Home » Eclipse Projects » EclipseLink » Non-foreign key added in batchfetch select(Non-foreign key added in batchfetch select)
Non-foreign key added in batchfetch select [message #1729476] |
Thu, 14 April 2016 09:01  |
Hi!
I am using Eclipselink 2.3.1 with Oracle.
I have two tables, MALH and MALHAND. In both tables I have a primary key 'ID'. Table MALHAND has a foreign key 'MALH_ID', which points to the column MALH.ID. There may be multiple rows in MALHAND for each row in MALH.
In Malh.java I have the following notation:
@OneToMany(fetch = FetchType.LAZY, mappedBy = "mal", cascade = CascadeType.ALL)
@BatchFetch(value = BatchFetchType.EXISTS, size = 2)
private List<Malhand> malhandelser = new LinkedList<Malhandelse>();
whereas in Malhand.java I have
@ManyToOne
@JoinColumn(name = "VERKSTALLIGHETSMAL_ID")
private Malh mal;
However, this fails, and when looking in the logs I see the error below, where another, non-foreign key, column 'MALNUMMER' has been added to the query!
That column exists for sure, but it is definitely not a foreign key, nor is it by any means a primary key! Why is it added? And why doesn't it get any values?
Error Code: 936
Query: ReadAllQuery(name="malhand" referenceClass=Malhand sql="SELECT t0.ID, [...truncated...] FROM MALHAND t0 WHERE EXISTS (SELECT t1.ID FROM MALH t1 WHERE ((t1.MALNUMMER IN ?) AND (t0.MALH_ID = t1.ID))) ")
Local Exception Stack:
Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.3.1.v20111018-r10243): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.SQLSyntaxErrorException: ORA-00936
Thanks in advance for any suggestions!
Re: Non-foreign key added in batchfetch select [message #1729721 is a reply to message #1729602] |
Mon, 18 April 2016 09:12   |
Setup:
Oracle database, the same data used in both tests below.
Test 1: JUnit test, i.e., no WebLogic involved. Works.
In pom.xml:
<dependency>
<groupId>com.oracle</groupId>
<artifactId>ojdbc6</artifactId>
<version>10.3.6</version>
</dependency>
<dependency>
<groupId>org.eclipse.persistence</groupId>
<artifactId>eclipselink</artifactId>
<version>2.3.1</version>
</dependency>
<dependency>
<artifactId>javax.persistence</artifactId>
<version>2.0.0</version>
</dependency>
In persistence.xml:
<property name="javax.persistence.jdbc.url" value="jdbc:oracle:thin:@//<removed>" />
<property name="javax.persistence.jdbc.driver" value="oracle.jdbc.driver.OracleDriver" />
<property name="javax.persistence.jdbc.user" value="<removed>" />
<property name="javax.persistence.jdbc.password" value="<removed>" />
<property name="eclipselink.target-database" value="org.eclipse.persistence.platform.database.OraclePlatform" />
<property name="eclipselink.cache.shared.default" value="false" />
<property name="eclipselink.jdbc.batch-writing" value="jdbc" />
<property name="eclipselink.jdbc.batch-writing.size" value="100" />
From log:
[EL Finest]: 2016-04-18 11:39:02.723--UnitOfWork(6534179)--Thread(Thread[main,5,main])
--Execute query ReadAllQuery(name="findByMalnummer" referenceClass=Malh sql="SELECT ID, DTYPE, MALID, MALNUMMER, ORIGIN_SYSTEM, REFERENSNUMMER, REGISTRERINGSDATUM, UPDATED, UPDATED_BY, VERSION FROM MALH WHERE (MALNUMMER = ?)"
[EL Fine]: 2016-04-18 11:39:02.725--ClientSession(22732137)--Connection(12942642)--Thread(Thread[main,5,main])
--SELECT ID, DTYPE, MALID, MALNUMMER, ORIGIN_SYSTEM, REFERENSNUMMER, REGISTRERINGSDATUM, UPDATED, UPDATED_BY, VERSION FROM MALH WHERE (MALNUMMER = ?)
