Re: [RichTextEditor] Missing icons in the palette when widget is calling by a plugin [message #1733810 is a reply to message #1733547] |
Wed, 01 June 2016 03:03  |
Thanks for open a ticket Dirk,
Reading the information of the bugzilla, I can see the missing toolbar icons if i put the follow parameters at the end of the eclipse.ini
-Dorg.eclipse.swt.browser.DefaultType=ie
-Dorg.eclipse.swt.browser.IEVersion=9999
But, when I put these parameters the ck editor don't fill all the area of the browser widget.
Anyway, when I test my plugin, in the configuration tab of the launch or debug properties is setup to generate a new config.file and the result is good so I'll try to change the configuration to try to make a workarround of the problem. I'll write again if I found the parameter involved in the issue.
Best Regards
Pablo
[Updated on: Wed, 01 June 2016 03:03] by Moderator
FUDForum. Page generated in 0.05715 seconds
