Home » Modeling » TMF (Xtext) » Invoke a Rule Explicitly
Invoke a Rule Explicitly [message #1729891] Wed, 20 April 2016 02:24 Go to next message
  override dispatch createProposals(RuleCall ruleCall, ContentAssistContext context,
    IIdeContentProposalAcceptor acceptor)
How can I invoke a rule which is not triggered.
For example,
I know that a particular rule will not be invoked at an instance.
I wish to trigger it ,So that the above is executed with the particular rule
[Updated on: Wed, 20 April 2016 02:39] by Moderator
Re: Invoke a Rule Explicitly [message #1729892 is a reply to message #1729891] Wed, 20 April 2016 02:42 Go to previous messageGo to next message
hi i dont get that question.
you can create any proposals at any place but you have to do it manually.
Re: Invoke a Rule Explicitly [message #1729897 is a reply to message #1729892] Wed, 20 April 2016 03:42 Go to previous messageGo to next message
I mean to say. suppose I want to invoke Some rule say
can I invoke it explicitly using java /xtend.
Re: Invoke a Rule Explicitly [message #1729898 is a reply to message #1729897] Wed, 20 April 2016 03:46 Go to previous messageGo to next message
i dont get your question if you want to propose "bla blubb" at any place call
val entry = new ContentAssistEntry => [
proposal = "bla blubb"
acceptor.accept(entry ...)
Re: Invoke a Rule Explicitly [message #1729899 is a reply to message #1729898] Wed, 20 April 2016 03:49 Go to previous messageGo to next message
As I understand ,
The rules are called implictly.
Hello:
ID;
I know if I type "abc" ,Hello rule will be invoked .
I wish to invoke Hello rule ,by java or xtend code.So that I get the rule call here. Its like i want to tell, trigger this rule no matter what
[Updated on: Wed, 20 April 2016 03:50] by Moderator
Re: Invoke a Rule Explicitly [message #1729901 is a reply to message #1729899] Wed, 20 April 2016 03:53 Go to previous messageGo to next message
sry i have no idea on that.
i am talking about the initial method that is called by content assist service which is createProposals(contexts, acceptor);
Re: Invoke a Rule Explicitly [message #1729909 is a reply to message #1729901] Wed, 20 April 2016 04:47 Go to previous message
ok Thanks
Previous Topic:Application freezes when typing an undefined terminal
Next Topic:Regarding ignoreCase for Keywords.
Current Time: Sun Jul 27 01:57:21 EDT 2025
Powered by FUDForum. Page generated in 0.05401 seconds