bind => [198702031280-3]
[EL Finest]: 2016-04-18 11:39:02.873--UnitOfWork(6534179)--Thread(Thread[main,5,main])
--Execute query ReadAllQuery(name="malhands" referenceClass=Malhand sql="SELECT t0.ID, t0.EXNUMMER, t0.NOTERING, t0.STATUS, t0.TEAM, t0.VERKSTALLIGHETSMAL_ID FROM MALHAND t0 WHERE EXISTS (SELECT t1.ID FROM MALH t1 WHERE ((t1.MALNUMMER = ?) AND (t0.VERKSTALLIGHETSMAL_ID = t1.ID))) ")
[EL Fine]: 2016-04-18 11:39:02.873--ClientSession(22732137)--Connection(12942642)--Thread(Thread[main,5,main])
--SELECT t0.ID, t0.EXNUMMER, t0.NOTERING, t0.STATUS, t0.TEAM, t0.VERKSTALLIGHETSMAL_ID FROM MALHAND t0 WHERE EXISTS (SELECT t1.ID FROM MALH t1 WHERE ((t1.MALNUMMER = ?) AND (t0.VERKSTALLIGHETSMAL_ID = t1.ID)))
Test 2: Accessing the same data using WebLogic. Doesn't work.
WebLogic info:
<2016-apr-18 kl 11:52 CEST> <Info> <WebLogicServer> <BEA-000377> <Starting WebLogic Server with Java HotSpot(TM) Client VM Version 20.4-b02 from Sun Microsystems Inc.>
<2016-apr-18 kl 11:52 CEST> <Info> <Management> <BEA-141107> <Version: WebLogic Server Temporary Patch for 9923849 Tue Oct 18 16:53:26 MDT 2011
WebLogic Server 10.3.6.0.6 PSU Patch for BUG17071663 Tue OCT 02 13:01:30 IST 2013
Eclipselink info:
Oracle info:
<BEA-001177> <Creating data source connection pool named oraclePool, URL = jdbc:oracle:thin:@<removed>, Properties = user=<removed>;.>
<BEA-000626> <Free resources in pool "oraclePool" will be tested every "600" seconds.>
<BEA-001516> <Data source connection pool "oraclePool" connected to Database: "Oracle", Version: "Oracle Database 12c Enterprise Edition Release 12.1.0.2.0 - 64bit Production
With the Partitioning, OLAP, Advanced Analytics and Real Application Testing options".>
<BEA-001517> <Data source connection pool "oraclePool" using Driver: "Oracle JDBC driver", Version: "11.2.0.1.0".>
From persistence.xml:
<property name="eclipselink.target-server" value="WebLogic_10" />
From persistence log:
[EL Finest]: 2016-04-18 14:19:45.246--ServerSession(24317947)--Thread(Thread[[ACTIVE] ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)',5,Pooled Threads])--reconnecting to external connection pool
[EL Fine]: 2016-04-18 14:19:45.25--ServerSession(24317947)--Connection(24167087)--Thread(Thread[[ACTIVE] ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)',5,Pooled Threads])--SELECT ID, DTYPE, MALID, MALNUMMER, ORIGIN_SYSTEM, REFERENSNUMMER, REGISTRERINGSDATUM, UPDATED, UPDATED_BY, VERSION FROM MALH WHERE (MALNUMMER IN (?))
[EL Finest]: 2016-04-18 14:19:45.252--ServerSession(24317947)--Connection(24483974)--Thread(Thread[[ACTIVE] ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)',5,Pooled Threads])--Connection released to connection pool [read].
[EL Finest]: 2016-04-18 14:19:45.256--UnitOfWork(3593080)--Thread(Thread[[ACTIVE] ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)',5,Pooled Threads])--Execute query ReadAllQuery(name="malhands" referenceClass=Malhand sql="SELECT t0.ID, t0.EXNUMMER, t0.NOTERING, t0.STATUS, t0.TEAM, t0.VERKSTALLIGHETSMAL_ID FROM MALHAND t0 WHERE EXISTS (SELECT t1.ID FROM MALH t1 WHERE ((t1.MALNUMMER IN ?) AND (t0.VERKSTALLIGHETSMAL_ID = t1.ID))) ")
[EL Finest]: 2016-04-18 14:19:45.256--ServerSession(24317947)--Connection(53028)--Thread(Thread[[ACTIVE] ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)',5,Pooled Threads])--Connection acquired from connection pool [read].
