Home » Modeling » TMF (Xtext) » What to commit(GIT commit of xtext project)
What to commit [message #1730915] Fri, 29 April 2016 14:25 Go to next message
I tried to find something like this online and could not, so sorry if this is a duplicated question.
I've created a grammar (new project -> file under org,example.domainmodel ->etc)
I would like to commit this grammar to a repo, so other collaborators will be able to both edit it and use it.
I tried to find online some guidelines of what I should commit
1) should I commit all directories that were created with the project?
2) should I commit just the xtext file?
3) should I do something else?
Thank you
Re: What to commit [message #1730917 is a reply to message #1730915] Fri, 29 April 2016 14:42 Go to previous messageGo to next message
You should exclude src-gen xtend-gen bin / target and Model/generated
Re: What to commit [message #1730918 is a reply to message #1730917] Fri, 29 April 2016 14:51 Go to previous messageGo to next message
But if the only file I created is under
org.example.domainmodel/src/org.example.domainmodel/Domainmodel.xtext
do I really need to commit the entire src directory?
do I really need the ide/tests/ui and ui.tests directories?
Re: What to commit [message #1730919 is a reply to message #1730918] Fri, 29 April 2016 14:57 Go to previous messageGo to next message
You should run the mwe once. This will trigger the Generation of the the generated once / stub Classes that will Contain manually written customization Code and yes you need the other Projects as well as you chose. To create them in the wizard
Re: What to commit [message #1730922 is a reply to message #1730919] Fri, 29 April 2016 15:41 Go to previous messageGo to next message
what is mwe?
Re: What to commit [message #1730923 is a reply to message #1730922] Fri, 29 April 2016 15:48 Go to previous messageGo to next message
This is the generateyourdsl.mwe2 file that triggers the xtext generator
Re: What to commit [message #1731301 is a reply to message #1730923] Wed, 04 May 2016 04:12 Go to previous message
It's a matter of taste/necessity what you check in.
You should always check in
- everything that is hand written. That includes the grammar
- everything that has been manually modified, e.g. if you touched the generated plugin.xml
- the base plug-in structure as created by the 'New Xtext project' wizard, as the generator is not capable of recreating plug-ins and the base files (e.g. MANIFEST.MF) therein.
It makes sense to check in
- all generate-once artifacts, e.g. plugin.xml, everything in the src folder. Why? Because you could manually modify it in the future and forget to add it.
- the .settings folder if you want your project settings to be valid for all users
You don't have to check in
- purely generated code in the folders src-gen or xtend-gen. It makes sense to check them in if you don't want to force users (that includes a CI server) to generated after checking out, or to better track what changes between two generator runs, or to make it easy to revert a change.
I never checked in
- the bin folder as it is really automatically created and populated by Eclipse. Eclipse skip this by default.
Some versioning systems, e.g. git, delete empty folders on checkout. This can cause errors after checkout, e.g. when Eclipse cannot find the src-gen folder you chose not to check in. To avoid that you can add and check in a dummy file in these directories.
Previous Topic:What is the best way to allow xtext work on extensions ignoring case of them
Next Topic:Eclipse Plugin Install Error
Current Time: Sat Jul 26 12:00:08 EDT 2025
Powered by FUDForum. Page generated in 0.09920 seconds
