Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Prevent tool tips from disappearing after fixed time
Prevent tool tips from disappearing after fixed time [message #1729717] Mon, 18 April 2016 08:51 Go to next message
When setting the tool tip text of a Control via the setToolTipText(String string) method, the tool tip disappears after a fixed time (around 3 seconds). This happens regardless if the user provides input or not.
What would be the best way to show the tool tip indefinitely (i.e. without a time limit) until the user provides some input (e.g. moving the mouse cursor)?
Thanks in advance!
Vlad
Re: Prevent tool tips from disappearing after fixed time [message #1729728 is a reply to message #1729717] Mon, 18 April 2016 09:44 Go to previous messageGo to next message
Use a JFace-Tooltip
Tom
On 18.04.16 14:51, Vlad Acretoaie wrote:
> the mouse cursor)?
> Thanks in advance!
> Cheers,
> Vlad
Re: Prevent tool tips from disappearing after fixed time [message #1729791 is a reply to message #1729728] Tue, 19 April 2016 02:45 Go to previous message
Hi Thomas,
Thanks for the quick answer. That was my initial idea as well.
I was hoping for something that would require fewer changes to my existing code (like setting a timeout value somewhere), but it seems like this is the only way to go.
Vlad
Previous Topic:Accessibility for rows in Tree with SWT_CHECK style
Next Topic:shell - can't drive initial size
Current Time: Sun Aug 31 14:40:50 EDT 2025
Powered by FUDForum. Page generated in 0.04054 seconds