[EL Finest]: 2016-04-18 14:19:45.256--ServerSession(24317947)--Thread(Thread[[ACTIVE] ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)',5,Pooled Threads])--reconnecting to external connection pool
[EL Fine]: 2016-04-18 14:19:45.256--ServerSession(24317947)--Connection(18840807)--Thread(Thread[[ACTIVE] ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)',5,Pooled Threads])--SELECT t0.ID, t0.EXNUMMER, t0.NOTERING, t0.STATUS, t0.TEAM, t0.VERKSTALLIGHETSMAL_ID FROM MALHAND t0 WHERE EXISTS (SELECT t1.ID FROM MALH t1 WHERE ((t1.MALNUMMER IN ()) AND (t0.VERKSTALLIGHETSMAL_ID = t1.ID)))
[EL Fine]: 2016-04-18 14:19:45.259--ServerSession(24317947)--Thread(Thread[[ACTIVE] ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)',5,Pooled Threads])--SELECT 1 FROM DUAL
[EL Finest]: 2016-04-18 14:19:45.26--ServerSession(24317947)--Connection(53028)--Thread(Thread[[ACTIVE] ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)',5,Pooled Threads])--Connection released to connection pool [read].
[EL Warning]: 2016-04-18 14:19:45.26--UnitOfWork(3593080)--Thread(Thread[[ACTIVE] ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)',5,Pooled Threads])--Local Exception Stack:
Internal Exception: java.sql.SQLSyntaxErrorException: ORA-00936: uttryck saknas
Error Code: 936
Call: SELECT t0.ID, t0.EXNUMMER, t0.NOTERING, t0.STATUS, t0.TEAM, t0.VERKSTALLIGHETSMAL_ID FROM MALHAND t0 WHERE EXISTS (SELECT t1.ID FROM MALH t1 WHERE ((t1.MALNUMMER IN ()) AND (t0.VERKSTALLIGHETSMAL_ID = t1.ID)))
Query: ReadAllQuery(name="malhands" referenceClass=Malhand sql="SELECT t0.ID, t0.EXNUMMER, t0.NOTERING, t0.STATUS, t0.TEAM, t0.VERKSTALLIGHETSMAL_ID FROM MALHAND t0 WHERE EXISTS (SELECT t1.ID FROM MALH t1 WHERE ((t1.MALNUMMER IN ?) AND (t0.VERKSTALLIGHETSMAL_ID = t1.ID))) ")
From exception log:
2016-04-18 12:01:07,272 [[ACTIVE] ExecuteThread: '4' for queue: 'weblogic.kernel.Default (self-tuning)'] ERROR stacktrace:11 -
Error Code: 936
Error Code: 936
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:333)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:644)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeCall(DatabaseAccessor.java:535)
at org.eclipse.persistence.internal.sessions.AbstractSession.basicExecuteCall(AbstractSession.java:1717)
at org.eclipse.persistence.sessions.server.ServerSession.executeCall(ServerSession.java:566)
at org.eclipse.persistence.sessions.server.ClientSession.executeCall(ClientSession.java:207)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:207)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:193)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeSelectCall(DatasourceCallQueryMechanism.java:264)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.selectAllRows(DatasourceCallQueryMechanism.java:646)
at org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectAllRowsFromTable(ExpressionQueryMechanism.java:2611)
at org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectAllRows(ExpressionQueryMechanism.java:2570)
at org.eclipse.persistence.queries.ReadAllQuery.executeObjectLevelReadQuery(ReadAllQuery.java:420)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeDatabaseQuery(ObjectLevelReadQuery.java:1081)
at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:844)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:1040)
at org.eclipse.persistence.queries.ReadAllQuery.execute(ReadAllQuery.java:392)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:1128)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2871)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1516)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1498)
at org.eclipse.persistence.mappings.CollectionMapping.executeBatchQuery(CollectionMapping.java:883)
at org.eclipse.persistence.mappings.ForeignReferenceMapping.extractResultFromBatchQuery(ForeignReferenceMapping.java:579)
at org.eclipse.persistence.mappings.CollectionMapping.extractResultFromBatchQuery(CollectionMapping.java:864)
at org.eclipse.persistence.internal.indirection.BatchValueHolder.instantiate(BatchValueHolder.java:58)
at org.eclipse.persistence.internal.indirection.QueryBasedValueHolder.instantiate(QueryBasedValueHolder.java:88)
at org.eclipse.persistence.internal.indirection.DatabaseValueHolder.getValue(DatabaseValueHolder.java:88)
at org.eclipse.persistence.internal.indirection.UnitOfWorkValueHolder.instantiateImpl(UnitOfWorkValueHolder.java:161)
at org.eclipse.persistence.internal.indirection.UnitOfWorkValueHolder.instantiate(UnitOfWorkValueHolder.java:222)
