Home » Newcomers » Newcomers » Semaphore
Semaphore [message #173090] Sat, 30 September 2006 13:59 Go to next message
Originally posted by: malin_grr.hotmail.com
Hello
I got a problem, somehow I can't use the java.util.concurrent.Semaphore in
my code when I'm working in eclipse why?
How can I get it to work, I can't "import" it, what is this??
Please help!
Re: Semaphore [message #173114 is a reply to message #173090] Sat, 30 September 2006 20:37 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
Are you sure you're using a Java 1.5 or later JRE?
- Jeff
malin wrote:
> Hello
> in my code when I'm working in eclipse why?
> Please help!
Re: Semaphore [message #173284 is a reply to message #173090] Mon, 02 October 2006 23:25 Go to previous message
Originally posted by: eclipse4.rizzoweb.com
malin wrote:
> Hello
> Please help!
You are probably running Eclipse with a 1.4 JVM/JDK, so Eclipse is not
set up in Java 5.0 mode.
Got to the Preferences, Java > Compiler and you'll see an option to set
it for Java 5. Also check the Installed JREs section to see if you have
it configured with an appropriate JRE/JDK.
Hope this helps,
Eric
Previous Topic:Support for a tool
Next Topic:Update
Current Time: Tue Jul 22 02:53:10 EDT 2025
Powered by FUDForum. Page generated in 0.31618 seconds
