Home » Modeling » Epsilon » EOL: How to create a stereotype in an existing UML profile
EOL: How to create a stereotype in an existing UML profile [message #1731626] Sun, 08 May 2016 05:11 Go to next message
I would like to add a stereotype like "foo" (which extends the <<metaclass>> Class here) to an existing UML profile named "MyProfile" in the following code:
var stereotype: Stereotype;
var elementImport: ElementImport;
var extension: Extension;
if (not Stereotype.all.exists(s|s.name = "foo"))
		// define a new stereotype named with the classifier name
		stereotype = Stereotype.createInstance();
		stereotype.name = "foo";
		stereotype.package = MyProfile;
else
		("foo already exists!").println();
if (not ElementImport.all.exists(e|e.importingNamespace = MyProfile))
		elementImport = ElementImport.createInstance();
		elementImport.importingNamespace = MyProfile;
		elementImport.target = UML!Class; // Error: Undefined variable, type or model: 'UML!Class'
if (not Extension.all.exists(e | e.package = MyProfile))
		extension = Extension.createInstance();
		extension.package = MyProfile;
		extension.metaclass = elementImport.target; // Error: The feature 'metaclass' is not a valid changeable feature
		extension.endType.add(stereotype); // these statements must relate the stereotype and the element import, but do not work as I expect
		extension.endType.add(elementImport.target);
But it does not work as I expect! The usage of the "target", "metaclass" properties are erroneous. How to use and arrange these statements to associate the imported element <<metaclass>> Class and the stereotype "foo"?
Alireza
[Updated on: Tue, 17 May 2016 08:20] by Moderator
Re: EOL: How to create a stereotype in an existing UML profile [message #1731937 is a reply to message #1731626] Wed, 11 May 2016 04:15 Go to previous messageGo to next message
"UML!Class" is just a type name, and doesn't refer to any actual objects. If you want to refer to the EClass, you'd have to load the UML metamodel as a model itself. Within your launch configuration, you could use the "Registered EMF EPackage", and then look through its EClasses to find the one named "Class".
Alternatively, a quick and dirty method could be:
var throwaway = new UML!Class;
var classType = throwaway.eClass;
As for "metaclass", if you look at the Extension EClass through the "EPackage Registry" view, you'll see that it's in italics. That means it is a derived feature, which cannot be changed directly. You have to change the features that it is derived from. If you look at the source code of ExtensionImpl and follow some method calls from getMetaclass(), you'll see that it's derived from this OCL expression:
result = metaclassEnd().type.oclAsType(Class)
metaclassEnd() is another OCL query, which according to the UML source code is defined like this:
result = (memberEnd->reject(p | ownedEnd->includes(p.oclAsType(ExtensionEnd)))->any(true))
It looks like you'll have to set memberEnd or ownedEnd in some way.
[Updated on: Wed, 11 May 2016 04:18] by Moderator
Re: EOL: How to create a stereotype in an existing UML profile [message #1731938 is a reply to message #1731937] Wed, 11 May 2016 04:20 Go to previous messageGo to next message
Dear Antonio,
Thanks a a lot for your solution and reply. How can I load the UML metamodel in EOL code?
Alireza
Re: EOL: How to create a stereotype in an existing UML profile [message #1731940 is a reply to message #1731938] Wed, 11 May 2016 04:25 Go to previous messageGo to next message
Are you running your EOL code from the "Run" launch configurations, or from your own Java code?
EOL itself doesn't allow for loading new models while it's running: you load models either through the launch configuration, or from the Java code setting up the EolModule's model repository.
Re: EOL: How to create a stereotype in an existing UML profile [message #1731943 is a reply to message #1731940] Wed, 11 May 2016 04:31 Go to previous messageGo to next message
No, I'm running from my EOL "Run" launch configurations. Just like "loading the PrimitiveTypes library which I use to change properties datatypes like Integer, String, etc." [1], is there any way to load UML metamodel to use its objects like Class, Operation, etc?
[1] https://git.eclipse.org/c/epsilon/org.eclipse.epsilon.git/tree/examples/org.eclipse.epsilon.examples.uml.library
[Updated on: Wed, 11 May 2016 04:35] by Moderator
Re: EOL: How to create a stereotype in an existing UML profile [message #1731946 is a reply to message #1731943] Wed, 11 May 2016 04:35 Go to previous messageGo to next message
Yes, use the "Registered EMF Package" model type in the "Models" tab of your launch configuration, as I mentioned in my previous message. Alternatively, assign "new Class" to a variable (UML!Class won't work, since UML is treated as a model name) and then extract the .eClass from it.
Re: EOL: How to create a stereotype in an existing UML profile [message #1732012 is a reply to message #1731946] Wed, 11 May 2016 12:53 Go to previous messageGo to next message
I used the "Registered EMF Package" model type and selected "http://www.eclipse.org/uml2/5.0.0/UML" in the Meta-model URI. Instead of setting the target property of the elementImport, I used the importedElement property to set the imported metaclass Class with the following code:
elementImport.importedElement = UML.allInstances().selectOne(e | e.eClass.name = "EClass" and e.name = "Class");
This causes the following exception error:
org.eclipse.emf.ecore.impl.EClassImpl cannot be cast to org.eclipse.uml2.uml.PackageableElement
The expected importedElement must be:
Class [name=Class, qualifiedName=UML::Class, visibility=public, isLeaf=false, isAbstract=false, isFinalSpecialization=false, isActive=false, ]
Is there any trick to resolve this exception?
Alireza
Re: EOL: How to create a stereotype in an existing UML profile [message #1732265 is a reply to message #1732012] Sat, 14 May 2016 03:59 Go to previous messageGo to next message
Sorry for the delay. The problem is that an EClass is not a PackageableElement. I think you want to assign an instance of UML!Class there rather than the UML!Class type itself.
Re: EOL: How to create a stereotype in an existing UML profile [message #1732267 is a reply to message #1732265] Sat, 14 May 2016 04:21 Go to previous messageGo to next message
Hi Antonio,
Thanks a lot.
You're right. But none of the createInstance() method and the new operator are not applicable here:
new UML.allInstances().selectOne(e | e.eClass.name = "EClass" and e.name = "Class"); // Erroneous
or
UML.allInstances().selectOne(e | e.eClass.name = "EClass" and e.name = "Class").createInstance(); // Erroneous
Do you suggest any solution to create and assign an instance of the above UML!Class type here?
Alireza
[Updated on: Sat, 14 May 2016 04:22] by Moderator
Re: EOL: How to create a stereotype in an existing UML profile [message #1732442 is a reply to message #1732267] Tue, 17 May 2016 07:37 Go to previous messageGo to next message
"new" takes a type, not an EClass instance:
var newClass = new Class;
Perhaps this example could help? It shows how to use the "new" keyword:
http://www.eclipse.org/epsilon/examples/index.php?example=org.eclipse.epsilon.examples.buildooinstance
Re: EOL: How to create a stereotype in an existing UML profile [message #1732448 is a reply to message #1732442] Tue, 17 May 2016 07:55 Go to previous message
Hi Antonio,
Thanks a lot for your more clarification and suggested solution. I will try this.
Alireza
Previous Topic:How to add a new UML Property as subset of an UML Class in EML
Next Topic:EVL: Defining more than one context with the same name in a module
Current Time: Wed Jul 23 18:38:15 EDT 2025
Powered by FUDForum. Page generated in 0.06651 seconds