at org.eclipse.persistence.indirection.IndirectList.buildDelegate(IndirectList.java:244)
at org.eclipse.persistence.indirection.IndirectList.getDelegate(IndirectList.java:414)
at org.eclipse.persistence.indirection.IndirectList$1.<init>(IndirectList.java:542)
at org.eclipse.persistence.indirection.IndirectList.listIterator(IndirectList.java:541)
at org.eclipse.persistence.indirection.IndirectList.iterator(IndirectList.java:505)
at malh.interfaces.gui.dto.MalhandConverter.entityListToInternalList(MalhandConverter.java:40)
at malh.interfaces.gui.dto.MalhAssembler.toDto(MalhAssembler.java:20)
at malh.interfaces.gui.MalhFacadeBean.getMalh(MalhFacadeBean.java:66)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at com.bea.core.repackaged.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
at com.bea.core.repackaged.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at com.bea.core.repackaged.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at com.oracle.pitchfork.intercept.MethodInvocationInvocationContext.proceed(MethodInvocationInvocationContext.java:103)
at re.common.ejb.interceptor.JPAFlushingInterceptor.flushIfPossible(JPAFlushingInterceptor.java:40)
at com.oracle.pitchfork.intercept.JeeInterceptorInterceptor.invoke(JeeInterceptorInterceptor.java:68)
at com.bea.core.repackaged.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at auth.AuthInterceptor.auth(AuthInterceptor.java:17)
at re.common.ejb.interceptor.WebExceptionInterceptor.logCall(WebExceptionInterceptor.java:35)
at re.common.ejb.interceptor.ResponseStateInterceptor.processCall(ResponseStateInterceptor.java:22)
at kz.framework.audit.KzWebAuditInterceptor.logCall(KzWebAuditInterceptor.java:38)
at kz.ejb.callcontext.KzCallContextInterceptor.auth(KzCallContextInterceptor.java:42)
at com.bea.core.repackaged.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:131)
at com.bea.core.repackaged.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:119)
at com.oracle.pitchfork.spi.MethodInvocationVisitorImpl.visit(MethodInvocationVisitorImpl.java:34)
at weblogic.ejb.container.injection.EnvironmentInterceptorCallbackImpl.callback(EnvironmentInterceptorCallbackImpl.java:54)
at com.oracle.pitchfork.spi.EnvironmentInterceptor.invoke(EnvironmentInterceptor.java:42)
at com.bea.core.repackaged.springframework.aop.interceptor.ExposeInvocationInterceptor.invoke(ExposeInvocationInterceptor.java:89)
at com.bea.core.repackaged.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy204.getMalh(Unknown Source)
at malh.interfaces.gui.MalhFacadeBean_w630g_MalhFacadeImpl.__WL_invoke(Unknown Source)
at weblogic.ejb.container.internal.SessionRemoteMethodInvoker.invoke(SessionRemoteMethodInvoker.java:40)
at malh.interfaces.gui.MalhFacadeBean_w630g_MalhFacadeImpl.getMalh(Unknown Source)
at malh.interfaces.gui.MalhFacadeBean_w630g_MalhFacadeImpl_WLSkel.invoke(Unknown Source)
at weblogic.rmi.internal.ServerRequest.sendReceive(ServerRequest.java:174)
at weblogic.rmi.cluster.ClusterableRemoteRef.invoke(ClusterableRemoteRef.java:347)
at weblogic.rmi.cluster.ClusterableRemoteRef.invoke(ClusterableRemoteRef.java:261)
at malh.interfaces.gui.MalFacadeBean_w630g_MalFacadeImpl_1036_WLStub.getAktivaOchAvstalldaVerkstallighetsmal(Unknown Source)
at weblogic.ejb.container.internal.RemoteBusinessIntfProxy.invoke(RemoteBusinessIntfProxy.java:85)
at $Proxy203.getMalh(Unknown Source)
at re.web.service.MalhServiceAdapter.hamtaMalh(MalhServiceAdapter.java:48)
at re.web.mal.MalhHolder.laddaMalh(MalhHolder.java:76)
at re.web.mal.maloversikt.MalhController.sokMalh(MalhController.java:152)
at com.sun.el.parser.AstValue.invoke(AstValue.java:187)
at com.sun.el.MethodExpressionImpl.invoke(MethodExpressionImpl.java:297)
at com.sun.faces.facelets.el.TagMethodExpression.invoke(TagMethodExpression.java:105)
at javax.faces.component.MethodBindingMethodExpressionAdapter.invoke(MethodBindingMethodExpressionAdapter.java:88)
at com.sun.faces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:102)
at re.web.infra.listener.ReginaActionListener.callSuperProcessAction(ReginaActionListener.java:33)
at re.web.infra.listener.ReginaActionListener$1.processAction(ReginaActionListener.java:21)
at re.web.infra.listener.ActionListenerChain.execute(ActionListenerChain.java:26)
at re.web.infra.listener.ExceptionListenerWrapper.processAction(ExceptionListenerWrapper.java:16)
at re.web.infra.listener.TraceLoggingListenerWrapper.executeChain(TraceLoggingListenerWrapper.java:155)
