Home » Archived » Eclipse SmartHome » Channel Configuration through UI
Channel Configuration through UI [message #1719532] Fri, 08 January 2016 11:45 Go to next message
Is it planned that PaperUI will support the configuration of Channels as well.
Meaning that besides enabling/disabling a channel it can also edit the Channel configurable options?
Or alternatively will habmin allowing this in the near term?
Or alternatively, is there a way that via commandline this is supported?
[Updated on: Fri, 08 January 2016 11:49] by Moderator
Re: Channel Configuration through UI [message #1719563 is a reply to message #1719532] Fri, 08 January 2016 16:20 Go to previous messageGo to next message
Planned yes, but not yet in any concrete planning phase. Feel free to create an issue for it - and if you have good ideas how the UI should look like for this feature, it would be even better Smile
Re: Channel Configuration through UI [message #1719572 is a reply to message #1719563] Fri, 08 January 2016 18:28 Go to previous messageGo to next message
Okay, thanks made the issue for it.
Re: Channel Configuration through UI [message #1733231 is a reply to message #1719532] Wed, 25 May 2016 11:01 Go to previous messageGo to next message
I need a bit of help with this feature.
I see that it is implemented already - https://github.com/eclipse/smarthome/pull/1404, but can not see it working.
It can help, If you tell me, in which binding the channel configuration from the Paper UI is working. Smile
In my case, all bundles are up to date with the latest updates.
I have a channel:
<channel-type id="networkName">
		<item-type>String</item-type>
		<label>Network name</label>
		<description>The name of the network.</description>
		<state readOnly="true" pattern="%s " />
		<config-description-ref uri="systeminfo:channels:lowpriority" />
</channel-type>
and configuration file
<config-description uri="systeminfo:channels:lowpriority">
		<parameter name="priority" type="text">
			<label>Interval</label>
			<description>Refresh interval in seconds.</description>
			<options>
				<option value="High">High</option>
				<option value="Medium">Medium</option>
				<option value="Low">Low</option>
			</options>
			<default>Low</default>
		</parameter>
		<parameter name="pid" type="integer" min="-1" step="1">
			<label>PID</label>
			<description>The PID of the process. It is only used for channels from group 'process'.</description>
			<default>-1</default>
			<advanced>true</advanced>
		</parameter>
</config-description>
and a call to http://localhost:8080/rest/channel-types returns
....{"parameters":[{"defaultValue":"Low","description":"Refresh interval in seconds.","label":"Interval","name":"priority","required":false,"type":"TEXT","readOnly":false,"multiple":false,"advanced":false,"limitToOptions":true,"options":[{"label":"High","value":"High"},{"label":"Medium","value":"Medium"},{"label":"Low","value":"Low"}],"filterCriteria":[]},{"defaultValue":"-1","description":"The PID of the process. It is only used for channels from group \u0027process\u0027.","label":"PID","name":"pid","required":false,"type":"INTEGER","min":-1,"stepsize":1,"readOnly":false,"multiple":false,"advanced":true,"limitToOptions":false,"options":[],"filterCriteria":[]}],"parameterGroups":[],"description":"The name of the network.","label":"Network name","stateDescription":{"pattern":"%s ","readOnly":true,"options":[]},"tags":[],"UID":"systeminfo:networkName"}
but in the Paper UI the button is missing
<div class="actions">
	<!-- ngIf: getChannelFromChannelTypes(channel.channelTypeUID).parameters && getChannelFromChannelTypes(channel.channelTypeUID).parameters.length > 0 -->
</div>
Any hints, ideas ?
Re: Channel Configuration through UI [message #1733257 is a reply to message #1733231] Wed, 25 May 2016 14:57 Go to previous messageGo to next message
I have not yet seen this working in paperUI.
If you have OH, you can edit channel config through Habmin2 inferface.
https://github.com/cdjackson/HABmin2
Re: Channel Configuration through UI [message #1733288 is a reply to message #1733257] Thu, 26 May 2016 04:23 Go to previous messageGo to next message
I am not aware of any existing binding that uses channel configuration yet, but I had seen the feature working. I'll ask Aoun for help on analyzing why it isn't working for you.
Re: Channel Configuration through UI [message #1733311 is a reply to message #1733257] Thu, 26 May 2016 07:54 Go to previous messageGo to next message
Marcel Verpaalen wrote on Wed, 25 May 2016 18:57
thanks, it will be ok for now to use Habmin2 Smile
Re: Channel Configuration through UI [message #1733320 is a reply to message #1733311] Thu, 26 May 2016 09:18 Go to previous messageGo to next message
Yes, it seems to have been broken due to https://github.com/eclipse/smarthome/pull/1288. I just created a pull request that should fix this issue (https://github.com/eclipse/smarthome/pull/1570).
Re: Channel Configuration through UI [message #1733335 is a reply to message #1733320] Thu, 26 May 2016 03:07 Go to previous messageGo to next message
Syed Aoun Haider Bukhari wrote on Thu, 26 May 2016 13:18
thank you
Re: Channel Configuration through UI [message #1733362 is a reply to message #1733288] Thu, 26 May 2016 16:46 Go to previous message
Kai Kreuzer wrote on Thu, 26 May 2016 10:23
Think zwave uses this possibility in some cases
Thanks Aoun for fixing this so quick
Previous Topic:Allow channels without item type
Next Topic:Creating Things from a DiscoveryResult
Current Time: Sat Jul 26 11:48:11 EDT 2025
Powered by FUDForum. Page generated in 0.10366 seconds
