"); on my master page in my library to show my report title
It's worked fine so far because all my report titles have been constants
But I have one report now where I want a parameter value included in the report name
I've tried using
reportContext.getReportRunnable().setProperty("title") = "whatever";
and various other things but no success. The title shown when previewing the report is still the constant 'title' i've set on the General tab
And an unhandled exception error when viewing in browser
The following items have errors:
ReportDesign (id = 1):
+ Unhandled exception when executing script.
Re: Change report title property value at runtime [message #934157 is a reply to message #933588] Fri, 05 October 2012 14:07 Go to previous messageGo to next message
try:
reportContext.getDesignHandle().setProperty("title", "mytitle");
Jason
Re: Change report title property value at runtime [message #937448 is a reply to message #934157] Mon, 08 October 2012 21:20 Go to previous messageGo to next message
Thanks again jason,
That mostly works. The master page picks up the correct title to display, but the menu bar of the browser still shows the initial version of the title.
Is there any way to modify that as well or does that get set prior to any code on the report being executed?
Cheers
Re: Change report title property value at runtime [message #938271 is a reply to message #937448] Tue, 09 October 2012 14:24 Go to previous messageGo to next message
I believe the reason this happens is because the title is read from the design by the viewer before it runs the report. The only way I know to work around this is to modify the viewer to add an id to the title tag and then add a Text element with client side script, to the report that locates the title element by this id and then use it to change on the fly.
<script>
document.getElementById("mytitle").value=<VALUE_OF>reportContext.getDesignHandle().getProperty("title");</VALUE-OF>;
</script>
Jason
Re: Change report title property value at runtime [message #1733263 is a reply to message #938271] Wed, 25 May 2016 16:44 Go to previous message
Hi, I am trying to update the report name with report parameters and schedule the job. Do you have a sample report with the above conditions?
Previous Topic:Oracle Stored Procedure Query type Dataset loads huge metadata
Next Topic:How i call stored procedure before the execution of report ?
Current Time: Sun Jul 27 03:52:33 EDT 2025
Powered by FUDForum. Page generated in 0.05039 seconds
