Home » Language IDEs » ServerTools (WTP) » Not able to start weblogic server in eclipse(I am not able to start weblogic server in eclipse, where as i can start it through Oracle jdeveloper)
Not able to start weblogic server in eclipse [message #1730764] Thu, 28 April 2016 06:43 Go to next message
I am not able to start weblogic server in eclipse, where as i can start it through Oracle jdeveloper.
Configuration: Eclipse Kepler
Oracle Jdeveloper 12c
JDK 1.7
Not able to see any error in eclipse log files.... Sad
Please help me on this.. i have tried a lot over internet, but could not able find any solution Sad .
Thanks in Advance
Here are the log files...
JAVA Memory arguments: -Xms256m -Xmx512m -XX:PermSize=128m -XX:MaxPermSize=512m
CLASSPATH=C:\Oracle\Middleware\Oracle_Home\oracle_common\modules\oracle.jdbc_11.2.0\ojdbc6dms.jar;C:\Oracle\Middleware\Oracle_Home\oracle_common\jdk\lib\tools.jar;C:\Oracle\Middleware\Oracle_Home\wlserver\server\lib\weblogic_sp.jar;C:\Oracle\Middleware\Oracle_Home\wlserver\server\lib\weblogic.jar;C:\Oracle\Middleware\Oracle_Home\wlserver\server\lib\webservices.jar;C:\Oracle\Middleware\Oracle_Home\oracle_common\modules\org.apache.ant_1.7.1/lib/ant-all.jar;C:\Oracle\Middleware\Oracle_Home\oracle_common\modules\net.sf.antcontrib_1.1.0.0_1-0b2/lib/ant-contrib.jar;C:\Oracle\Middleware\Oracle_Home\wlserver\modules\features\oracle.wls.common.nodemanager_1.0.0.0.jar;C:\Oracle\Middleware\Oracle_Home\oracle_common\modules\internal\features\jrf_wlsFmw_oracle.jrf.wls.classpath_12.1.2.jar;C:\Oracle\Middleware\Oracle_Home\oracle_common\modules\com.oracle.cie.config-wls-online_8.0.0.0.jar;C:\Oracle\Middleware\Oracle_Home\wlserver\common\derby\lib\derbynet.jar;C:\Oracle\Middleware\Oracle_Home\wlserver\common\derby\lib\derbyclient.jar;C:\Oracle\Middleware\Oracle_Home\wlserver\common\derby\lib\derby.jar;C:\Oracle\Middleware\Oracle_Home\wlserver\server\lib\xqrl.jar
PATH=;C:\Oracle\Middleware\Oracle_Home\wlserver\server\native\win\32;C:\Oracle\Middleware\Oracle_Home\wlserver\server\bin;C:\Oracle\Middleware\Oracle_Home\oracle_common\modules\org.apache.ant_1.7.1\bin;C:\Oracle\Middleware\Oracle_Home\oracle_common\jdk\jre\bin;C:\Oracle\Middleware\Oracle_Home\oracle_common\jdk\bin;C:\PROGRA~1\Java\jre1.8.0_91\bin\server;C:\PROGRA~1\Java\jre1.8.0_91\bin;C:\PROGRA~1\Java\jre1.8.0_91\lib\amd64;C:\PROGRA~3\Oracle\Java\javapath;C:\PROGRA~1\Java\java8\jdk1.8.0_45\bin;C:\Windows\System32;C:\Windows;C:\Windows\System32\wbem;C:\Windows\System32\WINDOW~1\v1.0\;C:\PROGRA~2\IBM\Client;C:\PROGRA~2\IBM\Client;C:\PROGRA~2\IBM\Client;C:\PROGRA~2\WebEx\Productivity;E:\Deviprasad;C:\Oracle\Middleware\Oracle_Home\wlserver\server\native\win\32\oci920_8
* To start WebLogic Server, use a username and *
* password assigned to an admin-level user. For *
* server administration, use the WebLogic Server *
* console at http:\\hostname:port\console *
starting weblogic with Java version:
java version "1.7.0_15"
Java(TM) SE Runtime Environment (build 1.7.0_15-b33)
Java HotSpot(TM) Client VM (build 23.7-b01, mixed mode)
Starting WLS with line:
