4DIAC [message #1730940] |
Sat, 30 April 2016 05:19  |
Hi all, i'm new in this forum, i have a problem with 4DIAC.
Speciically, when i make deployment with Forte with Pre-Existent Functional Blocks everything work, but when i create new functional blocks....forte recognize only the OLD pre-existent FB!
This is hoy i did:
- i create a new functional block
- exported its .cpp and .f files in the Forte\src\modules\utils
- added the line in the cmakelist.txt in the utils folder
- opened cmake, configured using the root forte directory as source code, Forte\bin\win32 as destination folder, using visual studio 8 2009 as generator and using the native compiler,checked FORTE_ARCHITECTURE_WIN32, FORTE_MODULE_CONVERT, FORTE_MODULE_IEC61131, FORTE_MODULE_TEST, FORTE_MOODULE_UTILS, FORTE_SUPPORT_MONITORING, pressed again configure since red flags don't appaer, pressed generate button
- opened visual studio generated solution with visual studio 2008
- setted release mode
- build forte......AND HERE THE PROBLEM!
"Errore 45 fatal error C1083: Impossibile aprire il file inclusione 'E_CYCLE_gen.cpp': No such file or directory"
PLEASE....HELP ME :\
Re: 4DIAC [message #1730982 is a reply to message #1730940] |
Sun, 01 May 2016 11:04  |
It's probably better to ask on their specific forum:
http://eclipse.org/forums/eclipse.4diac
> This is hoy i did:
> button
FUDForum. Page generated in 1.25554 seconds
