| Home » Archived » Eclipse Communications Framework (ECF) » I lose osgi remote service
 Goto Forum:|
|  I lose osgi remote service [message #1730264] | Fri, 22 April 2016 16:47  |  |
| Eclipse User  |  |  |  |  | Hey everyone, I want to use remote services in an OSGI environment. So I decided to handle this with eclipse ECF. In my opinion a very good project to deal with OSGI remote services. So for the discovery provider I use Zoodiscovery. The services are registered with generic service property. Furthermore, Zoodiscovery is used in centralized mode and the central IP is published with a network broadcast. I got everything to work. But after a period of time the service consumer loses the remote service.
 This message is shown when the remote service is discovered:
[log;+0000 2016.04.22 15:26:03:564;DEBUG;org.eclipse.ecf.provider.zookeeper;Service Discovered: ServiceInfo[uri=ecfosgirsvc://192.168.178.21:32565/osgirsvc_AMIsPeVObufIp5v5cV6pHNIvzGM=;id=ServiceID[type=ServiceTypeID[typeName=_ecfosgirsvc._default.default._iana];location=ecfosgirsvc://192.168.178.21:32565/osgirsvc_AMIsPeVObufIp5v5cV6pHNIvzGM=;full=_ecfosgirsvc._default.default._iana@ecfosgirsvc://192.168.178.21:32565/osgirsvc_AMIsPeVObufIp5v5cV6pHNIvzGM=];priority=0;weight=0;props=ServiceProperties[{objectClass=de.custom.service.api.IManagerService, endpoint.id=e9dc7ac1-708d-43a6-b2fa-539beff6c732, remote.intents.supported=passByValue exactlyOnce ordered, ecf.endpoint.id=ecftcp://192.168.178.21:2121/server, ecf.rsvc.id=3, endpoint.service.id=174, service.imported.configs=ecf.generic.server, ecf.endpoint.ts=1461329304080, ecf.generic.server.hostname=192.168.178.21, ecf.endpoint.id.ns=org.eclipse.ecf.core.identity.StringID, remote.configs.supported=ecf.generic.server, endpoint.package.version.de.custom.api=1.0.0, endpoint.framework.uuid=70eaf65a-8608-0016-13af-dcea8562a726}]]]This message is shown when the remote service is undiscovered:
 [log;+0000 2016.04.22 15:28:53:125;DEBUG;org.eclipse.ecf.provider.zookeeper;Service Undiscovered: ServiceInfo[uri=ecfosgirsvc://192.168.178.21:32565/osgirsvc_AMIsPeVObufIp5v5cV6pHNIvzGM=;id=ServiceID[type=ServiceTypeID[typeName=_ecfosgirsvc._default.default._iana];location=ecfosgirsvc://192.168.178.21:32565/osgirsvc_AMIsPeVObufIp5v5cV6pHNIvzGM=;full=_ecfosgirsvc._default.default._iana@ecfosgirsvc://192.168.178.21:32565/osgirsvc_AMIsPeVObufIp5v5cV6pHNIvzGM=];priority=0;weight=0;props=ServiceProperties[{objectClass=de.custom.service.api.IManagerService, endpoint.id=e9dc7ac1-708d-43a6-b2fa-539beff6c732, remote.intents.supported=passByValue exactlyOnce ordered, ecf.endpoint.id=ecftcp://192.168.178.21:2121/server, ecf.rsvc.id=3, endpoint.service.id=174, service.imported.configs=ecf.generic.server, ecf.endpoint.ts=1461329304080, ecf.generic.server.hostname=192.168.178.21, ecf.endpoint.id.ns=org.eclipse.ecf.core.identity.StringID, remote.configs.supported=ecf.generic.server, endpoint.package.version.de.custom.api=1.0.0, endpoint.framework.uuid=70eaf65a-8608-0016-13af-dcea8562a726}]]]
 BUT: On host system everything is fine and the service is online. If I restart the OSGI framework on consumer side everything works fine again until this Undiscovery event. The period of time between discovery and undiscovery is equal of length.
 It seems as if there is a timeout undiscovering the service. If I use the service by calling a method there is no different behaviour. Has anyone an idea what's going on?
 I know that posting same problematic on different forums is not a good idea, but in my opinion this form (which I recognized later :: sorry for that!) is the better one for my question, so I decided to post my problem here in this forum, too.
 Thank you for help and bet regards!
| Re: I lose osgi remote service [message #1730426 is a reply to message #1730410] | Mon, 25 April 2016 13:21  |  |
| Eclipse User  |  |  |  |  | Tobias Pyttel wrote on Mon, 25 April 2016 10:33 So after a period of time I found the solution!
 It was very simple: I enabled full debug logging with VM parameter
 with root in INFO mode:-Dlog4j.configuration=file:/file/path/to/logging/log4j.properties
 log4j.rootLogger=INFO,stdout
log4j.logger.com.endeca=DEBUG
# Logger for crawl metrics
log4j.logger.com.endeca.itl.web.metrics=DEBUG
log4j.appender.stdout=org.apache.log4j.ConsoleAppender
log4j.appender.stdout.layout=org.apache.log4j.PatternLayout
log4j.appender.stdout.layout.ConversionPattern=%p\t%d{ISO8601}\t%r\t%c\t[%t]\t%m%n
 This displayed the client session timeout when the remote service was undiscovered (it was set to 4000ms). So after a lot if trial and error the update of network card driver was the solution.
 But another point: After dealing with ECF OSGI remote services (Zoodiscovery / generic) I would like to share my experience with a full sample tutorial where I want to show how I made two standalone OSGI Frameworks communicating to each other in a private network on different machines and OS (Windows and Debian) with help of OSGI remote service and ECF. I had some problems with DNS settings and some other stuff which maybe can help other people get their projects done quicker. So where, in your opinion, is the best location to do so?
 Best regards!
 Hi Tobias.
 As Wim says, you would be most welcome to add a tutorial to the Tutorials section on the ECF wiki:
 https://wiki.eclipse.org/Eclipse_Communication_Framework_Project#Tutorials
 To do this you need to have a login to the wiki (to edit).  If you don't already have one you can get one here:
 https://dev.eclipse.org/site_login/createaccount.php
 Also, it might be a good idea to join the ecf-dev mailing list:
 https://dev.eclipse.org/mailman/listinfo/ecf-dev
 and I would suggest announcing that you are creating such a tutorial on that list.   There may be others that would help with the tutorial creation, formatting, and/or review (I'm certainly one of those...I will help you get things figured out, and help with content and/or references if you would like it).
 Glad to hear you are having success using ECF.  BTW, you might want to check out some of the other distribution providers (websockets, jax-rs, hazelcast, activemq, etc), discovery providers (etcd), and other goodies like the ServiceRegistry work (java-only remote services):   https://github.com/ECF/ServiceRegistry at https://github.com/ECF
 Thanks...and if you have any technical questions, directional/plan questions, etc., please post to the mailing list.
 Scott
 Current Time: Fri Oct 31 15:09:30 EDT 2025
 Powered by FUDForum . Page generated in 0.05536 seconds |
