Home » Language IDEs » Java Development Tools (JDT) » Eclipse Plugin Installation Error(Eclipse Plugin Installation Error)
Eclipse Plugin Installation Error [message #1732615] Wed, 18 May 2016 10:23 Go to next message
Cannot complete the install because one or more required items could not be found.
Software being installed: CustomProject 1.0.0.201605181920 (CustomProject.feature.group 1.0.0.201605181920)
Missing requirement: Customplugin 1.0.0.201605181920 (customplugin 1.0.0.201605181920) requires 'bundle org.eclipse.ui.ide 3.9.2' but it could not be found
Cannot satisfy dependency:
From: CustomProject 1.0.0.201605181920 (CustomProject.feature.group 1.0.0.201605181920)
To: customplugin [1.0.0.201605181920]
Re: Eclipse Plugin Installation Error [message #1732624 is a reply to message #1732615] Wed, 18 May 2016 10:58 Go to previous messageGo to next message
It's hard to guess what CustomProject might be. In the end, it appears
to require a 3.9.2 version of the IDE, so a repository with that version
must be specified during the install.
> not be found.
> could not be found
> 1.0.0.201605181920)
Re: Eclipse Plugin Installation Error [message #1732627 is a reply to message #1732624] Wed, 18 May 2016 11:49 Go to previous messageGo to next message
Could you please tell me how add those bundle?
Re: Eclipse Plugin Installation Error [message #1732629 is a reply to message #1732627] Wed, 18 May 2016 11:50 Go to previous messageGo to next message
I don't even know the context in which you have this problem. I don't
know what you're installing, nor where it comes from. Ask whomever is
providing it how you should install it.
Re: Eclipse Plugin Installation Error [message #1732633 is a reply to message #1732629] Wed, 18 May 2016 12:32 Go to previous messageGo to next message
I have created custom project using
https://cvalcarcel.wordpress.com/2009/07/11/writing-an-eclipse-plug-in-part-2-creating-a-custom-project-in-eclipse-adding-to-the-new-project-wizard/
https://cvalcarcel.wordpress.com/2009/07/26/writing-an-eclipse-plug-in-part-4-create-a-custom-project-in-eclipse-new-project-wizard-the-behavior/
After that I have created plugin. When I am installing I got the above error
Re: Eclipse Plugin Installation Error [message #1732674 is a reply to message #1732633] Thu, 19 May 2016 01:42 Go to previous message
In Window -> Preferences -> Install Update -> Available Software you can
add update sites and enable them. In the Install dialog, you can enable
"Contact all update sites during install to find required software".
You'll need to add an update site that contents the bundle that's
missing. I think this installable unit is in
http://download.eclipse.org/releases/kepler
> error
Previous Topic:Java returned exit code = 1
Next Topic:Debug Problem
Current Time: Sun Jun 01 00:24:35 EDT 2025
Powered by FUDForum. Page generated in 0.04386 seconds
