Home » Modeling » Epsilon » EVL: How to define and use a profile and stereotypes in a model validation
EVL: How to define and use a profile and stereotypes in a model validation [message #1730972] Sun, 01 May 2016 04:45 Go to next message
Considering the following code to create a non-existing class stereotype:
pre {
	// getting the existing FooProfile
	var MyProfile = ProfileModel.select(p|p.name = "FooProfile");
if (not Stereotype.all.exists(s|s.name = "foo"))
	// define a new stereotype named with the given name
	var stereotype: Stereotype = Stereotype.createInstance();
	stereotype.name = "foo";
	stereotype.package = MyProfile;
	stereotype.feature = "base_Class";
else
	("foo" + " exists!").println();
1) The following error is raised when I apply the code in a UML model validation:
Cannot find meta-class 'foo' in model ''
I think, it is required here to store the created stereotype "foo" in my profile model too. Is this true? How can I add the created stereotype to my profile model file (here ProfileModel)?
2) I want to create a UML profile from scratch, i.e., the profile must be created in the pre section of my EVL module. How can I create this profile in the EOL language?
Alireza
[Updated on: Sun, 08 May 2016 05:13] by Moderator
Re: EVL: How to define and use a profile and stereotypes in a model validation [message #1731239 is a reply to message #1730972] Tue, 03 May 2016 13:02 Go to previous messageGo to next message
Hi Alireza,
I suspect that you'll need to re-apply the modified profile to your UML model.
Dimitris
Re: EVL: How to define and use a profile and stereotypes in a model validation [message #1731244 is a reply to message #1731239] Tue, 03 May 2016 14:14 Go to previous messageGo to next message
Dear Dimitris,
Thanks a lot for the reply. Do you suggest any trick to the (2) question?
Alireza
Re: EVL: How to define and use a profile and stereotypes in a model validation [message #1731247 is a reply to message #1731244] Tue, 03 May 2016 14:21 Go to previous messageGo to next message
Hi Alireza,
To create a profile on the fly you can add an empty UML model in your run configuration that will host your stereotypes etc.
Dimitris
Re: EVL: How to define and use a profile and stereotypes in a model validation [message #1731248 is a reply to message #1731247] Tue, 03 May 2016 14:25 Go to previous messageGo to next message
Thanks a lot.
Alireza
Re: EVL: How to define and use a profile and stereotypes in a model validation [message #1731352 is a reply to message #1731248] Wed, 04 May 2016 09:51 Go to previous messageGo to next message
Hi all,
I like to define stereotypes which extend metaclasses like Classifier, Operation, etc. Is there any solution to modify the following code in EOL to resolve my problem?
		// define a new stereotype named with the "foo" name here
               // the following line raises error,
               // even for the string "base_Class" in the right-hand side too
		stereotype.metaclass = "base_Classifier";
else
		("foo already exists!").println();
Alireza
[Updated on: Wed, 04 May 2016 12:58] by Moderator
Re: EVL: How to define and use a profile and stereotypes in a model validation [message #1731381 is a reply to message #1731352] Wed, 04 May 2016 14:14 Go to previous messageGo to next message
Hi Alireza,
Which property of Stereotype [1] are you trying to assign using the line in question?
Dimitris
[1] http://download.eclipse.org/modeling/mdt/uml2/javadoc/5.0.0/org/eclipse/uml2/uml/Stereotype.html
Re: EVL: How to define and use a profile and stereotypes in a model validation [message #1731392 is a reply to message #1731381] Wed, 04 May 2016 17:02 Go to previous message
Dear Dimitris,
Thanks a lot for your help. I created another topic to illustrate the problem with more detail. Please, see https://www.eclipse.org/forums/index.php?t=msg&th=1077253&goto=1731626&#msg_1731626.
Alireza
[Updated on: Sun, 08 May 2016 05:21] by Moderator
Previous Topic:call java class which has a method from ANT build file
Next Topic:Query in ETL -Accessing the Target Node Parent?
Current Time: Thu Jul 24 23:24:45 EDT 2025
Powered by FUDForum. Page generated in 0.28400 seconds