at re.web.infra.listener.TraceLoggingListenerWrapper$ProcessEventMethodInvocation.proceed(TraceLoggingListenerWrapper.java:59)
at kz.guice.interceptor.TraceLoggingInterceptor.invoke(TraceLoggingInterceptor.java:105)
at re.web.infra.listener.TraceLoggingListenerWrapper.processAction(TraceLoggingListenerWrapper.java:162)
at re.web.infra.listener.ReginaActionListener.processAction(ReginaActionListener.java:29)
at javax.faces.component.UICommand.broadcast(UICommand.java:315)
at javax.faces.component.UIViewRoot.broadcastEvents(UIViewRoot.java:794)
at javax.faces.component.UIViewRoot.processApplication(UIViewRoot.java:1259)
at com.sun.faces.lifecycle.InvokeApplicationPhase.execute(InvokeApplicationPhase.java:81)
at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:101)
at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:118)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:409)
at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:227)
at weblogic.servlet.internal.StubSecurityHelper.invokeServlet(StubSecurityHelper.java:125)
at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:301)
at weblogic.servlet.internal.TailFilter.doFilter(TailFilter.java:26)
at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:60)
at re.web.infra.filter.SessionBeanInitializationFilter.doFilter(SessionBeanInitializationFilter.java:71)
at kz.ejb.callcontext.KzCallContextFilter.doFilter(KzCallContextFilter.java:48)
at weblogic.servlet.internal.RequestEventsFilter.doFilter(RequestEventsFilter.java:27)
at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.wrapRun(WebAppServletContext.java:3739)
at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.run(WebAppServletContext.java:3705)
at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321)
at weblogic.security.service.SecurityManager.runAs(SecurityManager.java:120)
at weblogic.servlet.internal.WebAppServletContext.securedExecute(WebAppServletContext.java:2282)
at weblogic.servlet.internal.WebAppServletContext.execute(WebAppServletContext.java:2181)
at weblogic.servlet.internal.ServletRequestImpl.run(ServletRequestImpl.java:1491)
at weblogic.work.ExecuteThread.execute(ExecuteThread.java:256)
at weblogic.work.ExecuteThread.run(ExecuteThread.java:221)
Caused by: java.sql.SQLSyntaxErrorException: ORA-00936: uttryck saknas
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:439)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:395)
at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:802)
at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:436)
at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:186)
at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:521)
at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:205)
at oracle.jdbc.driver.T4CPreparedStatement.executeForDescribe(T4CPreparedStatement.java:861)
at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1145)
at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1267)
at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3449)
at oracle.jdbc.driver.OraclePreparedStatement.executeQuery(OraclePreparedStatement.java:3493)
at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeQuery(OraclePreparedStatementWrapper.java:1491)
at weblogic.jdbc.wrapper.PreparedStatement.executeQuery(PreparedStatement.java:135)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeSelect(DatabaseAccessor.java:931)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:607)
... 175 more
2016-04-18 12:01:07,300 [[ACTIVE] ExecuteThread: '4' for queue: 'weblogic.kernel.Default (self-tuning)'] ERROR stacktrace:11 - ORA-00936: uttryck saknas
at framework.audit.KzWebAuditInterceptor.logCall(KzWebAuditInterceptor.java:38)
at malh.interfaces.gui.MalhFacadeBean_w630g_MalhFacadeImpl_1036_WLStub.getMalh(Unknown Source)
at guice.interceptor.TraceLoggingInterceptor.invoke(TraceLoggingInterceptor.java:105)
Re: Non-foreign key added in batchfetch select [message #1729803 is a reply to message #1729768] |
Tue, 19 April 2016 04:13  |
Sorry, my bad... there are two similar methods in our code, one taking a list as argument, the other just taking a single value, and I posted the latter version by mistake.
However, I just doublechecked, and the outcome is exactly the same (i.e., in the log '= ?' is naturally replaced by 'IN (?)', but the test works the same. With emphasis on 'works'. )
Sorry for the confusion, clumsy of me.
Current Time: Sat Jul 26 10:59:25 EDT 2025
Powered by FUDForum. Page generated in 0.05686 seconds
