Home » Modeling » Papyrus » [CDO] Using the Papyrus editor on a CDOResource within a transaction
[CDO] Using the Papyrus editor on a CDOResource within a transaction [message #1732716] Thu, 19 May 2016 09:19 Go to next message
Dear all,
I use a CDO repository to store my Papyrus model. I can properly open and use the Papyrus editor on an Online Transactional Checkout folder in my project explorer. The editor, however, crashes when I try to open it on the same di file but within an explicit transaction. The exception I receive is
java.lang.ClassCastException: org.eclipse.emf.cdo.internal.ui.CDOLobEditorInput cannot be cast to org.eclipse.ui.IURIEditorInput
	at org.eclipse.papyrus.infra.core.editor.CoreMultiDiagramEditor.loadModelAndServices(CoreMultiDiagramEditor.java:603)
	at org.eclipse.papyrus.infra.core.editor.CoreMultiDiagramEditor.initContents(CoreMultiDiagramEditor.java:921)
	at org.eclipse.papyrus.infra.core.editor.CoreMultiDiagramEditor.init(CoreMultiDiagramEditor.java:489)
	at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:361)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:319)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:898)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:879)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:121)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:345)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:264)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:104)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:73)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:55)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:971)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:640)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:746)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:717)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:711)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:695)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$1.handleEvent(PartServiceImpl.java:99)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:186)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4761)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:85)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:59)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:572)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:536)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:724)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:396)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1166)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3252)
	at org.eclipse.ui.internal.WorkbenchPage.access$25(WorkbenchPage.java:3167)
	at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:3149)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3144)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3108)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3089)
	at org.eclipse.emf.cdo.ui.CDOEditorUtil$2.run(CDOEditorUtil.java:395)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4155)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3772)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:694)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:606)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
Do you have any idea about what I am doing wrong?
Best regards
Stephan
Re: [CDO] Using the Papyrus editor on a CDOResource within a transaction [message #1732750 is a reply to message #1732716] Thu, 19 May 2016 17:01 Go to previous messageGo to next message
Hi, Stephan,
Are you using the Papyrus "extras" component that provides the Papyrus
connector for CDO repositories? It doesn't store Papyrus models as XMI
resources in CLOBs but rather using CDO's normal object-database
mapping.
If you are rolling your own CDO repository persistence solution, then I
probably won't know how to help.
Christian
On 2016-05-19 13:19:47 +0000, Stephan Seifermann said:
> Dear all,
> at
> at
> at
> at
> at
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at java.lang.reflect.Method.invoke(Method.java:498)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> at
> at
> at
> at
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> at
> at
> at
> at
> Best regards
> Stephan
Re: [CDO] Using the Papyrus editor on a CDOResource within a transaction [message #1732804 is a reply to message #1732750] Thu, 19 May 2016 23:34 Go to previous messageGo to next message
Hello Christian,
I installed the extra plugin:
Papyrus CDO Integration (Incubation) 1.1.4.201602101324 org.eclipse.papyrus.extra.cdo.feature.feature.group
The way I want to open the editor is shown in the attachment (papyrus_session.png). This results in the mentioned exception. When using the transactional checkout (papyrus_checkout.png) the editor is started without any problem. I would assume both ways to work as the UI provides the ability to open the Papyrus editor in the given contexts.
So, is this a bug or did I miss something important?
Best regards
Stephan
Re: [CDO] Using the Papyrus editor on a CDOResource within a transaction [message #1733143 is a reply to message #1732804] Tue, 24 May 2016 14:02 Go to previous messageGo to next message
Hi, Stephan,
I know that work was contributed in Mars that moved the principal user
interface for Papyrus models in CDO from the on-line transactional
paradigm to a workspace check-out paradigm. As I understand it,
checkouts are supposed to offer significant benefits over the on-line
transactional method and are the direction that CDO intends to focus on
in general (at least as far as UI integration in the Eclipse Workbench
is concerned). I don't recall any specific changes that would have
broken the on-line transactional method, but I think there are some
APIs now that expect to be working with CDO checkouts that didn't
previously. Hopefully Eike can chime in with clarifications and
corrections of my fuzzy understanding.
You can find some information about the Papyrus changes in this CDO
integration on the wiki:
https://wiki.eclipse.org/Papyrus/Mars_Work_Description/Improvments/Improve_CDO_integration_within_Papyrus
That's about the extent of what I know about it.
HTH,
Christian
On 2016-05-20 03:34:51 +0000, Stephan Seifermann said:
> Hello Christian,
> Best regards
> Stephan
> <image>
> <image>
Re: [CDO] Using the Papyrus editor on a CDOResource within a transaction [message #1733321 is a reply to message #1733143] Thu, 26 May 2016 02:21 Go to previous message
Hello Christian,
thanks for your answer. You are right, both paradigms that use checkouts work. My use case, however, was to not checkout the repository but directly edit the resources in a transaction. There seems to be a difference in the editor input given to Papyrus in these two scenarios.
The pointer you sent to me does not mention the sessions view that I use. Therefore, I think this is simply not supported and most probably not necessary in most use cases. I will just use the checkouts to edit the resources.
Best regards
Stephan
Previous Topic:Export Embedded UTP file
Next Topic:Inhereting the ports of a block from its IBD
Current Time: Sat Jul 26 03:38:30 EDT 2025
Powered by FUDForum. Page generated in 0.04358 seconds
