Home » Eclipse Projects » Eclipse 4 » Visibility of new editor part
Visibility of new editor part [message #1732835] Fri, 20 May 2016 11:13 Go to next message
I have a part descriptor for an editor which extends jface TextEditor
In my OpenHandler I do
@Execute
	public void execute(Shell shell){
		FileDialog dialog = new FileDialog(shell);
		String fileName = dialog.open();
		if (fileName.endsWith(".lxml")) {
			MPart part = partService.createPart("uk.co.xbundle.scopist.application.partdescriptor.lxmleditor");
			part.setLabel(fileName);
			MPartStack editorStack = (MPartStack) modelService.find("uk.co.xbundle.scopist.application.partstack.editors", app);
			editorStack.getChildren().add(part);
			partService.showPart(part, PartState.ACTIVATE);
The editor initializes via its constructor, the tab panel appears, but the editor is not visible within the tab.
Any ideas as to why this should be?
Robert
Re: Visibility of new editor part [message #1732856 is a reply to message #1732835] Sat, 21 May 2016 02:23 Go to previous message
Have you tried to debug to see if the initialization code is called?
Re: Visibility of new editor part [message #1732869 is a reply to message #1732856] Fri, 20 May 2016 22:13 Go to previous message
Thanks Dirk
Yes, initialization was fine
I hadn't set the input of the TextEditor using TextEditor.setEditorInput(IEditorInput input)
Previous Topic:Open file with e3.x editor in e4 application
Next Topic:Editor area
Current Time: Mon Jul 21 03:47:31 EDT 2025
Powered by FUDForum. Page generated in 0.26234 seconds
