Home » Eclipse Projects » BPMN 2.0 Modeler » How do I create a custom editor with the BPMN2 Modeler?
How do I create a custom editor with the BPMN2 Modeler? [message #1729946] Wed, 20 April 2016 08:39 Go to next message
I have added a new Work Definitions which gets picked up under Custom Tasks in the editor:
    "name" : "BooleanQuestion",
    "parameters" : [
        "Question" : new StringDataType()
    "displayName" : "Yes/No Question",
    "eclipse:customEditor" : "com.common.workeditor.MyWorkEditor"
The editor I have defined looks like this:
public class MyWorkEditor extends Dialog implements WorkEditor {
	private final String title = "My editor";
    protected MyWorkEditor(Shell parentShell) {
		super(parentShell);
		throw new RuntimeException("sad");
    protected void configureShell(Shell newShell) {
    	super.configureShell(newShell);
    	newShell.setText(title);
    protected Control createDialogArea(Composite parent) {
        Composite composite = (Composite) super.createDialogArea(parent);
        GridLayout gridLayout = new GridLayout();
        gridLayout.numColumns = 2;
        composite.setLayout(gridLayout);
        //Work work = (Work) getValue();
        Label nameLabel = new Label(composite, SWT.NONE);
        nameLabel.setText("Name: "); //$NON-NLS-1$
        nameLabel.setLayoutData(new GridData(SWT.LEFT, SWT.TOP, false, false, 1, 1));
        Text nameText = new Text(composite, SWT.NONE);
        nameText.setEditable(false);
        nameText.setLayoutData(new GridData(SWT.FILL, SWT.TOP, true, false, 1, 1));
        String name = "MyName";
        nameText.setText(name == null ? "" : name); //$NON-NLS-1$
        return composite;
	public void setWorkDefinition(WorkDefinition definition) {
		// TODO Auto-generated method stub
	public void setWork(Work work) {
	public boolean show() {
		int result = open();
        return result == OK;
	public Work getWork() {
		return null;
Using the old Drools plugin for Eclipse I could simply double click the node and use a custom editor (not this exact one, but in similar). However, double clicking my Yes/No Question doesn't do anything. Am I on the wrong path here?
Re: How do I create a custom editor with the BPMN2 Modeler? [message #1729970 is a reply to message #1729946] Wed, 20 April 2016 11:36 Go to previous messageGo to next message
Hi Jonas,
I'm sorry, but the ability to provide your own custom editor is not yet implemented. Instead, the parameters will appear in the "Custom Task" tab of the property sheet, for example:
http://content.screencast.com/users/BobBrodt/folders/Jing/media/b63c6b39-659e-43c5-b034-fe46aecbf1a5/2016-04-20_0934.png
If you absolutely must have this functionality, please file an enhancement request - we'll try to get it into the next Neon release.
Bob
Re: How do I create a custom editor with the BPMN2 Modeler? [message #1730082 is a reply to message #1729970] Thu, 21 April 2016 06:06 Go to previous message
Hi, and thanks for your reply Bob!
Yes, we have some properties which requires a custom editor to allow us to migrate to this plugin. I found https://bugs.eclipse.org/bugs/show_bug.cgi?id=373068 on the issue tracker, and I suspect that is what we need? I added a vote for it as well.
Thanks for helping!
Jonas
Previous Topic:Change Process ID, BPMN2 elements ID
Next Topic:EventBasedGateway with catch events always shows validation errors
Current Time: Mon Jul 21 08:31:47 EDT 2025
Powered by FUDForum. Page generated in 0.07416 seconds
