Home » Eclipse Projects » Plugin Development Environment (PDE) » exporting plugin and extensions issues
exporting plugin and extensions issues [message #68631] Wed, 22 July 2009 05:41 Go to next message
I hava a extension for a popup menu in my plugin. When I launch a eclipse
instance to test the plugin, the popop menu is added as I want. But, if I
export the plugin, the extension desappear.
Can somebody tell me what I should do to keep my popup menu extension when
I export the plugin?
thank
Gloria.
Re: exporting plugin and extensions issues [message #68725 is a reply to message #68631] Wed, 22 July 2009 05:56 Go to previous messageGo to next message
Originally posted by: aurelien.pupier.esial.net
gloria guitteaud a écrit :
> Hello,
> eclipse instance to test the plugin, the popop menu is added as I want.
> But, if I export the plugin, the extension desappear.
> when I export the plugin?
> thank
> Gloria.
Hi gloria,
it can come from several kind of issues :
- the plugin.xml is not include in the bin build properties (Is your another Extension points works?)
- dependence is not satisfied (Other of your feature works?)
- there is an exception : look in your error log
Aurelien
Re: exporting plugin and extensions issues [message #68781 is a reply to message #68725] Wed, 22 July 2009 08:46 Go to previous messageGo to next message
hello Aurelien,
I didn't have no error log, the exportation ran successfully.
Then, I tried to include the 'bin' folder in the binary build before
exportation and worked very well.
So I thank you a lot.
Gloria
Re: exporting plugin and extensions issues [message #599774 is a reply to message #68631] Wed, 22 July 2009 05:56 Go to previous messageGo to next message
> Hello,
> thank
> Gloria.
Hi gloria,
Aurelien
Re: exporting plugin and extensions issues [message #599799 is a reply to message #68725] Wed, 22 July 2009 08:46 Go to previous messageGo to next message
hello Aurelien,
Gloria
Re: exporting plugin and extensions issues [message #1730159 is a reply to message #68781] Thu, 21 April 2016 17:45 Go to previous message
I had the same problem and the solution was to move from JavaSE-1.8 to JavaSE.1.7
Previous Topic:How to get focus to an editor?
Next Topic:Standalone junit tests in plug-in projects and transitive dependencies
Current Time: Thu Sep 18 20:09:36 EDT 2025
Powered by FUDForum. Page generated in 0.05047 seconds
