Home » Eclipse Projects » Remote Application Platform (RAP) » Problem when closing MPart in RAP e4 the whole application crash(Closing of RAP e4 MPart crash the instance of the application)
Problem when closing MPart in RAP e4 the whole application crash [message #1731690] Mon, 09 May 2016 06:07 Go to next message
Hello, I have a problem when closing MPart in Eclipse RAP e4.
From an MPart named InitView, I open MyView using either
partService.showPart(MyView.ID, PartState.ACTIVATE);
or
String id = MyMultiView.ID +Math.random();
ResourceManager.openView(partService,MyMultiView.ID,id);
But when closing MyView I have this error:
2016-05-09 11:55:47.502:WARN:oejs.ServletHandler:qtp220570133-48: ERROR:  /Bacnet
org.eclipse.swt.SWTException: Widget is disposed
	at org.eclipse.swt.SWT.error(SWT.java:3658)
	at org.eclipse.swt.SWT.error(SWT.java:3581)
	at org.eclipse.swt.SWT.error(SWT.java:3552)
	at org.eclipse.swt.widgets.Widget.error(Widget.java:1038)
	at org.eclipse.swt.widgets.Widget.getDisplay(Widget.java:416)
	at org.eclipse.swt.widgets.Widget.isValidThread(Widget.java:993)
	at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:976)
	at org.eclipse.swt.widgets.Control.getParent(Control.java:218)
	at org.eclipse.rap.rwt.internal.lifecycle.ControlLCAUtil.renderParent(ControlLCAUtil.java:142)
	at org.eclipse.swt.internal.widgets.displaykit.DisplayLCA.renderReparentControls(DisplayLCA.java:175)
	at org.eclipse.swt.internal.widgets.displaykit.DisplayLCA.render(DisplayLCA.java:92)
	at org.eclipse.rap.rwt.internal.lifecycle.Render.execute(Render.java:29)
	at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle.continueLifeCycle(RWTLifeCycle.java:149)
	at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle.sleep(RWTLifeCycle.java:223)
	at org.eclipse.swt.widgets.Display.sleep(Display.java:1257)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4$1.eventLoopIdle(PartRenderingEngine.java:1091)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1117)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:994)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
	at org.eclipse.rap.e4.E4EntryPointFactory.createWorkbench(E4EntryPointFactory.java:85)
	at org.eclipse.rap.e4.E4EntryPointFactory.access$0(E4EntryPointFactory.java:58)
	at org.eclipse.rap.e4.E4EntryPointFactory$1.createUI(E4EntryPointFactory.java:49)
	at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:171)
	at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:283)
	at java.lang.Thread.run(Thread.java:745)
	at org.eclipse.rap.rwt.internal.lifecycle.UIThread.run(UIThread.java:104)
It crashes the whole RAP application... With no information in the error log on which widget is disposed.
By using:
@Focus
void grantFocus() {
	System.out.println("Set focus init");
        scrolledComposite.setFocus();
	System.out.println("post focus");
I can see that the focus is performed on the parent MPart = InitView, but then it crashes!
Any idea ?
[Updated on: Mon, 09 May 2016 06:09] by Moderator
Re: Problem when closing MPart in RAP e4 the whole application crash [message #1731693 is a reply to message #1731690] Mon, 09 May 2016 06:27 Go to previous messageGo to next message
please file a bugzilla with a simple snippet to reproduce the issue and
we will address it as soon as possible.
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Problem when closing MPart in RAP e4 the whole application crash [message #1731694 is a reply to message #1731690] Mon, 09 May 2016 06:39 Go to previous messageGo to next message
.... ok. I can reproduce the error with a simple JUint test case by calling:
child.setParent( parent );
child.dispose();
Will be fixed in RAP 3.1RC1.
Best,
Ivan
Ivan Furnadjiev
Re: Problem when closing MPart in RAP e4 the whole application crash [message #1731699 is a reply to message #1731694] Mon, 09 May 2016 07:23 Go to previous messageGo to next message
Thanks for the reply.
So there is some kind of dependency between the MPart ?
Even if the way I open MyView seems independent of InitView (only the partService is involved).
Did you fill out a bugzilla ? as you find a way to reproduce the error. Or you want me to do it.
When will be released RC1 ? Is there a way to avoid this bug easily ?
Re: Problem when closing MPart in RAP e4 the whole application crash [message #1731701 is a reply to message #1731699] Mon, 09 May 2016 07:27 Go to previous messageGo to next message
RAP 3.1RC1 will be released in 10 days (May 20). There is no easy way to
fix the crash meantime. You don't need to open a bugzilla.
Ivan
Ivan Furnadjiev
Re: Problem when closing MPart in RAP e4 the whole application crash [message #1731702 is a reply to message #1731701] Mon, 09 May 2016 07:33 Go to previous message
Ok perfect!
Previous Topic:Sash badget
Next Topic:[RAP E4]Image can't be seen in a treeviewer
Current Time: Sun Jul 20 21:29:03 EDT 2025
Powered by FUDForum. Page generated in 0.07407 seconds
