Home » Eclipse Projects » e(fx)clipse » FXMLBuilder StackOverflowError(trying to load an FXML file in part results in StackOverflowError)
FXMLBuilder StackOverflowError [message #1723345] Sun, 14 February 2016 16:48 Go to next message
What is the correct way to load an FXML file in a e4 part?
The builder.load() method generates a StackOverflowError.
I created an e4 Application project from File->New->Project...->JavaFX->OSGI
I edited the @PostConstruct method to look like the following:
@PostConstruct
public void postConstruct(BorderPane parent, @FXMLLoader FXMLLoaderFactory factory) {
	try {
            FXMLBuilder<Node> builder = factory.loadRequestorRelative("IOS.fxml");
            Node n = builder.load();
            parent.setCenter(n);
        } catch (IOException e) {
            e.printStackTrace();
		// This works when the FXML loader code is commented out.
//		Button btn = new Button("Hello World");
//		btn.setId("hwButton");
//		btn.setOnAction(new EventHandler<ActionEvent>() {
//			@Override
//			public void handle(ActionEvent event) {
//				System.out.println("Button clicked");
//		parent.setCenter(btn);
The FXML looks like this:
	Do not edit this file it is generated by e(fx)clipse from ../src/com/parts/IOS.fxgraph
<?import java.lang.*?>
<?import javafx.scene.control.Button?>
<?import javafx.scene.layout.BorderPane?>
<?scenebuilder-stylesheet /css/default.css?>
<BorderPane xmlns:fx="http://javafx.com/fxml" fx:controller="com.parts.UIPart">
	<center>
		<Button fx:id="hwButton" text="Hello World" onAction="#clicked"/>
	</center>
</BorderPane>
Thanks for the help,
John
[Updated on: Sun, 14 February 2016 16:50] by Moderator
Re: FXMLBuilder StackOverflowError [message #1723346 is a reply to message #1723345] Sun, 14 February 2016 17:08 Go to previous messageGo to next message
I always manage to figure this stuff out after I ask for help.
You can't make the Part the Controller as well. I created another class that the FXML is controlled by and the e4 Part loaded as expected.
I'm still learning JavaFX in an e4 app.
Re: FXMLBuilder StackOverflowError [message #1731152 is a reply to message #1723346] Tue, 03 May 2016 04:43 Go to previous messageGo to next message
John Bodkin wrote on Sun, 14 February 2016 22:08
I just ran into the same problem. Is this the preferred way of doing that? I tried to have the MPart be the controller as well. Is that even possible?
Or are you supposed to do it something like this (with MPart being registered somewhere in the application model):
public class MyPart {
	Node view;
	MyController controller;
	@PostConstruct
	void init(HBox p, IEclipseContext context) {
		InjectingFXMLLoader<Node> iFXMLLoader = InjectingFXMLLoader.create(context, getClass(), "view.fxml");
		try {
			Data<Node, MyController> data = iFXMLLoader.loadWithController();
			view = data.getNode();
			controller = data.getController();
			p.getChildren().add(view);
                        // ...do other stuff
Re: FXMLBuilder StackOverflowError [message #1731243 is a reply to message #1731152] Tue, 03 May 2016 13:59 Go to previous messageGo to next message
I would generally not advice you to make the Part instance your
controller but anyways the way to do it would be:
a) remove fx:controller from your FXML-File
b) change your MyPart to
class MyPart {
@PostConstruct
void init(HBox box, @LocalInstance FXMLLoader loader) {
loader.setController(this);
loader.setLocation(getClass().getResource("view.fxml"));
box.getChildren().add(loader.load());
You already see the problem? Because you HAVE TO remove the
fx:controller from the FXML-File the tooling can not assist anymore with
showing errors/warnings/autofixes.
I thought we had a feature request somewhere in bugzilla where we
discussed if it would be possible to directly put the FXML-File into the
e4-MPart-Model and we detect that situation in the framework and instead
of creating an instance we load the FXML-File and push the controller
into the MPart#object slot.
Tom
> possible?
> Node view;
> @PostConstruct
> try {
Re: FXMLBuilder StackOverflowError [message #1731308 is a reply to message #1731243] Wed, 04 May 2016 04:45 Go to previous message
Thanks!
Previous Topic:Can't Send Email using SMTP in JavaFX
Next Topic:css file doesn't load for app handlers
Current Time: Sun Jul 27 09:40:46 EDT 2025
Powered by FUDForum. Page generated in 0.20875 seconds
