Home » Archived » Sapphire » Access xml file-path from PossibleValuesService or ListPropertyBinding implementation
Access xml file-path from PossibleValuesService or ListPropertyBinding implementation [message #1733116] Tue, 24 May 2016 02:32 Go to next message
Hi guys!
how can I get the path of the xml-file the Sapphire GUI is displaying from a PossibleValuesService or ListPropertyBinding implementation?
In either cases I need to consider the content of other files that reside on the same path as the currently open xml-file.
For EL-Function implementations a reference to the open xml-file can be easily obtained by casting the root-parent of the FunctionContext to a SapphireEditorForXml and then calling getEditorInput().
Kind regards, reinhart
Re: Access xml file-path from PossibleValuesService or ListPropertyBinding implementation [message #1733136 is a reply to message #1733116] Tue, 24 May 2016 12:58 Go to previous messageGo to next message
Any place you have access to an Element from you model, you can call element.adapt( IFile.class ). To get Element from within a Service, call context( Element.class ). To get Element from within PropertyBinding, call property().element().
[Updated on: Tue, 24 May 2016 12:59] by Moderator
Re: Access xml file-path from PossibleValuesService or ListPropertyBinding implementation [message #1733814 is a reply to message #1733136] Wed, 01 June 2016 03:29 Go to previous messageGo to next message
Thank you Konstantin! Are these kind of features documented anywhere else but in the Source-Code?
[Updated on: Wed, 01 June 2016 08:10] by Moderator
Re: Access xml file-path from PossibleValuesService or ListPropertyBinding implementation [message #1733874 is a reply to message #1733814] Wed, 01 June 2016 12:32 Go to previous message
There are some API articles in the sapphire.doc plugin (Sapphire Developer Guide under Help), but most API documentation is in the form of javadoc. If javadoc for a particular method or class is lacking sufficient detail, please open a bug report.
[Updated on: Wed, 01 June 2016 12:33] by Moderator
Previous Topic:generate sdef
Next Topic:show/hide outline elements during runtime
Current Time: Tue Oct 28 12:54:56 EDT 2025
Powered by FUDForum. Page generated in 0.75860 seconds
