Home » Eclipse Projects » Gemini » java.lang.IllegalArgumentException while stopping my bundle(java.lang.IllegalArgumentException while stopping my bundle)
java.lang.IllegalArgumentException while stopping my bundle [message #1733011] |
Mon, 23 May 2016 12:58  |
I can't give much information, because I don't know what the problem is.
This is the bundles I install:
+ my bundle
This is the exception I get:
ERROR: Bundle mybundle [57] EventDispatcher: Error during dispatch. (java.lang.IllegalArgumentException)
at org.apache.felix.framework.BundleContextImpl$ServiceObjectsImpl.ungetService(BundleContextImpl.java:584)
at org.ops4j.pax.cdi.extension.impl.compat.Osgi6ServiceObjectsWrapper.ungetService(Osgi6ServiceObjectsWrapper.java:45)
at org.ops4j.pax.cdi.extension.impl.ServiceEventBridge.serviceChanged(ServiceEventBridge.java:75)
at org.apache.felix.framework.util.EventDispatcher.invokeServiceListenerCallback(EventDispatcher.java:991)
at org.apache.felix.framework.util.EventDispatcher.fireEventImmediately(EventDispatcher.java:839)
at org.apache.felix.framework.util.EventDispatcher.fireServiceEvent(EventDispatcher.java:546)
at org.apache.felix.framework.Felix.fireServiceEvent(Felix.java:4557)
at org.apache.felix.framework.Felix.access$000(Felix.java:106)
at org.apache.felix.framework.Felix$1.serviceChanged(Felix.java:420)
at org.apache.felix.framework.ServiceRegistry.unregisterService(ServiceRegistry.java:170)
at org.apache.felix.framework.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.java:144)
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:883)
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:857)
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:140)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.unregisterService(AbstractComponentManager.java:925)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.doDeactivate(AbstractComponentManager.java:774)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.deactivateInternal(AbstractComponentManager.java:757)
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.removedService(DependencyManager.java:1014)
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.removedService(DependencyManager.java:915)
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1241)
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1136)
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.untrack(ServiceTracker.java:996)
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1175)
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:120)
at org.eclipse.gemini.jpa.ServicesUtil.unregisterEMFService(ServicesUtil.java:327)
at org.eclipse.gemini.jpa.ServicesUtil.unregisterEMFServices(ServicesUtil.java:165)
at org.eclipse.gemini.jpa.GeminiManager.unregisterPersistenceUnits(GeminiManager.java:281)
at org.eclipse.gemini.jpa.PersistenceBundleExtender.unregisterPersistenceUnitsInBundle(PersistenceBundleExtender.java:321)
at org.eclipse.gemini.jpa.PersistenceBundleExtender.bundleChanged(PersistenceBundleExtender.java:413)
at org.apache.felix.framework.util.EventDispatcher.invokeBundleListenerCallback(EventDispatcher.java:916)
at org.apache.felix.framework.util.EventDispatcher.fireEventImmediately(EventDispatcher.java:835)
at org.apache.felix.framework.util.EventDispatcher.fireBundleEvent(EventDispatcher.java:517)
at org.apache.felix.framework.Felix.fireBundleEvent(Felix.java:4541)
at org.apache.felix.framework.Felix.stopBundle(Felix.java:2600)
at org.apache.felix.framework.Felix.setActiveStartLevel(Felix.java:1389)
at org.apache.felix.framework.FrameworkStartLevelImpl.run(FrameworkStartLevelImpl.java:308)
at java.lang.Thread.run(Thread.java:745)
Is the problem in gemini service?
Re: java.lang.IllegalArgumentException while stopping my bundle [message #1733475 is a reply to message #1733286] |
Fri, 27 May 2016 19:38  |
Hi Pavel,
That basically just points to the problem being due to timing issues. I am not familiar with pax cdi or using it with Gemini JPA. If nobody else has any experience with this then you will just need to try to isolate the problem on your own. One thing I can say is that sometimes the weaving that Gemini JPA does, and the bundle restarts that result from that, can cause some other bundles to get thrown off. To see if that is the problem try doing static weaving (see Gemini JPA doc for how to do that).
-Mike
Current Time: Sun Jul 20 23:18:43 EDT 2025
Powered by FUDForum. Page generated in 0.06228 seconds