C:\Oracle\Middleware\Oracle_Home\oracle_common\jdk\bin\java -client -Xms256m -Xmx512m -XX:PermSize=128m -XX:MaxPermSize=512m -Dweblogic.Name=DefaultServer -Djava.security.policy=C:\Oracle\Middleware\Oracle_Home\wlserver\server\lib\weblogic.policy -Xverify:none -Djava.endorsed.dirs=C:\Oracle\Middleware\Oracle_Home\oracle_common\jdk\jre\lib\endorsed;C:\Oracle\Middleware\Oracle_Home\oracle_common\modules\endorsed -Djava.protocol.handler.pkgs="oracle.mds.net.protocol" -Dopss.version=12.1.2 -Digf.arisidbeans.carmlloc=C:\Users\drajuv\AppData\Roaming\JDeveloper\system12.1.2.0.40.66.68\DefaultDomain\config\fmwconfig\carml -Digf.arisidstack.home=C:\Users\drajuv\AppData\Roaming\JDeveloper\system12.1.2.0.40.66.68\DefaultDomain\config\fmwconfig\arisidprovider -Doracle.security.jps.config=C:\Users\drajuv\AppData\Roaming\JDeveloper\system12.1.2.0.40.66.68\DefaultDomain\config\fmwconfig\jps-config.xml -Doracle.deployed.app.dir=C:\Users\drajuv\AppData\Roaming\JDeveloper\system12.1.2.0.40.66.68\DefaultDomain\servers\DefaultServer\tmp\_WL_user -Doracle.deployed.app.ext=\- -Dweblogic.alternateTypesDirectory=C:\Oracle\Middleware\Oracle_Home\oracle_common\modules\oracle.ossoiap_12.1.2,C:\Oracle\Middleware\Oracle_Home\oracle_common\modules\oracle.oamprovider_12.1.2,C:\Oracle\Middleware\Oracle_Home\oracle_common\modules\oracle.jps_12.1.2 -Doracle.mds.filestore.preferred=true -Dweblogic.jdbc.remoteEnabled=false -Dcommon.components.home=C:\Oracle\Middleware\Oracle_Home\oracle_common -Djrf.version=12.1.2 -Dorg.apache.commons.logging.Log=org.apache.commons.logging.impl.Jdk14Logger -Ddomain.home=C:\Users\drajuv\AppData\Roaming\JDeveloper\system12.1.2.0.40.66.68\DefaultDomain -Doracle.server.config.dir=C:\Users\drajuv\AppData\Roaming\JDeveloper\system12.1.2.0.40.66.68\DefaultDomain\config\fmwconfig\servers\DefaultServer -Doracle.domain.config.dir=C:\Users\drajuv\AppData\Roaming\JDeveloper\system12.1.2.0.40.66.68\DefaultDomain\config\fmwconfig -da -Dwls.home=C:\Oracle\Middleware\Oracle_Home\wlserver\server -Dweblogic.home=C:\Oracle\Middleware\Oracle_Home\wlserver\server -Djps.app.credential.overwrite.allowed=true -Djavax.management.builder.initial=weblogic.management.jmx.mbeanserver.WLSMBeanServerBuilder -Djava.util.logging.manager=oracle.core.ojdl.logging.ODLLogManager weblogic.Server
<Apr 28, 2016 2:33:42 PM IST> <Info> <Security> <BEA-090905> <Disabling the CryptoJ JCE Provider self-integrity check for better startup performance. To enable this check, specify -Dweblogic.security.allowCryptoJDefaultJCEVerification=true.>
<Apr 28, 2016 2:33:44 PM IST> <Info> <Security> <BEA-090906> <Changing the default Random Number Generator in RSA CryptoJ from ECDRBG to FIPS186PRNG. To disable this change, specify -Dweblogic.security.allowCryptoJDefaultPRNG=true.>
<Apr 28, 2016 2:33:46 PM IST> <Info> <WebLogicServer> <BEA-000377> <Starting WebLogic Server with Java HotSpot(TM) Client VM Version 23.7-b01 from Oracle Corporation.>
<Apr 28, 2016 2:33:52 PM IST> <Info> <Management> <BEA-141107> <Version: WebLogic Server 12.1.2.0.0 Fri Jun 7 15:16:15 PDT 2013 1530982 WLS_12.1.2.0.0_GENERIC_130607.1100>
<Apr 28, 2016 2:34:14 PM IST> <Notice> <WebLogicServer> <BEA-000365> <Server state changed to STARTING.>
<Apr 28, 2016 2:34:14 PM IST> <Info> <WorkManager> <BEA-002900> <Initializing self-tuning thread pool.>
