Algorithmic language project for writing algorithms in French. [message #1729454] |
Thu, 14 April 2016 05:38  |
Xtext Algorithmic project:
Grammar (simplified) of my language:
grammar com.infoly.xtext.algo.Algorithmic with org.eclipse.xtext.common.Terminals
generate algorithmic "http://www.infoly.com/xtext/algo/Algorithmic"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
/* 12 avril 2016
* PROJET ALGORITHMIC
Algorithmic:
// typesUser=TypesDecl?
constantes=ConstsDecls?
variables=VarsDecls?
modules+=Module*;
Module:
module=MODULE_TYPE name=ModuleName '(' parameters=Parameters? ')' (':' typeReturn=Type)?
constlocales=ConstsDecls?
varlocales=VarsDecls?
body = Body
ModuleCall:
{ModuleCall}
ref= (ModuleRef | Library) ( '(' arguments+=Arguments? ')' )
ModuleRef: ref=[ModuleName];
ModuleName: name=ValidID;
Body:
{Body}
'Début'
statements+=Statement*
last=LastStatement?
'Fin'
Statement returns Expression:
StatementAssignment
| StatementCall
StatementCall:
ModuleCall
StatementAssignment returns Expression:
var=VarRef '<-' expr=Expression
LastStatement:
(isFunction?='Retourne') expr=Expression
* EXPRESSIONs
Expression:
expr=ExpressionPlusMinus
ExpressionPlusMinus returns Expression:
ExpressionMulDivModulo (
('+' {Expression_Plus.left=current} right=ExpressionMulDivModulo) |
('-' {Expression_Minus.left=current} right=ExpressionMulDivModulo)
ExpressionMulDivModulo returns Expression:
ExpressionTerminal (
('*' {Expression_Mul.left=current} right=ExpressionTerminal)
| ('/' {Expression_Div.left=current} right=ExpressionTerminal)
| ('%' {Expression_Modulo.left=current} right=ExpressionTerminal)
ExpressionTerminal returns Expression :
ExpressionValue // Un litéral: Value : INT | FLOAT | BOOL | STRING
| ExpressionDataOrModuleCall // Const, var, param ou module ou librairie
// | ExpressionData
// | ModuleCall
| ('(' Expression ')')
ExpressionValue:
{IntegerLiteral} value=INT |
{FloatLiteral} value=FLOAT |
{StringLiteral} value=STRING |
{StringLiteral} value=EXIT |
{BooleanLiteral} value=BOOL
ExpressionDataOrModuleCall returns Expression :
DataRef
| ModuleCall
// VARIOUS TRY
// | (Library | ModuleRef) ( '(' arguments+=Arguments? ')' )
// | (=> refM=ModuleRef '(' arguments+=Arguments? ')' )
// | (Library '(' arguments+=Arguments? ')' )
// ((AllRef '(') | (=>LibRef '(')) arguments+=Arguments? ')' // FACTORISE NOK
* LIBRARY
Library: {Library} (Display | Get);
LibRef: ref=[Library];
Display: 'afficher';
Get: 'saisir';
* DATAs
AllName:
ConstName | VarName | ParName | ModuleName
AllRef:
ref = [AllName]
DataName:
DataRef:
refData = [DataName]
ConstsDecls :
('Constante:'|'Const:')
constantes += ConstsDecl (';'? constantes += ConstsDecl)*
ConstsDecl :
type=Type ':' conststype += Constante (',' conststype += Constante)*
Constante:
name=ConstName init=Init
ConstName:
name=ValidID
VarsDecls:
isWritable ?= ('Variable:'|'Var:')
variables += VarsDecl (';'? variables += VarsDecl)*
VarsDecl:
type=Type ':' varstype += Variable (',' varstype += Variable)*
VarRef:
ref = [Variables]
Variables:
Variable | Param
Variable:
VarName init=Init?
VarName:
name=ValidID
Parameters:
params += CategoryParams (';'? params += CategoryParams)* // Catégories E, E/S, S
CategoryParams:
category=PARAM_CATEGORY param=Params //| ConstsDecl
// isWritable=((category=PARAM_CATEGORY) ?= ('E:'|'E/S:')) param=Params
Params:
pars += ParamsDecl (';'? pars += ParamsDecl)*
ParamsDecl:
type=Type ':' parstype += Param (',' parstype += Param)*
Param:
ParName init=Init?
