Home » Eclipse Projects » EGit / JGit » Git Import = General Project & Can't run as java
Git Import = General Project & Can't run as java [message #1731357] Wed, 04 May 2016 11:18 Go to next message
I am new to java & trying to learn with my friend. We created a sample on github and used egit to clone & then import.
It worked fine for him & he's able to run it as java with no configuration changes from a brand new install.
For me, it does not work because it just imports it as a general project no matter what. I have googled & searched for hours & hours but I can't figure out what is wrong.
Here is our sample on github: https://github.com/hayyyyyyyyyyy/cuddly-chainsaw
and I've attached a screenshot of my general project that will not run as java.
Also, I have re-created the project as a non-git offline java project and it works fine. Any help would be greatly appreciated.
Re: Git Import = General Project & Can't run as java [message #1731363 is a reply to message #1731357] Wed, 04 May 2016 12:10 Go to previous messageGo to next message
You have the Eclipse project (.project file) in the repository so
just import existing project instead of import as general project
nice github account name Wink
Re: Git Import = General Project & Can't run as java [message #1731368 is a reply to message #1731363] Wed, 04 May 2016 12:15 Go to previous messageGo to next message
Thank you! I added those files yesterday but it still does not help.
I actually have nearly no idea what I am doing. I just want this setup correctly so that we can learn github & java together. Do you know any online services that can remote into my PC and set everything up correctly?
Embarrassed
Re: Git Import = General Project & Can't run as java [message #1731372 is a reply to message #1731368] Wed, 04 May 2016 12:27 Go to previous messageGo to next message
The .project file you added has a strange name "org.eclipse.jdt.core.javabuilder" (it should be naming your project, which doesn't look like the JDT java builder)
and it's not a Java project, e.g. there is no javabuilder specified and you also lack the .classpath file needed to define the classpath for your project.
Best you create a fresh new Java project using the project wizard: click "New > Java Project" give it a name and then copy the resulting .project
and .classpath into your project. Note you can't open two projects with the same name in Eclipse so you have to delete the one you
used to generate a proper Java project before you can open the other one in the same workbench.
Re: Git Import = General Project & Can't run as java [message #1731373 is a reply to message #1731372] Wed, 04 May 2016 12:28 Go to previous messageGo to next message
Thanks! I'll give it a try.
Re: Git Import = General Project & Can't run as java [message #1731407 is a reply to message #1731373] Wed, 04 May 2016 22:07 Go to previous message
I created a new java project in eclipse & uploaded via the git shell, deleted it locally, then cloned/imported and it runs as java now ^_^
thanks again
Previous Topic:EGit is showing 401: Unauthorized error when pushing to TFS Git repository
Next Topic:disable 'Information Message' from egit
Current Time: Sun Jul 20 23:38:00 EDT 2025
Powered by FUDForum. Page generated in 0.23698 seconds
