Home » Newcomers » Newcomers » Eclipse Mars 2 splash screen closes and cannot proceed.(Eclipse Mars 2 splash screen closes and cannot proceed.)
icon8.gif  Eclipse Mars 2 splash screen closes and cannot proceed. [message #1731505] Fri, 06 May 2016 06:10 Go to next message
Hi, I am having problem getting eclipse to start as the eclipse splash screen fires up and closes. I am using the following eclipse version
1. Eclipse Mars 2
2. Ubuntu 16.04
Below is the console log that is captured.
$ ./eclipse
Java HotSpot(TM) 64-Bit Server VM warning: ignoring option MaxPermSize=256m; support was removed in 8.0
org.eclipse.m2e.logback.configuration: The org.eclipse.m2e.logback.configuration bundle was activated before the state location was initialized. Will retry after the state location is initialized.
I have already tried doing the following , but without success eg cannot startup eclipse.
1. Setting --launcher.GTK_version 2 (within eclipse.ini)
Any advice is appreciated.
[Updated on: Sun, 08 May 2016 10:22] by Moderator
Re: Eclipse Mars 2 splash screen closes and cannot proceed. [message #1731680 is a reply to message #1731505] Mon, 09 May 2016 04:35 Go to previous message
This is not very helpful for further investigation. Could you please check if Oracle or Openjdk is in your PATH in bash script? Also could you please check if GTK+3 or GTK+2 is installed?
Kind Regards
Previous Topic:Java Access Remote MySQL Database - JDBC or ODBC ?
Next Topic:Source code print margin
Current Time: Sat Jul 26 11:45:52 EDT 2025
Powered by FUDForum. Page generated in 0.11018 seconds
