Home » Modeling » EMF » Once again Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl]
Once again Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl] [message #1060537] Sun, 26 May 2013 08:24 Go to next message
i know there are already a few threads about this error, but none of them solved my problem.
i built a standalone server and client (without eclipse, launch-files or something else, just by calling the server/client class) based on examples by Eike Stepper:
- server: http://git.eclipse.org/c/cdo/cdo.git/tree/plugins/org.eclipse.emf.cdo.examples/src/org/eclipse/emf/cdo/examples/server/Server.java
- client: http://git.eclipse.org/c/cdo/cdo.git/tree/plugins/org.eclipse.emf.cdo.examples/src/org/eclipse/emf/cdo/examples/StandaloneManualExample.java
i attached a picture with my included plugins (for the server). i already included 'org.eclipse.emf.cdo.server.ocl_4.0.0.v20120911-1146.jar' (as mentioned in other threads) and in the osgi-terminal it is marked as resovled.
i also tested the precompiled server from 'emf-cdo-R20130213-0014-CDOServer-Linux.zip' (also added the ...server.ocl-jar) and i got the same error.
the request of my client which causes the error looks like that:
// the connection is create like in the example above
CDOTransaction transaction = s.openTransaction();
CDOQuery cqo = transaction.createQuery("ocl", "Company.allInstances()");
final List<Company> companies = cqo.getResult(Company.class);
int size = companies.size();
The error trace from the server looks like:
[ERROR] Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl]
org.eclipse.net4j.util.container.FactoryNotFoundException: Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl]
	at org.eclipse.net4j.util.container.ManagedContainer.getFactory(ManagedContainer.java:200)
	at org.eclipse.net4j.util.container.ManagedContainer.createElement(ManagedContainer.java:534)
	at org.eclipse.net4j.util.container.ManagedContainer.getElement(ManagedContainer.java:292)
	at org.eclipse.net4j.util.container.ManagedContainer.getElement(ManagedContainer.java:273)
	at org.eclipse.emf.cdo.spi.server.ContainerQueryHandlerProvider.getQueryHandler(ContainerQueryHandlerProvider.java:42)
	at org.eclipse.emf.cdo.internal.server.Repository.getQueryHandler(Repository.java:977)
	at org.eclipse.emf.cdo.internal.server.QueryManager$QueryContext.run(QueryManager.java:293)
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
	at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
	at java.util.concurrent.FutureTask.run(FutureTask.java:166)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
	at java.lang.Thread.run(Thread.java:722)
Has anybody some ideas? Did i miss any dependency or something?
  • Attachment: cdo.png
    (Size: 118.04KB, Downloaded 193 times)
Re: Once again Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl] [message #1060670 is a reply to message #1060537] Mon, 27 May 2013 11:56 Go to previous messageGo to next message
Am 27.05.2013 14:34, schrieb bobby car:
A standalone server needs to register the needed factory via:
OCLQueryHandler.prepareContainer(IPluginContainer.INSTANCE);
Cheers
/Eike
http://www.esc-net.de
Re: Once again Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl] [message #1060682 is a reply to message #1060670] Mon, 27 May 2013 13:36 Go to previous messageGo to next message
that and a few more dependencies seem to fix my problem
Thanks Eike
Re: Once again Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl] [message #1730751 is a reply to message #1060682] Thu, 28 April 2016 05:28 Go to previous messageGo to next message
I'm facing the same problem while performing junit tests based on a h2 memstore.
I followed the tip of this topic and also had a look to 'org.eclipse.emf.cdo.tests.config.impl.RepositoryConfig' with no success Sad.
The following plug-ins are declared as required :
- org.eclipse.emf.cdo.server.ocl
- org.eclipse.ocl.ecore
And running my test against a deployed repository based on a classical h2 db store is ok.
Can anybody help me figure out what is wrong with the following configuration used in my test ?
Map<String, String> props = new HashMap<String, String>();
props.put(IRepository.Props.OVERRIDE_UUID, "");
props.put(IRepository.Props.SUPPORTING_AUDITS, "false");
props.put(IRepository.Props.SUPPORTING_BRANCHES, "false");
props.put(IRepository.Props.ENSURE_REFERENTIAL_INTEGRITY, "false");
IRepository repository = CDOServerUtil.createRepository(REPOSITORY_NAME, MEMStoreUtil.createMEMStore(), props);
container = ContainerUtil.createContainer();
OCLQueryHandler.prepareContainer(container); // Needed for issuing OCL queries
Net4jUtil.prepareContainer(container);
CDONet4jUtil.prepareContainer(container);
CDONet4jServerUtil.prepareContainer(container);
TCPUtil.prepareContainer(container);
container.activate();
TCPUtil.getAcceptor(container, URI);
CDOServerUtil.addRepository(container, repository);
connector = TCPUtil.getConnector(container, URI);
CDONet4jSessionConfiguration sessionConfig = CDONet4jUtil.createNet4jSessionConfiguration();
sessionConfig.setConnector(connector);
sessionConfig.setRepositoryName(REPOSITORY_NAME);
featureSession = sessionConfig.openNet4jSession();
concurrentSession = sessionConfig.openNet4jSession();
Kind regards,
Laurent
Re: Once again Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl] [message #1730944 is a reply to message #1730751] Sat, 30 April 2016 10:09 Go to previous messageGo to next message
Am 28.04.2016 um 11:28 schrieb Laurent Le Moux:
> no success :(.
Please try the following instead:
container = IPluginContainer.INSTANCE;
Does that work?
Cheers
/Eike
> Kind regards,
> Laurent
Re: Once again Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl] [message #1730952 is a reply to message #1730944] Sat, 30 April 2016 11:31 Go to previous messageGo to next message
It was as simple as that...
Thank you Eike !
Re: Once again Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl] [message #1730971 is a reply to message #1730952] Sun, 01 May 2016 04:21 Go to previous messageGo to next message
Hi Laurent,
I looked at it again and propose the following addition to CDOServerUtil.addRepository() :
InternalRepository internal = (InternalRepository)repository;
if (internal.getContainer() == null)
internal.setContainer(container);
With that code added you could use your own container instance and the repo's query handler provider would use it to
look up the query handlers. Can you please submit a bugzilla for this?
Cheers
/Eike
Am 30.04.2016 um 17:31 schrieb Laurent Le Moux:
> Thank you Eike !
Re: Once again Factory not found: org.eclipse.emf.cdo.server.queryHandlerFactories[ocl] [message #1731012 is a reply to message #1730971] Mon, 02 May 2016 03:38 Go to previous message
Hi Eike,
It's done : https://bugs.eclipse.org/bugs/show_bug.cgi?id=492791
Laurent
Previous Topic:[CDO] CDOLazyContentAdapter does not attach to CDOResourceFolder
Next Topic:Ecore meta-model formal documentation?
Current Time: Wed Jul 23 10:46:09 EDT 2025
Powered by FUDForum. Page generated in 0.07405 seconds