<Apr 28, 2016 2:34:17 PM IST> <Notice> <LoggingService> <BEA-320400> <The log file C:\Users\drajuv\AppData\Roaming\JDeveloper\system12.1.2.0.40.66.68\DefaultDomain\servers\DefaultServer\logs\DefaultServer.log will be rotated. Reopen the log file if tailing has stopped. This can happen on some platforms, such as Windows.>
<Apr 28, 2016 2:34:17 PM IST> <Notice> <LoggingService> <BEA-320401> <The log file has been rotated to C:\Users\drajuv\AppData\Roaming\JDeveloper\system12.1.2.0.40.66.68\DefaultDomain\servers\DefaultServer\logs\DefaultServer.log00012. Log messages will continue to be logged in C:\Users\drajuv\AppData\Roaming\JDeveloper\system12.1.2.0.40.66.68\DefaultDomain\servers\DefaultServer\logs\DefaultServer.log.>
<Apr 28, 2016 2:34:17 PM IST> <Notice> <Log Management> <BEA-170019> <The server log file C:\Users\drajuv\AppData\Roaming\JDeveloper\system12.1.2.0.40.66.68\DefaultDomain\servers\DefaultServer\logs\DefaultServer.log is opened. All server side log events will be written to this file.>
Apr 28, 2016 2:34:29 PM oracle.security.jps.JpsStartup start
INFO: Jps started.
Apr 28, 2016 2:34:34 PM oracle.security.jps.internal.idstore.util.LibOvdUtil pushLdapNamesToLibOvd
INFO: Pushed ldap name and types info to libOvd. Ldaps : DefaultAuthenticator:idstore.ldap.provideridstore.ldap.
<Apr 28, 2016 2:34:36 PM IST> <Notice> <Security> <BEA-090082> <Security initializing using security realm myrealm.>
2016-04-28 14:34:49.079/103.732 Oracle Coherence 12.1.2.0.0 <Info> (thread=[ACTIVE] ExecuteThread: '1' for queue: 'weblogic.kernel.Default (self-tuning)', member=n/a): Loaded operational configuration from "jar:file:/C:/Oracle/Middleware/Oracle_Home/coherence/lib/coherence.jar!/tangosol-coherence.xml"
2016-04-28 14:34:49.094/103.747 Oracle Coherence 12.1.2.0.0 <Info> (thread=[ACTIVE] ExecuteThread: '1' for queue: 'weblogic.kernel.Default (self-tuning)', member=n/a): Loaded operational overrides from "jar:file:/C:/Oracle/Middleware/Oracle_Home/coherence/lib/coherence.jar!/tangosol-coherence-override-dev.xml"
2016-04-28 14:34:49.094/103.747 Oracle Coherence 12.1.2.0.0 <D5> (thread=[ACTIVE] ExecuteThread: '1' for queue: 'weblogic.kernel.Default (self-tuning)', member=n/a): Optional configuration override "/tangosol-coherence-override.xml" is not specified
2016-04-28 14:34:49.110/103.763 Oracle Coherence 12.1.2.0.0 <D5> (thread=[ACTIVE] ExecuteThread: '1' for queue: 'weblogic.kernel.Default (self-tuning)', member=n/a): Optional configuration override "cache-factory-config.xml" is not specified
2016-04-28 14:34:49.110/103.763 Oracle Coherence 12.1.2.0.0 <D5> (thread=[ACTIVE] ExecuteThread: '1' for queue: 'weblogic.kernel.Default (self-tuning)', member=n/a): Optional configuration override "cache-factory-builder-config.xml" is not specified
2016-04-28 14:34:49.110/103.763 Oracle Coherence 12.1.2.0.0 <D5> (thread=[ACTIVE] ExecuteThread: '1' for queue: 'weblogic.kernel.Default (self-tuning)', member=n/a): Optional configuration override "/custom-mbeans.xml" is not specified
Oracle Coherence Version 12.1.2.0.0 Build 44396
Grid Edition: Development mode
Copyright (c) 2000, 2013, Oracle and/or its affiliates. All rights reserved.
