Home » Modeling » TMF (Xtext) » Eclipse Plugin Install Error(Eclipse Plugin Install Error)
Eclipse Plugin Install Error [message #1731273] Wed, 04 May 2016 02:26 Go to next message
Hi Christian,
I have created plugin for my dsl editor that developed using xtext.
It is installing on my eclipse IDE successfully but when I using the same plugin on some other system it is throwing below error. I debug the plugin but I didn't get the solution.
index.php/fa/25806/0/
I checked in my plugin it contains all the artifacts like :
Please find the attached plugin. Could you please tell me the bug in my setup?
[Updated on: Wed, 04 May 2016 05:35] by Moderator
Re: Eclipse Plugin Install Error [message #1731275 is a reply to message #1731273] Wed, 04 May 2016 02:46 Go to previous messageGo to next message
the screenhot is irrelevant. the interesting point is what is in the error message. it says you what is wrong.
in the screenshot you can only see the beginning of the message: requires bundle ...
Re: Eclipse Plugin Install Error [message #1731280 is a reply to message #1731275] Wed, 04 May 2016 02:56 Go to previous messageGo to next message
The error message is
Cannot complete the install because one or more required items could not be found.
Software being installed: JPL_Plugin_Editor 1.0.0.201605032306 (JPL_Plugin_Editor.feature.group 1.0.0.201605032306)
Missing requirement: com.prolifics.jpl.JPLEditor.tests 1.0.0.201605032306 (com.prolifics.jpl.JPLEditor.tests 1.0.0.201605032306) requires 'bundle org.eclipse.xtext.junit4 0.0.0' but it could not be found
Cannot satisfy dependency:
From: JPL_Plugin_Editor 1.0.0.201605032306 (JPL_Plugin_Editor.feature.group 1.0.0.201605032306)
To: com.prolifics.jpl.JPLEditor.tests [1.0.0.201605032306]
Re: Eclipse Plugin Install Error [message #1731282 is a reply to message #1731280] Wed, 04 May 2016 02:58 Go to previous messageGo to next message
are you sure you want to add the tests to your feature? i would not have added them to the feature
Re: Eclipse Plugin Install Error [message #1731284 is a reply to message #1731282] Wed, 04 May 2016 03:12 Go to previous messageGo to next message
Hi Christian,
I am new to xtext. This is the first time I am working on it. So I don't know what all are required to create a plugin so at the time of plugin creation I have added all the artifacts.
Re: Eclipse Plugin Install Error [message #1731286 is a reply to message #1731284] Wed, 04 May 2016 03:23 Go to previous messageGo to next message
Hi Christian,
Do I need to mention all those I required in category.xml?
Re: Eclipse Plugin Install Error [message #1731287 is a reply to message #1731284] Wed, 04 May 2016 03:24 Go to previous messageGo to next message
is it working if you remove it? do you have a updatesite for xtext added to your target eclipse? is xtext already installed there?
Re: Eclipse Plugin Install Error [message #1731288 is a reply to message #1731287] Wed, 04 May 2016 03:27 Go to previous messageGo to next message
To install my plugin Do I need to xtext on customer IDE?
Re: Eclipse Plugin Install Error [message #1731289 is a reply to message #1731288] Wed, 04 May 2016 03:27 Go to previous messageGo to next message
yes, at least parts of it.
Re: Eclipse Plugin Install Error [message #1731291 is a reply to message #1731289] Wed, 04 May 2016 03:31 Go to previous messageGo to next message
why we need xtext installing on customer side, though my plugin developed from xtext ? Can you please explain?
Re: Eclipse Plugin Install Error [message #1731294 is a reply to message #1731291] Wed, 04 May 2016 03:37 Go to previous messageGo to next message
xtext has parts that generate stuff, but xtext has api parts as well.
these api parts are not copied to each language but reused by all languages.
this is why you need e.g. the plugin org.eclipse.xtext in your target environment.
of couse you can e.g. add the xtext.sdk feature to the included features in the feature editor of your feature xml
or you simply add the xtext update site as well to your customer ide.
or .... (tons of options on how to deal with this)
Re: Eclipse Plugin Install Error [message #1731296 is a reply to message #1731294] Wed, 04 May 2016 03:54 Go to previous messageGo to next message
Thanks for your valuable information
Re: Eclipse Plugin Install Error [message #1731304 is a reply to message #1731296] Wed, 04 May 2016 04:29 Go to previous messageGo to next message
Hi Christian,
But the newly generated plugin is not working individually. If I install xtext plugin its working. Am I going in right direction? Can you please guide me?
Re: Eclipse Plugin Install Error [message #1731307 is a reply to message #1731304] Wed, 04 May 2016 04:33 Go to previous messageGo to next message
org.eclipse.text is not org.eclipse.xtext
and there are others (ca 30) to add.
so did you add xtext.sdk to included features?
Re: Eclipse Plugin Install Error [message #1731316 is a reply to message #1731307] Wed, 04 May 2016 05:20 Go to previous messageGo to next message
It's a spelling mistake. I have added org.eclipse.xtext. I didn't see xtext.sdk there in the list. Do I need to install 30 more packages?
Re: Eclipse Plugin Install Error [message #1731318 is a reply to message #1731316] Wed, 04 May 2016 05:23 Go to previous message
yes i have no complete list.
thus simply add the sdk to the feature, p2 will then pick what it needs
Previous Topic:What to commit
Next Topic:Change the "Xtext Task" in Task Browser
Current Time: Fri Jul 25 23:55:01 EDT 2025
Powered by FUDForum. Page generated in 0.05092 seconds
