Home » Eclipse Projects » Eclipse 4 » Eclipse IDE blocks on startup (no response)
Eclipse IDE blocks on startup (no response) [message #1732690] Wed, 18 May 2016 22:04 Go to next message
It seems I have somehow killed my workspace. When I open Eclipse (Mars.2) it starts out fine. Then the Job "Setup check" kicks in. After this I cannot use the application anymore: It is blocked. So I also can't stop any running jobs.
index.php/fa/25956/0/
I am working on Windows using JDK 1.8.0_66.
Has anybody seen this before? Is there something I can do to repair my workspace? It's a bitch to setup and I don't really want to do that again Sad.
Any tips are highly appreciated!
Christoph
Re: Eclipse IDE blocks on startup (no response) [message #1732692 is a reply to message #1732690] Thu, 19 May 2016 05:14 Go to previous messageGo to next message
This is the workspace log:
!ENTRY org.eclipse.epp.logging.aeri.ide 2 16 2016-05-19 11:11:27.142
!MESSAGE Server 'org.eclipse.epp.logging.aeri.ide.server' failed with exception: Connect to dev.eclipse.org:443 [dev.eclipse.org/198.41.30.200] failed: Connection refused: connect. ; version: 1.100.0.v20160217-0435
!STACK 0
org.apache.http.conn.HttpHostConnectException: Connect to dev.eclipse.org:443 [dev.eclipse.org/198.41.30.200] failed: Connection refused: connect
	at org.apache.http.impl.conn.HttpClientConnectionOperator.connect(HttpClientConnectionOperator.java:142)
	at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:319)
	at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:363)
	at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:219)
	at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:195)
	at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:86)
	at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:108)
	at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:184)
	at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82)
	at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:57)
	at org.apache.http.client.fluent.Executor.execute(Executor.java:206)
	at org.eclipse.epp.internal.logging.aeri.ide.server.mars.IO.request(IO.java:205)
	at org.eclipse.epp.internal.logging.aeri.ide.server.mars.IO.refreshConfiguration(IO.java:68)
	at org.eclipse.epp.internal.logging.aeri.ide.server.mars.ServerConnection.startUp(ServerConnection.java:101)
	at com.google.common.util.concurrent.AbstractIdleService$2$1.run(AbstractIdleService.java:54)
	at com.google.common.util.concurrent.Callables$3.run(Callables.java:93)
	at java.lang.Thread.run(Thread.java:745)
Caused by: java.net.ConnectException: Connection refused: connect
	at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method)
	at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:85)
	at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
	at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
	at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
	at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
	at java.net.Socket.connect(Socket.java:589)
	at org.apache.http.conn.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:244)
	at org.apache.http.impl.conn.HttpClientConnectionOperator.connect(HttpClientConnectionOperator.java:125)
	... 16 more
!ENTRY org.eclipse.equinox.ds 2 0 2016-05-19 11:11:39.707
!MESSAGE Getting a lock required more than 10000 ms. There might be a synchronization problem in this callstack or just the build/dispose process of some components took too long!
!STACK 0
java.lang.Exception: Debug stacktrace
	at org.eclipse.equinox.internal.ds.InstanceProcess.getLock(InstanceProcess.java:120)
	at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:560)
	at org.eclipse.equinox.internal.ds.ServiceReg.getService(ServiceReg.java:53)
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212)
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210)
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111)
	at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45)
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496)
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619)
	at org.eclipse.equinox.internal.p2.core.ProvisioningAgent.addingService(ProvisioningAgent.java:159)
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941)
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:1)
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)
	at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183)
	at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:318)
	at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:261)
	at org.eclipse.equinox.internal.p2.core.ProvisioningAgent.getService(ProvisioningAgent.java:66)
	at org.eclipse.oomph.p2.internal.core.AgentImpl.initializeProvisioningAgent(AgentImpl.java:451)
	at org.eclipse.oomph.p2.internal.core.AgentManagerImpl.getCurrentAgent(AgentManagerImpl.java:188)
	at org.eclipse.oomph.setup.ui.SetupUIPlugin.performStartup(SetupUIPlugin.java:351)
	at org.eclipse.oomph.setup.ui.SetupUIPlugin.access$3(SetupUIPlugin.java:346)
	at org.eclipse.oomph.setup.ui.SetupUIPlugin$1$1.run(SetupUIPlugin.java:243)
Re: Eclipse IDE blocks on startup (no response) [message #1732693 is a reply to message #1732692] Thu, 19 May 2016 05:29 Go to previous message
Hmm ... I managed to solve the issue by going back to a previous commit. So apparently it was something I did in my code that Eclipse didn't like.
Previous Topic:Create Eclipse Custom Project
Next Topic:[BUG?] Eclipse Mars.2 on Ubuntu 16.04 Beta errant behavior
Current Time: Mon Jul 21 03:35:49 EDT 2025
Powered by FUDForum. Page generated in 0.09172 seconds