<Apr 28, 2016 2:34:56 PM IST> <Warning> <com.oracle.coherence> <BEA-000000> <2016-04-28 14:34:56.568/111.221 Oracle Coherence GE 12.1.2.0.0 <Warning> (thread=[ACTIVE] ExecuteThread: '1' for queue: 'weblogic.kernel.Default (self-tuning)', member=n/a): Local address "127.0.0.1" is a loopback address; this cluster node will not connect to nodes located on different machines>
Apr 28, 2016 2:34:58 PM oracle.ods.virtualization.engine.util.VDELogger info
INFO: Notification sent for Mapping config object reloaded
<Apr 28, 2016 2:35:24 PM IST> <Notice> <WebLogicServer> <BEA-000365> <Server state changed to STANDBY.>
<Apr 28, 2016 2:35:24 PM IST> <Notice> <WebLogicServer> <BEA-000365> <Server state changed to STARTING.>
<Apr 28, 2016 2:36:03 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.das.mgr.InvoicingDASMgr.updateInvoiceXceptionLoadDataWithFlag(java.util.List,java.util.List) in EJB InvoicingDASMgr contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingDASMgr has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:03 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract java.util.List com.mcd.invoicing.das.mgr.InvoicingDASMgr.getInvoiceListStandardPaging(com.mcd.das.to.PagingCriteria,java.lang.String) throws javax.ejb.EJBException in EJB InvoicingDASMgr contains a parameter of type com.mcd.das.to.PagingCriteria which is not serializable. Though the EJB InvoicingDASMgr has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:03 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.das.mgr.InvoicingDASMgr.updateAuditorSelection(java.util.List) in EJB InvoicingDASMgr contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingDASMgr has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:03 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.das.mgr.InvoicingDASMgr.terminateUserCrteChgData(java.util.List) in EJB InvoicingDASMgr contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingDASMgr has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:03 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.das.mgr.InvoicingDASMgr.saveOobEmplTransRecCheckItem(java.util.List,java.lang.Long) in EJB InvoicingDASMgr contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingDASMgr has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:03 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.das.mgr.InvoicingDASMgr.saveOobEmplTransRecEquip(java.util.List,java.lang.Long) in EJB InvoicingDASMgr contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingDASMgr has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:03 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.das.mgr.InvoicingDASMgr.updateOobEmplWorkItem(java.util.Map,java.util.List,java.lang.String) in EJB InvoicingDASMgr contains a parameter of type java.util.Map which is not serializable. Though the EJB InvoicingDASMgr has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:03 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.das.mgr.InvoicingDASMgr.updateOobEmplWorkItem(java.util.Map,java.util.List,java.lang.String) in EJB InvoicingDASMgr contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingDASMgr has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:03 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.das.mgr.InvoicingDASMgr.saveOobTrmnPremHrsData(java.util.List,java.lang.Long) in EJB InvoicingDASMgr contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingDASMgr has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:03 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.das.mgr.InvoicingDASMgr.saveAuditorAvailLoadData(java.util.List,java.lang.Long) in EJB InvoicingDASMgr contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingDASMgr has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:03 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract java.util.List com.mcd.invoicing.das.mgr.InvoicingDASMgr.getArChkStatusAgingReport(com.mcd.das.to.PagingCriteria,java.lang.String) in EJB InvoicingDASMgr contains a parameter of type com.mcd.das.to.PagingCriteria which is not serializable. Though the EJB InvoicingDASMgr has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:03 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.das.mgr.InvoicingDASMgr.updateArChkAppliedRpt(java.util.List) in EJB InvoicingDASMgr contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingDASMgr has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:03 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.das.mgr.InvoicingDASMgr.saveHumanTasks(java.util.List) in EJB InvoicingDASMgr contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingDASMgr has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:03 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract java.util.List com.mcd.invoicing.das.mgr.InvoicingDASMgr.getStatusAgingReport(com.mcd.das.to.PagingCriteria,java.lang.String) in EJB InvoicingDASMgr contains a parameter of type com.mcd.das.to.PagingCriteria which is not serializable. Though the EJB InvoicingDASMgr has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:03 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract java.util.List com.mcd.invoicing.das.mgr.InvoicingDASMgr.getPoSearchPageList(com.mcd.das.to.PagingCriteria) in EJB InvoicingDASMgr contains a parameter of type com.mcd.das.to.PagingCriteria which is not serializable. Though the EJB InvoicingDASMgr has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:03 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.das.mgr.InvoicingDASMgr.updateDocumentAtchs(java.util.List,long,java.lang.String,java.lang.String) in EJB InvoicingDASMgr contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingDASMgr has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:03 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.das.mgr.InvoicingDASMgr.saveOrUpdateCarData(com.mcd.das.CompanyCar.vo.CardataIntf) in EJB InvoicingDASMgr contains a parameter of type com.mcd.das.CompanyCar.vo.CardataIntf which is not serializable. Though the EJB InvoicingDASMgr has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:03 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.das.mgr.InvoicingDASMgr.updateCarData(com.mcd.das.CompanyCar.vo.CardataIntf) in EJB InvoicingDASMgr contains a parameter of type com.mcd.das.CompanyCar.vo.CardataIntf which is not serializable. Though the EJB InvoicingDASMgr has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:03 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.das.mgr.InvoicingDASMgr.processDocumentTasks(java.util.List,java.lang.String,java.lang.String,java.util.Date,java.lang.String) in EJB InvoicingDASMgr contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingDASMgr has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:03 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.das.mgr.InvoicingDASMgr.saveOobEmplTransRecPayAdjData(java.util.List,java.lang.Long) in EJB InvoicingDASMgr contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingDASMgr has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:11 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.client.facade.InvoicingFacade.updateInvoiceXceptionLoadDataWithFlag(java.util.List,java.util.List) in EJB InvoicingFacade contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingFacade has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:11 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract java.util.List com.mcd.invoicing.client.facade.InvoicingFacade.getInvoiceListStandardPaging(com.mcd.das.to.PagingCriteria,java.lang.String) throws javax.ejb.EJBException in EJB InvoicingFacade contains a parameter of type com.mcd.das.to.PagingCriteria which is not serializable. Though the EJB InvoicingFacade has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:11 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.client.facade.InvoicingFacade.updateAuditorSelection(java.util.List) throws javax.ejb.EJBException in EJB InvoicingFacade contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingFacade has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:11 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.client.facade.InvoicingFacade.terminateUserCrteChgData(java.util.List) in EJB InvoicingFacade contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingFacade has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:11 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.client.facade.InvoicingFacade.saveOobEmplTransRecCheckItem(java.util.List,java.lang.Long) in EJB InvoicingFacade contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingFacade