Home » Eclipse Projects » EGit / JGit » Can't switch branches after last upgrade
Can't switch branches after last upgrade [message #1731547] Fri, 06 May 2016 13:03 Go to next message
today i upgraded to the latest egit (4.3.1.201605051710-r) and switching branches doesn't work any more.
every branch switch pops up the "uncommited changes" dialogue. but there are no uncomitted changes in any of my branches (trying the commit option confirms that: "there are no changes").
nothing i tried (resetting, stashing) works.
so egit is basically broken for me now. any help?
thanks.
[Updated on: Fri, 06 May 2016 13:09] by Moderator
Re: Can't switch branches after last upgrade [message #1731760 is a reply to message #1731547] Mon, 09 May 2016 20:16 Go to previous messageGo to next message
going back to 4.11 fixed the problem.
i wonder though if no one else has noticed this issue?
Re: Can't switch branches after last upgrade [message #1731845 is a reply to message #1731760] Tue, 10 May 2016 08:54 Go to previous messageGo to next message
I have the same problems.
Additionally the automatic rebase fails always with checkout conflicts on files that haven't been touched in the incoming commits.
icon4.gif  Re: Can't switch branches after last upgrade [message #1731849 is a reply to message #1731845] Tue, 10 May 2016 09:28 Go to previous messageGo to next message
When trying to switch a branch I get a checkout conflict on one of the files that differ between the two branches.
No matter what I select (Commit, Stash, Reset) the same dialog appears again. (Selecting Commit shows the "No files to commit" dialog.)
This is a nasty bug and a showstopper!
[Updated on: Tue, 10 May 2016 11:06] by Moderator
Re: Can't switch branches after last upgrade [message #1731850 is a reply to message #1731849] Tue, 10 May 2016 09:41 Go to previous messageGo to next message
What do I have to do to downgrade EGit?
Re: Can't switch branches after last upgrade [message #1731873 is a reply to message #1731850] Tue, 10 May 2016 11:23 Go to previous messageGo to next message
Created a bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=493360
Re: Can't switch branches after last upgrade [message #1732320 is a reply to message #1731873] Sun, 15 May 2016 15:19 Go to previous message
thank you ulrich for reporting it and following up.
has everyone else already switched to SourceTree ;-----)
Previous Topic:Accessing the conflicting lines
Next Topic:Clear working directory before checkout in eGit
Current Time: Tue Nov 04 20:51:56 EST 2025
Powered by FUDForum. Page generated in 0.06009 seconds
