Home » Language IDEs » C / C++ IDE (CDT) » uncommon paths for environment-directory
uncommon paths for environment-directory [message #173047] Mon, 17 July 2006 09:03 Go to next message
Hi all,
I am not sure the previous message is received by newsgroup because I
don't see it here. If I am wrong please ignore this one.
I use Windows and GNUARM distribution.
Depend on one message in this group I changed in the file
org.eclipse.cdt.debug.mi.core/plugin.xml all cpu settings from "native" to
"*" because error "CPU don't supported"
Now CDT don't have this error and starts the debugger. But the debugger
stopps the debug session with error:
Execution is suspended because of error.
Don't know how to run. Try "help target".
With verbose mode for GDB Console I have log the communication between
Eclipse and arm-elf-gdb.
The paths in the environment-directory seems uncommon for me. Is it
possibly the problem?
Hier is the log data:
1-gdb-set confirm off
1^done,address="0x40000020",load-size="2446",transfer-rate= "179522",write-rate="815"
(gdb)
2-gdb-set width 0
2^done
(gdb)
3-gdb-set height 0
3^done
(gdb)
4-interpreter-exec console echo
4^done
(gdb)
5-gdb-show prompt
5^done,value="(gdb) "
(gdb)
6-gdb-set new-console
&"No symbol \"new\" in current context.\n"
No symbol "new" in current context.
6^error,msg="No symbol \"new\" in current context."
(gdb)
7-gdb-set new-console
7^error,msg="No symbol \"new\" in current context."
(gdb)
8-environment-cd C:\\embedded\\workarm\\sample320
8^done
(gdb)
9-environment-directory C /embedded/workarm/sample320;C
/embedded/workarm/sample320/.settings;C
/embedded/workarm/sample320/Cfg-Debug-FLASH;C
/embedded/workarm/sample320/Cfg-Debug-FLASH/lib;C
/embedded/workarm/sample320/Cfg-Debug-FLASH/src;C
/embedded/workarm/sample320/Cfg-Debug-XRAM;C
/embedded/workarm/sample320/Cfg-Debug-XRAM/lib;C
/embedded/workarm/sample320/Cfg-Debug-XRAM/src;C
/embedded/workarm/sample320/inc;C /embedded/workarm/sample320/lib;C
/embedded/workarm/sample320/src;C
&"Warning: /embedded/workarm/sample320/src;C: No such file or directory.\n"
&"Warning: /embedded/workarm/sample320/lib;C: No such file or directory.\n"
&"Warning: /embedded/workarm/sample320/inc;C: No such file or directory.\n"
Warning: /embedded/workarm/sample320/Cfg-Debug-XRAM/src;C: No such file or
directory.
Warning: /embedded/workarm/sample320/Cfg-Debug-XRAM/lib;C: No such file or
directory.
Warning: /embedded/workarm/sample320/Cfg-Debug-XRAM;C: No such file or
directory.
Warning: /embedded/workarm/sample320/Cfg-Debug-FLASH/src;C: No such file
or directory.
Warning: /embedded/workarm/sample320/Cfg-Debug-FLASH/lib;C: No such file
or directory.
Warning: /embedded/workarm/sample320/Cfg-Debug-FLASH;C: No such file or
directory.
Warning: /embedded/workarm/sample320/.settings;C: No such file or
directory.
Warning: /embedded/workarm/sample320;C: No such file or directory.
Warning: /cygdrive/c/embedded/workarm/sample320/C: No such file or
directory.
&"Warning: /embedded/workarm/sample320/Cfg-Debug-XRAM/src;C: No such file
or directory.\n"
&"Warning: /embedded/workarm/sample320/Cfg-Debug-XRAM/lib;C: No such file
or directory.\n"
&"Warning: /embedded/workarm/sample320/Cfg-Debug-XRAM;C: No such file or
directory.\n"
&"Warning: /embedded/workarm/sample320/Cfg-Debug-FLASH/src;C: No such file
or directory.\n"
&"Warning: /embedded/workarm/sample320/Cfg-Debug-FLASH/lib;C: No such file
or directory.\n"
&"Warning: /embedded/workarm/sample320/Cfg-Debug-FLASH;C: No such file or
directory.\n"
&"Warning: /embedded/workarm/sample320/.settings;C: No such file or
directory.\n"
&"Warning: /embedded/workarm/sample320;C: No such file or directory.\n"
&"Warning: /cygdrive/c/embedded/workarm/sample320/C: No such file or
directory.\n"
9^done,source-path=" /cygdrive/c/embedded/workarm/sample320/C:/embedded/workarm/s ample320;C:/embedded/workarm/sample320/.settings;C:/embedded /workarm/sample320/Cfg-Debug-FLASH;C:/embedded/workarm/sampl e320/Cfg-Debug-FLASH/lib;C:/embedded/workarm/sample320/Cfg-D ebug-FLASH/src;C:/embedded/workarm/sample320/Cfg-Debug-XRAM; C:/embedded/workarm/sample320/Cfg-Debug-XRAM/lib;C:/embedded /workarm/sample320/Cfg-Debug-XRAM/src;C:/embedded/workarm/sa mple320/inc;C:/embedded/workarm/sample320/lib;C:/embedded/wo rkarm/sample320/src;C:$cdir:$cwd "
(gdb)
10 info threads
&"info threads\n"
~"* 1 thread 1 (1230) 0x40000020 in start ()\n"
10^done
(gdb)
11-data-list-register-names
11^done,register-names=["r0","r1","r2","r3","r4","r5 ","r6","r7","r8","r9","r10","r11","r12","sp", "lr","pc","f0","f1","f2","f3","f4","f5","f6", "f7","fps","cpsr"]
(gdb)
12-break-insert -t main
12^done,bkpt={number="1",type="breakpoint",disp="del",enabled= "y",addr="0x80000318",func="main",file="../src/main.c",line= "90",times="0"}
(gdb)
13-exec-run
13^running
(gdb)
&"Don't know how to run. Try \"help target\".\n"
13^error,msg="Don't know how to run. Try \"help target\"."
(gdb)
14 info program
&"info program\n"
~"The program being debugged is not being run.\n"
14^done
(gdb)
15 info threads
&"info threads\n"
&"No registers.\n"
15^done
(gdb)
16-stack-info-depth
&"No registers.\n"
16^error,msg="No registers."
(gdb)
17-stack-info-depth
No registers.
&"No registers.\n"
17^error,msg="No registers."
(gdb)
18-data-list-changed-registers
No registers.
No registers.
&"No registers.\n"
18^error,msg="No registers."
(gdb)
19-stack-info-depth
&"No registers.\n"
No registers.
19^error,msg="No registers."
(gdb)
20-stack-info-depth
&"No registers.\n"
No registers.
20^error,msg="No registers."
(gdb)
Re: uncommon paths for environment-directory [message #173176 is a reply to message #173047] Tue, 18 July 2006 02:07 Go to previous message
efim,
I can see your previous message too.
I think this is that eclipse is giving the paths to gdb in windows style,
but the cygwin based gdb cannot handle this. Get Zylin's patched version of
the CDT, it contains a fix for this, too. (www.zylin.com)
HTH
Norbert
Previous Topic:errorparser
Next Topic:How to parse an external CPP file to get include statements?
Current Time: Thu Nov 06 12:09:02 EST 2025
Powered by FUDForum. Page generated in 0.04094 seconds