has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:11 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.client.facade.InvoicingFacade.saveOobEmplTransRecEquip(java.util.List,java.lang.Long) in EJB InvoicingFacade contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingFacade has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:11 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.client.facade.InvoicingFacade.updateOobEmplWorkItem(java.util.Map,java.util.List,java.lang.String) in EJB InvoicingFacade contains a parameter of type java.util.Map which is not serializable. Though the EJB InvoicingFacade has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:11 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.client.facade.InvoicingFacade.updateOobEmplWorkItem(java.util.Map,java.util.List,java.lang.String) in EJB InvoicingFacade contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingFacade has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:11 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.client.facade.InvoicingFacade.saveOobTrmnPremHrsData(java.util.List,java.lang.Long) in EJB InvoicingFacade contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingFacade has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:11 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.client.facade.InvoicingFacade.saveAuditorAvailLoadData(java.util.List,java.lang.Long) in EJB InvoicingFacade contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingFacade has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:11 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract java.util.List com.mcd.invoicing.client.facade.InvoicingFacade.getArChkStatusAgingReport(com.mcd.das.to.PagingCriteria,java.lang.String) in EJB InvoicingFacade contains a parameter of type com.mcd.das.to.PagingCriteria which is not serializable. Though the EJB InvoicingFacade has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:11 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.client.facade.InvoicingFacade.updateArChkAppliedRpt(java.util.List) in EJB InvoicingFacade contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingFacade has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:11 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract java.util.List com.mcd.invoicing.client.facade.InvoicingFacade.getStatusAgingReport(com.mcd.das.to.PagingCriteria,java.lang.String) in EJB InvoicingFacade contains a parameter of type com.mcd.das.to.PagingCriteria which is not serializable. Though the EJB InvoicingFacade has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:11 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract java.util.List com.mcd.invoicing.client.facade.InvoicingFacade.getPoSearchPageList(com.mcd.das.to.PagingCriteria) in EJB InvoicingFacade contains a parameter of type com.mcd.das.to.PagingCriteria which is not serializable. Though the EJB InvoicingFacade has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:11 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.client.facade.InvoicingFacade.updateDocumentAtchs(java.util.List,long,java.lang.String,java.lang.String) in EJB InvoicingFacade contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingFacade has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:11 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.client.facade.InvoicingFacade.saveOrUpdateCarData(com.mcd.das.CompanyCar.vo.CardataIntf) in EJB InvoicingFacade contains a parameter of type com.mcd.das.CompanyCar.vo.CardataIntf which is not serializable. Though the EJB InvoicingFacade has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:11 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.client.facade.InvoicingFacade.updateCarData(com.mcd.das.CompanyCar.vo.CardataIntf) in EJB InvoicingFacade contains a parameter of type com.mcd.das.CompanyCar.vo.CardataIntf which is not serializable. Though the EJB InvoicingFacade has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:11 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.client.facade.InvoicingFacade.processDocumentTasks(java.util.List,java.lang.String,java.lang.String,java.util.Date,java.lang.String) in EJB InvoicingFacade contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingFacade has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:11 PM IST> <Warning> <EJB> <BEA-012035> <The Remote interface method: public abstract void com.mcd.invoicing.client.facade.InvoicingFacade.saveOobEmplTransRecPayAdjData(java.util.List,java.lang.Long) in EJB InvoicingFacade contains a parameter of type java.util.List which is not serializable. Though the EJB InvoicingFacade has call-by-reference set to false, this parameter is not serializable and hence will be passed by reference. A parameter can be passed using call-by-value only if the parameter type is serializable.>
