Home » Archived » Jubula » Testing different DPI Scalings
Testing different DPI Scalings [message #1731725] Mon, 09 May 2016 10:46 Go to next message
hi there,
in windows it is possible to configure a dpi scaling of 100, 125 or 150 %.
Is it possible to use Jubula to test if there are all UI elements visible. i think the check of existence wouldn't work if a label gets cut or a text doesn't fit in the textbox you typed cause it exists anyway...
and i'm not sure if the check text action would recognize that....
Best Regards
Dominik
Re: Testing different DPI Scalings [message #1731772 is a reply to message #1731725] Tue, 10 May 2016 02:13 Go to previous messageGo to next message
Hi Dominik,
Jubula doesn't have a specific check for visibility, but you might be able to use "check property" and check the visibility property on components. I'm not sure though, whether the visibility of a component is true or false if not all of the component is visible.
Jubula also tends to scroll to components, so the check might result in scrolling so that the component is visible.
Hope that helps,
Alex
Re: Testing different DPI Scalings [message #1731774 is a reply to message #1731772] Tue, 10 May 2016 02:28 Go to previous messageGo to next message
hmm ok thanks Alex for your answer. i already thought that it would be like that but i had the hope that there is something i wasn't thinking about. So i have to think of another solution.
May i ask you if you have a progress to check your UI in different DPI settings or do you test this at all?
Re: Testing different DPI Scalings [message #1731799 is a reply to message #1731774] Tue, 10 May 2016 05:07 Go to previous messageGo to next message
We don't currently do DPI settings tests - if we did, I doubt that they would be automated. I know there are image comparison tools available, but trying to "train" them to recognise what is an ok difference and what isn't could be tricky I'd imagine.
Re: Testing different DPI Scalings [message #1731802 is a reply to message #1731799] Tue, 10 May 2016 05:15 Go to previous message
ok thanks a lot for your answer Smile
Previous Topic:Check that a specific string is not in a text
Next Topic:Check Tree Table
Current Time: Mon Jul 21 07:32:41 EDT 2025
Powered by FUDForum. Page generated in 0.03506 seconds
