Providing text through JavaScript [message #1729594] |
Fri, 15 April 2016 14:04  |
i have created a Xtext web application (version 2.9).
The ace editor library is been used for inserting text thru the persistent layer.
My next step is to provide text direct to the server but i am a little bit confused on how to do that.
kind regards
[Updated on: Thu, 20 May 2021 11:05] by Moderator
Re: Providing text through JavaScript [message #1729597 is a reply to message #1729595] |
Fri, 15 April 2016 14:40   |
Hi Christian ,
I have tried to send a http request but without luck
I used 'PUT' method with parameters uri, url and Data .
js code:
var uri = resource_id();
var url = "http://localhost:8080/xtext-service/update?resource="+uri+".edl";
var method = "PUT";
var postData = "deltaOffset=0&deltaText=Experiment&deltaReplaceLength=0&requiredStateId=-"+resource_cntdown();
var async = true;
var request = new XMLHttpRequest();
request.onload = function () {
var status = request.status; // HTTP response status, e.g., 200 for "200 OK"
var data = request.responseText; // Returned data, e.g., an HTML document.
request.open(method, url, async);
request.setRequestHeader("Content-Type", "application/x-www-form-urlencoded; charset=UTF-8"); //application/json;charset=UTF-8
request.send(postData);
kind regards
Re: Providing text through JavaScript [message #1729826 is a reply to message #1729598] |
Tue, 19 April 2016 07:53   |
Hi Christian ,
i have visited the above link (https://www.eclipse.org/forums/index.php?t=msg&th=781817&goto=1722463&#msg_1722463) and have adopted the POST code of the latter .
My Code
require(["../webjars/jquery/2.1.4/jquery.min"], function() {
jQuery(document).ready(function() {
jQuery("#post").click(function(e){
set_resource=$("#post_area_2").val(); // get text of from postarea_2
var data = {
resource : set_resource,
fullText : $("#post_area_1").val()
jQuery.post('http://localhost:8080/xtext-service/generate', data, function(result){
jQuery("#generator-result").text(result);
alert('http://localhost:8080/xtext-service/generate data resource = '
+ data.resource +" data.fullText = "+ data.fullText );
<textarea id="post_area_1" rows="1" cols="10">My Post message </textarea>
<textarea id= "post_area_2" rows="1" cols="5"> </textarea>
<button id="post" value="Generate" title="Generate">Post</button>
<div id="generator-result"></div>
While posting a message, i get the following errors from the server
i) 400 error, when i set my variable set_resource = "(whatever)"
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8"/>
<title>Error 400 Unable to identify the Xtext language.</title>
</head>
<body><h2>HTTP ERROR 400</h2>
<p>Problem accessing /xtext-service/generate. Reason:
<pre> Unable to identify the Xtext language.</pre></p><hr><i><small>Powered by Jetty://</small></i><hr/>
</body>
</html>
ii) 500 error, when i set my variable set_resource = "(the resource_id)"
By the way the resource_id is been used from the xtext during update and validation, and changes after the web page is been "refreshed" (F5). The resource id consist of 8 hexadecimals numbers and the edl extension. For example one resource_id should look like this one --> 9a8d7e12.edl
<html>
<head>
<title>Error 500 Server Error</title>
</head>
<body><h2>HTTP ERROR 500</h2>
<pre> Server Error</pre></p><h3>Caused by:</h3><pre>java.lang.NullPointerException
at eu.rawfie.edlWeb.generator.EdlGenerator.doGenerate(EdlGenerator.java:63)
at org.eclipse.xtext.generator.GeneratorDelegate.doGenerate(GeneratorDelegate.java:43)
at org.eclipse.xtext.generator.GeneratorDelegate.generate(GeneratorDelegate.java:34)
at org.eclipse.xtext.web.server.generator.GeneratorService.compute(GeneratorService.java:125)
at org.eclipse.xtext.web.server.generator.GeneratorService.compute(GeneratorService.java:47)
at org.eclipse.xtext.web.server.model.XtextWebDocumentAccess$5.exec(XtextWebDocumentAccess.java:342)
at org.eclipse.xtext.web.server.model.XtextWebDocumentAccess$5.exec(XtextWebDocumentAccess.java:334)
at org.eclipse.xtext.util.concurrent.CancelableUnitOfWork.exec(CancelableUnitOfWork.java:26)
at org.eclipse.xtext.web.server.model.XtextWebDocumentAccess.doAccess(XtextWebDocumentAccess.java:213)
at org.eclipse.xtext.web.server.model.XtextWebDocumentAccess.readOnly(XtextWebDocumentAccess.java:163)
at org.eclipse.xtext.web.server.model.XtextWebDocumentAccess.getCachedServiceResult(XtextWebDocumentAccess.java:346)
at org.eclipse.xtext.web.server.model.AbstractCachedService.getResult(AbstractCachedService.java:27)
at org.eclipse.xtext.web.server.generator.GeneratorService.getArtifact(GeneratorService.java:150)
at org.eclipse.xtext.web.server.XtextServiceDispatcher$16$1.apply(XtextServiceDispatcher.java:885)
at org.eclipse.xtext.web.server.XtextServiceDispatcher$16$1.apply(XtextServiceDispatcher.java:880)
at org.eclipse.xtext.web.servlet.XtextServlet.doService(XtextServlet.java:231)
at org.eclipse.xtext.web.servlet.XtextServlet.doPost(XtextServlet.java:188)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at org.eclipse.xtext.web.servlet.XtextServlet.service(XtextServlet.java:60)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:808)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:587)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
at org.eclipse.jetty.server.Server.handle(Server.java:499)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)
</pre>
</body>
</html>
Best Regards
[Updated on: Thu, 20 May 2021 11:04] by Moderator
FUDForum. Page generated in 0.05745 seconds