<Apr 28, 2016 2:36:21 PM IST> <Warning> <oracle.adf.share.logging.internal.perf.SensorTable> <BEA-000000> <Detected that sensors created in an invalid ADFContext were later visible in a valid ADFContext. The sensors should be created in a valid ADFContext. Please enable finest logging for more information.>
<Apr 28, 2016 2:36:38 PM IST> <Notice> <LoggingService> <BEA-320400> <The log file C:\Users\drajuv\AppData\Roaming\JDeveloper\system12.1.2.0.40.66.68\DefaultDomain\servers\DefaultServer\logs\DefaultDomain.log will be rotated. Reopen the log file if tailing has stopped. This can happen on some platforms, such as Windows.>
<Apr 28, 2016 2:36:38 PM IST> <Notice> <LoggingService> <BEA-320401> <The log file has been rotated to C:\Users\drajuv\AppData\Roaming\JDeveloper\system12.1.2.0.40.66.68\DefaultDomain\servers\DefaultServer\logs\DefaultDomain.log00012. Log messages will continue to be logged in C:\Users\drajuv\AppData\Roaming\JDeveloper\system12.1.2.0.40.66.68\DefaultDomain\servers\DefaultServer\logs\DefaultDomain.log.>
<Apr 28, 2016 2:36:38 PM IST> <Notice> <Log Management> <BEA-170027> <The server has successfully established a connection with the Domain level Diagnostic Service.>
<Apr 28, 2016 2:36:39 PM IST> <Notice> <WebLogicServer> <BEA-000365> <Server state changed to ADMIN.>
<Apr 28, 2016 2:36:39 PM IST> <Notice> <WebLogicServer> <BEA-000365> <Server state changed to RESUMING.>
<Apr 28, 2016 2:36:40 PM IST> <Notice> <Security> <BEA-090171> <Loading the identity certificate and private key stored under the alias DemoIdentity from the kss keystore file kss://system/demoidentity.>
<Apr 28, 2016 2:36:44 PM IST> <Notice> <Security> <BEA-090169> <Loading trusted certificates from the kss keystore file kss://system/trust.>
<Apr 28, 2016 2:36:44 PM IST> <Notice> <Server> <BEA-002613> <Channel "DefaultSecure" is now listening on 127.0.0.1:7102 for protocols iiops, t3s, ldaps, https.>
<Apr 28, 2016 2:36:44 PM IST> <Notice> <Server> <BEA-002613> <Channel "Default" is now listening on 127.0.0.1:7101 for protocols iiop, t3, ldap, snmp, http.>
<Apr 28, 2016 2:36:44 PM IST> <Notice> <WebLogicServer> <BEA-000331> <Started the WebLogic Server Administration Server "DefaultServer" for domain "DefaultDomain" running in development mode.>
<Apr 28, 2016 2:36:44 PM IST> <Notice> <WebLogicServer> <BEA-000365> <Server state changed to RUNNING.>
<Apr 28, 2016 2:36:44 PM IST> <Notice> <WebLogicServer> <BEA-000360> <The server started in RUNNING mode.>
Re: Not able to start weblogic server in eclipse [message #1730790 is a reply to message #1730764] Thu, 28 April 2016 09:35 Go to previous messageGo to next message
> JDK 1.7
> Not able to see any error in eclipse log files.... :( Please help me on
> solution :( .
> Thanks in Advance
You might try the Eclipse web tools platform (WTP) forum for more and
better help on this.
Re: Not able to start weblogic server in eclipse [message #1730800 is a reply to message #1730790] Thu, 28 April 2016 10:38 Go to previous messageGo to next message
Thanks for the Reply Russel. Actually i have raised a ticket earlier for the same issue under WTP but did not any help.
Subject: Server Oracle Weblogic Server 12c (12.1.2) at localhost [Default Domain] failed to start - is the ticket FYR..
Re: Not able to start weblogic server in eclipse [message #1731034 is a reply to message #1730800] Mon, 02 May 2016 08:28 Go to previous message
In this scenario, server started successfully it seems but, in eclipse it's showing "weblogic server failed to start at localhost [default domain]"..
any guess.. why it's failing
Previous Topic:standardjs.com eslint configuration?
Next Topic:err_connection_refused
Current Time: Sat Jul 26 21:00:04 EDT 2025
Powered by FUDForum. Page generated in 0.04727 seconds
