Home » Eclipse Projects » GEF » text clipping in Label - how to prevent?
text clipping in Label - how to prevent? [message #173152] Tue, 22 March 2005 19:14 Go to next message
This I think is a pretty basic question, but for some reason I cannot get
this to work properly.
I'm creating a custom Figure-based class that draws "flags". The flag uses
an GIF image (Label) for the flag pole and another Label with the flag text.
I use a horizontal ToolbarLayout. I have the figure working properly but I
cannot disable text clipping on the label. What am I doing wrong?
Code:
public FlagFigure() {
super();
IFigure flagPole = new Label(Images.getImage("flagpole.gif"));
IFigure bookmarkLabel = new Label("ThisIsALongerLabel");
setLayoutManager(new ToolbarLayout(true));
bookmarkLabel.setBorder(new MarginBorder(15, 2, 0, 0));
add(flagPole);
add(bookmarkLabel);
Thanks for any help,
Erik
Re: text clipping in Label - how to prevent? [message #173185 is a reply to message #173152] Tue, 22 March 2005 23:01 Go to previous messageGo to next message
I take it that by clipped you mean the text is truncated (i.e., an ellipsis
is shown at its end since not all of it fits in available space)? That
happens when the label is not sized to be as big as it wants to be. I am
not sure why that is happening in your case though.
It seems you're going in a round-about way for what you want to achieve.
Maybe a simpler approach will make things easier for you. Why don't you try
something like this?
Label flagFigure = new Label("ThisIsALongerLabel",
"Erik Johnson" <ejohnson@avaya.com> wrote in message
news:d1qh57$cue$1@news.eclipse.org...
uses
text.
I
> Code:
> super();
> add(flagPole);
> add(bookmarkLabel);
> Erik
Re: text clipping in Label - how to prevent? [message #173297 is a reply to message #173185] Wed, 23 March 2005 14:07 Go to previous message
Doh... It was my problem. My base edit part class was doing things that
weren't correct for the new edit part/figure resulting in setting the layout
constraints/size incorrectly.
As far as using a Label with text + image, the reason I wasn't doing that in
the first place was because I needed to override paintFigure to draw a few
extra lines & colors to give the figure the apperance of a flag. I was able
to achieve the same result though by subclassing Label and overriding
paintFigure, so I will probably just take that approach rather than
needlessly creating composite figures.
Erik
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:d1qufd$qun$1@news.eclipse.org...
ellipsis
try
get
> uses
> text.
but
> I
> > Code:
> > super();
> > add(flagPole);
> > add(bookmarkLabel);
> > Erik
Previous Topic:How to draw line using GEF
Next Topic:NullPointException
Current Time: Sat Jul 26 05:16:00 EDT 2025
Powered by FUDForum. Page generated in 0.07355 seconds
