Home » Eclipse Projects » GEF » [GEF4] GEF4/Zest graph in an SWT Composite?
[GEF4] GEF4/Zest graph in an SWT Composite? [message #1733123] Tue, 24 May 2016 10:53
I'm trying to migrate from GEF/Zest to GEF4/Zest in a profiling graph plugin. Our application consist of the Eclipse IDE workbench plus a bunch of external and own plugins, in particular a profiling graph viewer.
We have recently migrated the application to Eclipse Mars, and so it uses the E3 APIs via the compatibility mode.
So now I want to replace the old content of the profiling graph display, with a new graph built with GEF4/Zest.
My current headache is how to connect a GEF4/Zest graph to an SWT Composite to draw/paint in.
With the GEF/Zest api one can pass a (SWT) composite for the graph to be displayed in:
org.eclipse.zest.core.widgets.Graph.Graph(Composite parent, int style)
But how does one make a similar connection with the GEF4 apis?
Thanks in advance,
Thomas
Re: [GEF4] GEF4/Zest graph in an SWT Composite? [message #1733128 is a reply to message #1733123] Tue, 24 May 2016 04:55 Go to previous message
On the level of controls, the integration between JavaFX and SWT is performed via an FXCanvasEx. As GEF4 Zest.FX is based on GEF4 MVC.FX, it re-uses its Eclipse UI integration on the viewer level. You might want to take a look into AbstractFXView (ZestFXUiView specializes it) to see (within createPartControl(Composite) and hookViewers()) how the InfiniteCanvas control of the Zest.FX/MVC.FX viewer is hooked into the Composite. Most easily, you can directly extend ZestFxUiView (and then only have to take care of providing an input Graph).
Previous Topic:Undo/Redo model property
Next Topic:Problem with hover feedback geometry with GEF4.0.0RC2
Current Time: Sat Jul 26 21:58:27 EDT 2025
Powered by FUDForum. Page generated in 0.05973 seconds
