specify STRING in my DSL, so I can use templates inside the string [message #1705437] |
Sat, 15 August 2015 07:47  |
in my DSL, I have defined some comment as STRING:
AComment: {AComment}
'comment=' commentText=STRING?
For convenience, I want to provide some templates in the DSL preference page which holds text blocks to be used inside the comment string
Problem:
I have not found a way to specify the context of the template so it will show up if I press CTRL-space inside the string.
Question:
Is there a trick to do the job with some clever grammar or so?
Why:
in xtend, when I call CTRL+space inside the ''' ''' string, it will insert the «»
Re: specify STRING in my DSL, so I can use templates inside the string [message #1729420 is a reply to message #1729412] |
Thu, 14 April 2016 01:09  |
xtend actually parses Strings. ntl you can xtend the behaviour how contexts are created. here is a wild guess (not really tested)
public class MyDslTemplateProposalProvider extends DefaultTemplateProposalProvider {
private ContextTypeIdHelper helper;
@Inject
public MyDslTemplateProposalProvider(TemplateStore templateStore, ContextTypeRegistry registry,
ContextTypeIdHelper helper) {
super(templateStore, registry, helper);
this.helper = helper;
protected void createTemplates(TemplateContext templateContext, ContentAssistContext context,
ITemplateAcceptor acceptor) {
System.out.println("context: " + context);
super.createTemplates(templateContext, context, acceptor);
protected TemplateContext[] createTemplateContexts(ContentAssistContext context) {
return super.createTemplateContexts(context);
protected IFollowElementAcceptor createFollowElementAcceptor(Collection<TemplateContextType> result) {
return new FollowElementAcceptor(result) {
public Boolean caseTerminalRule(TerminalRule object) {
addContextType(helper.getId(object));
return super.caseTerminalRule(object);
public class MyDslXtextTemplateContextTypeRegistry extends XtextTemplateContextTypeRegistry {
@Inject
public MyDslXtextTemplateContextTypeRegistry(IGrammarAccess grammarAccess, Provider<XtextTemplateContextType> ctxTypeProvider, ContextTypeIdHelper helper) {
super(grammarAccess, ctxTypeProvider, helper);
protected void registerContextTypes(IGrammarAccess grammarAccess,
Provider<XtextTemplateContextType> ctxTypeProvider) {
List<TerminalRule> terminalRules = GrammarUtil.allTerminalRules(grammarAccess.getGrammar());
for (TerminalRule terminalRule : terminalRules) {
String value = getHelper().getId(terminalRule);
if (value!=null) {
XtextTemplateContextType type = ctxTypeProvider.get();
type.setName("Terminal '"+terminalRule.getName()+"'");
type.setId(value);
addContextType(type);
super.registerContextTypes(grammarAccess, ctxTypeProvider);
public class MyDslContextTypeIdHelper extends ContextTypeIdHelper{
@Inject
private MyDslGrammarAccess ga;
public String getId(AbstractRule rule) {
if (rule instanceof TerminalRule) {
String id = ga.getGrammar().getName()+"."+rule.getName();
return id;
return super.getId(rule);
@FinalFieldsConstructor
class MyDslUiModule extends AbstractMyDslUiModule {
override bindITemplateProposalProvider() {
def Class<? extends ContextTypeIdHelper> bindContextTypeIdHelper() {
return MyDslContextTypeIdHelper
override bindContextTypeRegistry() {
FUDForum. Page generated in 0.07346 seconds
