Home » Eclipse Projects » EclipseLink » The question about using fetchgraph(The question about using fetchgraph)
The question about using fetchgraph [message #1731549] Fri, 06 May 2016 13:10 Go to next message
I have the following entity:
@Entity
@Table(name = "tbl1")
public class PersonItem implements Serializable{
    @Id
    @Column(name="col1")
    private String guid;
    @Column(name="col2")
    private String name;
    @Column(name="col3")
    private String surname;
    @Column(name="col4")
    private Date birthDate;
   //+getters and setters
And I want that only three fields of 4 were loaded from DB. So I do:
Query query = em.createQuery("Select p from PersonItem p");
EntityGraph<PersonItem> eg = em.createEntityGraph(PersonItem.class);
eg.addAttributeNodes("guid");
eg.addAttributeNodes("name");
eg.addAttributeNodes("surname");
query.setHint("javax.persistence.fetchgraph", eg);
 List<PersonItem> list=query.getResultList();
Everything works ok and I see in log that only 3 columns are selected. However, when I try to do item.getBirthDate then istead of null or exception the execution of the thread totally stops, so the next statement after item.getBirthDate is not executed. Why, and how can it be fixed?
[Updated on: Fri, 06 May 2016 13:48] by Moderator
Re: The question about using fetchgraph [message #1731750 is a reply to message #1731549] Mon, 09 May 2016 15:10 Go to previous message
Execution should not be stopping or you have a JVM bug/issue. When accessing an unfetched attribute, EclipseLink will attempt to fetch it from the context, so my guess is you are getting an exception that is unhandled or caught and ignored somewhere in your stack, but if this isn't the case (wrap it in a try/catch block for a Throwable), try posting the jvm and how you are starting the application/thread.
Previous Topic:[moxy] Marshalling empty collection as absent elements for XML
Next Topic:LIMIT query not framed correctly when using CompositePU
Current Time: Sun Jul 27 02:29:33 EDT 2025
Powered by FUDForum. Page generated in 0.04577 seconds
