[CDO] Saving 1st model element to new repo crashes Eclipse [message #1731128] |
Tue, 03 May 2016 00:31  |
I am setting up a new linux laptop to develop my CDO project on. It is based on Kepler SR2 and I updated CDO to 4.3.0 from here - http://download.eclipse.org/modeling/emf/cdo/updates/releases/4.3/
I start with running my CDO Server with an empty database. Using the CDO Explorer view I add my ecore file with "Package Registry... " Then I open a Transaction and create a new resource "resource1". Then I open in the CDO Editor and add a new model element. Once I Ctrl-S it crashed the CDOServer running.
Exception in thread "net4j-Thread-1" java.lang.NoClassDefFoundError: org/eclipse/core/resources/ResourcesPlugin
at org.eclipse.emf.ecore.plugin.EcorePlugin.getWorkspaceRoot(EcorePlugin.java:1081)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.<clinit>(ExtensibleURIConverterImpl.java:393)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getURIConverter(ResourceSetImpl.java:499)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:369)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:220)
at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.getMetaInstance(MetaDataManager.java:113)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.ObjectTypeTable.getObjectType(ObjectTypeTable.java:90)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.DelegatingObjectTypeMapper.getObjectType(DelegatingObjectTypeMapper.java:60)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalMappingStrategy.readObjectType(AbstractHorizontalMappingStrategy.java:82)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalMappingStrategy.readObjectType(HorizontalMappingStrategy.java:194)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.readObjectType(DBStoreAccessor.java:205)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.getObjectType(DBStoreAccessor.java:222)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.readRevision(DBStoreAccessor.java:242)
at org.eclipse.emf.cdo.internal.server.Repository.loadRevisions(Repository.java:495)
at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.loadRevisions(CDORevisionManagerImpl.java:387)
at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevisions(CDORevisionManagerImpl.java:292)
at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevision(CDORevisionManagerImpl.java:275)
at org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.execute(RevisionInfo.java:140)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.LoadRevisionsIndication.responding(LoadRevisionsIndication.java:169)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndication.responding(CDOServerIndication.java:134)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOutput(IndicationWithResponse.java:98)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:298)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:67)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerReadIndication.execute(CDOServerReadIndication.java:36)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.ClassNotFoundException: org.eclipse.core.resources.ResourcesPlugin cannot be found by org.eclipse.emf.ecore_2.9.1.v20130827-0309
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
... 29 more
The org.eclipse.core.resources_3.8.101.v20130717-0806.jar plugin that contains this class is present and correct.
I attached the h2 db the repo at the point of failure. The user is "cdo" and pwd is "cdo34er", repo is "repo1" and the resource is "resource1"
Ideas?
[Updated on: Tue, 03 May 2016 00:44] by Moderator
Re: [CDO] Saving 1st model element to new repo crashes Eclipse [message #1731194 is a reply to message #1731131] |
Tue, 03 May 2016 08:31   |
Hi Eike,
I am stuck with 4.3 for a while because moving a large RCP 3 app to e4 is too big an undertaking currently.
Out of interest I tried to add a model element from the legacy modle included in the registry, ejb. I got the same exception, thus it is nothing to do with my model.
I must misunderstand something. I have a genmodel ready for CDO, but I describe the preparation of the database above, which has nothing to do with the generated code. When I use CDO Explorer view to open a session I cannot see my model as associated with the empty db. So I use Package Registry... to attached it, it shows as state == new, type = dynamic and original = dynamic. The I open a Transaction on that session, then I create a new resource, then I open that resource in the CDO editor then I add a model element, then I save and it crashes. How are you supposed to prepare a empty database ready to use with your client? None of the tutorials I could find seem to describe how you prepare a empty database ready for your model?
[Updated on: Tue, 03 May 2016 19:42] by Moderator
Re: [CDO] Saving 1st model element to new repo crashes Eclipse [message #1731270 is a reply to message #1731194] |
Wed, 04 May 2016 01:27   |
Am 03.05.2016 um 14:31 schrieb David Wynter:
> Hi Eike,
CDO does not depend on e4, nor does it depend on any strict version of the Eclipse Platform. We only test against the
Eclipse version that's displayed next to a CDO download, but you should be able to run against a different version, too.
Can you be more specific w.r.t. the exact steps you take to register your package? If it results in a "dynamic" package,
you've probably done something wrong.
> with your client?
Your generated model/package plugin should be deployed and activated in your client, ready to be used with CDO. Is that
not the case?
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Saving 1st model element to new repo crashes Eclipse [message #1766560 is a reply to message #1766499] |
Fri, 23 June 2017 01:18  |
David Wynter wrote on Thu, 22 June 2017 11:20Hi Eike,
I was confused by something you said. As far as I know we do not use dynamic models. We generate code for the ecore file and use those generated classes. Was there something in the stack trace I posted that makes you think we use dynamic models?
I think you mentioned that the UI showed the package as "type = dynamic and original = dynamic".
David Wynter wrote on Thu, 22 June 2017 11:20On the point you made about a mismatch between the client and server protocol version.We use a targetplatform to define the version of CDO and Net4j so they are consistent across client and server. Does that mean we have a bug in the CDO protocol?
It could mean that. But if so, it must be in a very rarely used "area". For example related to a specific datatype or even a specific value of that type. It's all guessing until I can reproduce the problem. Can you provide an executable test case?
FUDForum. Page generated in 0.35751 seconds
