Home » Eclipse Projects » Eclipse 4 » Create Eclipse Custom Project(Create Eclipse Custom Project)
Create Eclipse Custom Project [message #1732365] Mon, 16 May 2016 11:27 Go to next message
Can anybody tell me?
I want to create project from eclipse on selecting New -> MyProjectName
On selecting the MyProjectName it should generate a project (like any project) but with my own folder structure.
Re: Create Eclipse Custom Project [message #1732366 is a reply to message #1732365] Mon, 16 May 2016 11:30 Go to previous messageGo to next message
If I understand what you mean by "Custom" the following should work.
New -> Other -> General -> Project
Re: Create Eclipse Custom Project [message #1732367 is a reply to message #1732366] Mon, 16 May 2016 11:37 Go to previous messageGo to next message
But how can I put my own folder structure?
Like
MyProjectName
|-> lib
|-> bin
|-> util
Re: Create Eclipse Custom Project [message #1732368 is a reply to message #1732367] Mon, 16 May 2016 11:39 Go to previous messageGo to next message
Here I want to create a project along with these empty directories.
Re: Create Eclipse Custom Project [message #1732370 is a reply to message #1732368] Mon, 16 May 2016 11:49 Go to previous messageGo to next message
Once the project is created do the following....
Bring up the context menu (normally right mouse click) New -> folder.
As long as the folders stay empty keep one as a template and do a copy paste at the project level for new instances.
If the template project will have sub-folders with files then the copy paste of the IDE will not work. Install the Oomph copy project tool from here if this is going to be more than a one time activity.
index.php/fa/25917/0/
  • Attachment: Snap8.tif
    (Size: 988.92KB, Downloaded 1999 times)
Re: Create Eclipse Custom Project [message #1732373 is a reply to message #1732370] Mon, 16 May 2016 11:59 Go to previous messageGo to next message
So using this tool Can I create a plugin with custom folder structure?
Re: Create Eclipse Custom Project [message #1732375 is a reply to message #1732373] Mon, 16 May 2016 12:08 Go to previous messageGo to next message
The tool does not create a plug-in. All it does is a deep copy of a project. The current version of Eclipse does not support a deep copy of projects.
Re: Create Eclipse Custom Project [message #1732376 is a reply to message #1732373] Mon, 16 May 2016 12:05 Go to previous messageGo to next message
I want to create a eclipse plugin with my own folder structure. Once the plugin is completed. If I install that plugin it should show a option in new -> file-> (in the wizard like java project I want to show my own project name along with its folders)
Re: Create Eclipse Custom Project [message #1732377 is a reply to message #1732375] Mon, 16 May 2016 12:06 Go to previous messageGo to next message
If I select my project from menu it should create project with my own folder structure (like java project does)
Re: Create Eclipse Custom Project [message #1732379 is a reply to message #1732377] Mon, 16 May 2016 12:18 Go to previous messageGo to next message
The two screen captures are all you get with the Oomph tool..
index.php/fa/25922/0/
index.php/fa/25923/0/
  • Attachment: Snap9.tif
    (Size: 310.58KB, Downloaded 1879 times)
  • Attachment: Snap11.tif
    (Size: 305.47KB, Downloaded 1852 times)
Re: Create Eclipse Custom Project [message #1732380 is a reply to message #1732379] Mon, 16 May 2016 12:22 Go to previous messageGo to next message
I don't want to install oomph tool. I want to create just an eclipse plugin. If I install that plugin on any eclipse IDE it should show my project as an option in the menu. If I select that option it should generate a project with all files and folders that I have added in the plugin
Re: Create Eclipse Custom Project [message #1732430 is a reply to message #1732380] Tue, 17 May 2016 05:29 Go to previous message
These are the solutions for my question:
https://cvalcarcel.wordpress.com/2009/07/11/writing-an-eclipse-plug-in-part-2-creating-a-custom-project-in-eclipse-adding-to-the-new-project-wizard/
https://cvalcarcel.wordpress.com/2009/07/26/writing-an-eclipse-plug-in-part-4-create-a-custom-project-in-eclipse-new-project-wizard-the-behavior/
Previous Topic:Create Eclipse Custom Project Type
Next Topic:Eclipse IDE blocks on startup (no response)
Current Time: Mon Jul 21 12:37:07 EDT 2025
Powered by FUDForum. Page generated in 0.26922 seconds
