Home » Modeling » TMF (Xtext) » CDT-like Hovers
CDT-like Hovers [message #1730205] Fri, 22 April 2016 06:31 Go to next message
I'd like to have "CDT-like" hovers.
Basically it's useful on cross-references to show the cross-reference target (and a bit more of its surroundings) without having to ctrl-click to it.
Could this be done with the EmbeddedEditor ?
Re: CDT-like Hovers [message #1730207 is a reply to message #1730205] Fri, 22 April 2016 06:41 Go to previous messageGo to next message
Is this about implementing the hovers or not getting hovers in the embedded
editor
Re: CDT-like Hovers [message #1730209 is a reply to message #1730207] Fri, 22 April 2016 07:05 Go to previous messageGo to next message
in normal editors xtext uses MultiLineCommentDocumentationProvider
of course you could customize this as use node model to get "the code"
Re: CDT-like Hovers [message #1730221 is a reply to message #1730209] Fri, 22 April 2016 08:16 Go to previous messageGo to next message
Sorry I wasn't clear, the goal is not to have Hovers in the embedded editor but to have hovers in a normal editor but hovers containing an embedded editor of the cross reference target.
Re: CDT-like Hovers [message #1730222 is a reply to message #1730221] Fri, 22 April 2016 08:18 Go to previous messageGo to next message
why embedded editor in the hover? to actually edit it? or just to display the code?
Re: CDT-like Hovers [message #1730231 is a reply to message #1730222] Fri, 22 April 2016 09:07 Go to previous messageGo to next message
Just to display.
I was thinking of the EmbeddedEditor as I saw this presentation and also because this would probably be less work than transforming everything to html.
[Updated on: Fri, 22 April 2016 09:07] by Moderator
Re: CDT-like Hovers [message #1730232 is a reply to message #1730231] Fri, 22 April 2016 09:08 Go to previous messageGo to next message
Just take the node models text and wrap it into a pre tag should be a one
liner
Re: CDT-like Hovers [message #1730249 is a reply to message #1730232] Fri, 22 April 2016 11:12 Go to previous messageGo to next message
Sure but then I won't have any highlighting
Re: CDT-like Hovers [message #1730250 is a reply to message #1730249] Fri, 22 April 2016 11:24 Go to previous messageGo to next message
Yes that's right
You may digg into hovercontrolcreator. And replace the browser info control
with a sourceviewerinformationcontrol or whatever
Re: CDT-like Hovers [message #1730474 is a reply to message #1730250] Tue, 26 April 2016 03:43 Go to previous messageGo to next message
Managed to make it work with a sourceviewerinformationcontrol, I just miss the semantic highlighting for the moment
Re: CDT-like Hovers [message #1730476 is a reply to message #1730474] Tue, 26 April 2016 04:12 Go to previous message
you should be able to install that as well.
Previous Topic:Problem with number sign
Next Topic:Serializing & case-insensitive languages (java.lang.RuntimeException: Could not serialize EObjec
Current Time: Mon Jul 21 10:18:51 EDT 2025
Powered by FUDForum. Page generated in 0.07338 seconds