Arguments:
args += Expression (','? args += Expression)*
Init:
(isAssigned ?= '<-') value = Expression
ParName:
name=ValidID
ValidID:
ID
* TYPEs
TypesDecl: 'Type:' types += TypeDecl;
TypeDecl : base=Type ':' name=ValidID;
TypeUser : ref=[TypeDecl];
Type:
TypePrimitif | TypeStructured // | TypeUser
TypePrimitif:
TypeInt | TypeFloat | TypeBool | TypeChar
TypeInt: type = 'Entier' ;
TypeFloat: type = 'Réel';
TypeBool: type = 'Booléen';
TypeChar: type = 'Caractère';
TypeStructured:
TypeString | TypeArray | TypeStruct
TypeString: type = 'Chaine';
TypeArray: type = 'Tableau';
TypeStruct: type = 'Structure';
* ENUMs
enum MODULE_TYPE:
PROG='Programme' | FUNC='Fonction' | PROC='Procédure' | ONEVENT='SurEvénement'
enum PARAM_CATEGORY:
IN='E:' | INOUT='E/S:' | OUT='S:'
* TERMINALs
terminal fragment DIGIT: ('0'..'9');
terminal BOOL: ('VRAI'|'FAUX') ;
terminal EXIT: ('SUCCES' | 'ECHEC');
terminal FLOAT returns ecore::EFloat :
('+' | '-')? (('1'..'9' DIGIT* '.' DIGIT+ /* ? */) (('E' | 'e') ('+' | '-')? DIGIT+)?
| '0'? ('.' DIGIT+)? (('E' | 'e') ('+' | '-')? DIGIT+)? );
Problems
1) Sans le prédicat j'ai un conflit entre DataRef et ModuleRef. (LL Grammar)
2) Je voudrais faire ceci dans la grammaire :
1) Without the predicate I have a conflict between DataRef and ModuleRef. (LL Grammar)
2) I want to do this in the grammar:
DataRef
| ModuleCall
I wish it allows entering a Constant, Variable, Library or Module name like this for example:
* ALGORITHMIC
* ======== Grammaire =======
* NOK
// Globales Datas
Const:
Chaine : gTITRE <- "Le titre"
Entier : gVERSION <- 1.0
Var:
Réel : gReal
Chaine : gTexte
Entier : gE1, gE2
// Main module
Programme prog( )
Const:
Chaine : pINVITE <- "Entrez un nombre : "
Réel : pPI <- 3.14159
Var:
Chaine : pTexte
Réel : pR1, pR2, pResultat
Début
rdt( ) // Statement call Module
affiche( ) // Statement call Module
rdt( 123, 234 ) // Statement call Module with arguments
pTexte <- "Aire du disque:" // Statement assignment litteral
afficher( pTexte ) // Statement call Library
pR2 <- 2 * pPI * pR1 // Statement assignment Expression with variables
pResultat <- saisir( ) // Expression call Library
pResultat <- rdt( 123, 234, pResultat ) // Expression call Module NOK : Error DataName rdt
// while is is a ModuleName in propositions !!!!
rdt( 123,234, pResultat )
pTexte <- rdt( gE1 ) + gTITRE
pResultat <- 123 + gE1*gE2 - pR1/pR2 + pPI
pResultat <- pResultat + rdt( pR1, pR2, gE1)
afficher( pINVITE , pResultat)
pR1 <- afficher( pINVITE , pResultat)
Retourne SUCCES
Fin
// Function
Fonction rdt( E: Réel : fp1, fp2, fp3 ) : Réel
Var:
Réel : fRes
Début
fRes <- (fp1 * fp2) / fp3
Retourne fRes
Fin
// Procedure
Procédure affiche( E: Chaine : prInvite, ppp ; Réel : prReal ; S: Booléen : prState)
Var:
Chaine : prTxt
Réel : prRes
Début
prTxt <- prInvite
prRes <- prReal
prState <- VRAI
Fin
But it appears a bug:
• In the list of proposals rtd is seen as a ModuleName, which is correct.
• The error message displays a DataName is expected. This is probably the predicate that causes it but I do not see how to fix this.
Thank you in advance for your assistance.
FUDForum. Page generated in 0.04342 seconds
